Error code P0001
Discussion in 'Generation 1 Prius Discussion' started by aswresm, Sep 15, 2014.
  1. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    Got a P0001 error , Fuel volume regulator stuck opened....where is the fuel volume regulator is located on a first Gen. Prius?
    Thank you!!
  2. aswresm
    50
    2002 Prius
    I
    Is the fuel volume regulator is the same like a fuel pressure regulator??
  3. aswresm
    50
    2002 Prius
    I
    I see that the fuel pressure regulator is part of the injector rail assembly is that correct??
  4. ChapmanF
    15,111
    All of that stuff is bogus ... looks like you got a scan to start with from a scan tool that isn't Prius-compatible, and then looked up the code for some other car.
    Backing up a little ... Hi! What's wrong with your Prius? Was it doing something that made you think it should be scanned for codes? Are you anywhere near a dealer with a proper Prius scan tool? Or do you have a few minutes to search this forum and learn about other tools (Mini VCI, ScanGauge II, Torque, etc...) that will work?
    In case there is any fuel pressure problem, pump and regulator for your car are located in the tank and not separately replaceable.
    Cheers,
    -Chap
  5. aswresm
    50
    2002 Prius
    I
  6. Patrick Wong
    18,199
    6,464
    1. P0001 is not a valid Prius DTC. You need a better code reader, for example Mini VCI.
    2. The eBay part you provided a link to is not for Prius. Classic and 2G Prius use the 1NZFXE engine which is not the same as 1NZFE.
    Toyota NZ engine - Wikipedia, the free encyclopedia
    3. There is no fuel pressure regulator on the Prius fuel rail. If that part was present, that would require a return fuel line to the fuel tank. A casual inspection should immediately prove to you that there is no such return fuel line and no regulator on the fuel rail. This is a deliberate design feature to reduce HC vapor production by the fuel system.
    #6 Patrick Wong, Sep 15, 2014
  7. aswresm
    50
    2002 Prius
    I
    Thanks guys......I would work on getting the mini VCI soon.
  8. ChapmanF
    15,111
    Good plan. :)
  9. aswresm
    50
    2002 Prius
    I
