EV miles can be regenerated by PIP after EV depletion
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CraigCSJ, May 27, 2012.
  1. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    It is my understanding that the energy regenerated downhill while or during regenerative braking in EV, will be kind of "locked away" for later use, for example city driving. When you do this in HV, it will essentially be used up in order to maximalize fuel consumption in this mode. During climbing, the HV mode strives at keeping the SOC (state of charge) of the battery stable, and this costs some gas.
    In Paradoxes thread, it was not clear to me whether the whole is more economic or not. I understood he just found it fine to dispose of extra battery charge when it is particularly pleasant to drive in EV mode. I may be wrong. Maybe you can put your question in his thread?
    Jan
  2. CharlesH
    2,785
    1,152
    Roseville, CA
    As I understand it, when you do regeneration, the energy goes into the battery the same way regardless of theEV/HV setting. But when you start to need power, then the EV/HV setting comes into play. If you are in EV mode, then the battery will be drained. If you are in HV mode, the gasoline engine will be used to maintain the SOC that it had when you hit the HV button.
  3. Mister MMT
    285
    142
    Germany
    The way I do is different. I cite from Paradoxes thread:
    I think he got it right.
    Jan
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    I think we are saying the same thing. You go up hills in HV mode so the gasoline is burned to preserve the current battery charge. When you go downhill, it doesn't matter which setting you have, and your EV range goes up, as regeneration charges the battery. But some time before you get to a situation where were you need power, you hit HV to establish a new, higher, state of charge point. You will then burn gasoline to preserve that charge level, in HV mode. You can build up the charge in the battery using this "stacking" technique by going up and down hills.
    But my fundamental point still stands: what have you accomplished, other that getting a high "EV miles" statistic. You have just used the gasoline engine to charge the battery, rather than charging the battery from the plug. But you have burned the same amount of gasoline and just shuffled the energy around a bit.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Here's the deal for me.
    Most often, if not always, I have no way to charge other than at my house ( or work ). So... When I go on a trip, I use ev from my house to the highway. I usually then have 6 miles left. Once on the highway enroute to my destination if I am going down a hill where the hsi bar is in regen area or having to brake because of a light ahead I pop it into EV. Then, once having to accelerate to maintain speed, go up the hill or accelerate from the light I go back into HV. When I arrive at my destination, I'll have a full charge again. Yes, gas was used BUT it had to be used so I just stacked more range for when I get to my destination to have full charge for surface streets again. Once charge is used up, well down to say 2 miles, I begin the process again. So instead of using up the whole ev ability and using hv for e entire rest of the trip I preserve ev for when I want it and it makes sense to use it.
    On a recent trip to VA beach I did something like 990 miles. I could not charge except before I left my house on the trip. I did 69 miles total in EV out of those 990 by the stacking method. And I used those 69 miles when I wanted to use them, when it made sense to or when I just wanted to, like cruising Atlantic avenue in all ev and having people look as I drove by.
    Now, would it be better for mpg's to just use it up and let the car do what it wants in HV the rest of the trip? Maybe. Maybe not. Me, I personally don't care because I use this method because it works for me and allows me to do what I want when I want, meaning use ev/hv when I want. With the mpg's I still get in the end, it just isn't a concern for me. If it is for some experiment or just don't do it lol. I think those who understood where I was coming from when I first found this out right after buying the car do it for very similar of not the same reasons I do it.
    Btw, even though previous pics from before the site upgrade are not working, here's the thread with the pics from the trip to VA. My EV/HV mileage for 2 days round trip and continued updating with pics | Page 3 | PriusChat
    usbseawolf2000 and Mister MMT like this.
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I think the basic idea is, you have the option to decide when you want to use HV or EV and by utilizing this method to "stack" EV mileage, you can end up with a fair amount of charge you can choose to use when you want to use it.
    Many here have examples of when doing so may not be as efficient. Sure, going up a hill in HV and then storing the energy as I go down hill is just trying to recapture some of the energy used going up the hill while burning gas. But again, this is just a method that enables the driver to decide when to use gas and by doing so, possibly save up, bank, or stack enough EV range as to make it useful for some future driving where EV would be more beneficial.
    Here's an example:
    Let's say I drive 10 miles before I reach a big hill. When I reach that hill, I can leave it in EV and exhaust my remaining charge. However, I choose to switch to HV, retaining, say 1 mile of EV range. I climb the hill. On the way down, I regen another 1 miles of EV, I hit the switch to EV, then switch it back to HV. Now my stacked/banked EV range is 2 miles. I reach a second hill, climb that in HV, regen another 1 mile coming down. By now I've stacked 3 miles of EV (2 from the first hill and added 1 more after the 2nd hill).
    At bottom of the hill, I drive 1 more mile in EV to the city where I plan to run some errands.. maybe grab lunch (1 hour).. I now have 2 EV miles left.. stop by Home Depot/Costco/Target/Walmart which is 1 mile from the restaurant (1 hour there).. then pick up some dry cleaning 1 mile away from store..
    Now, had I left it in EV from the very beginning, I would've consumed all my EV range going up the first hill.. consumed whatever I regenerated from the 1st hill going up the 2nd hill.. and then consumed whatever I generated going down the 2nd hill as soon as I reached the city. That would mean my trip from the restaurant to the store and the trip from store to dry cleaner would both start the ICE (cold start since there was an hour in between each trip) for a 1 mile trip
    This is really no different than those of us who decide to use the ICE on the freeway and save the EV range for city driving. The only added dimension is that there is a way to build up/stack your EV range for parts of your drive that would be better suited (more efficient) for EV.
    Its a choice any PiP owner can make. Don't want to be bothered by it? Then don't.. just drive it.
    usbseawolf2000 likes this.
  7. Mister MMT
    285
    142
    Germany
    Edit: Paradox made his point in the mean time...
    Hi Charles,
    I am not sure and rather think we highlight different aspects. Let me try and summarize.
    In HV, when driving downhill and/or braking, the EV range climbs. While continuing in this mode, the EV range drops again, meaning the regenerated energy had been consumed. It is not said how much fuel this helped saving, probably some indeed.
    In EV, a similar increase in the avalable EV range is obtained. While continuing in HV mode, the EV range remains steady. The HSD system working as usual, the SOC stays largely stable.
    Repeating the above in EV several times, it is possible to "collect" an almost full load of battery power, which can be used for EV driving when it appears "nicest".
    Paradox considers this as a substantiel gain in comfort. That would be the accomplishment you were looking for. He did not say it was good or bad for fuel consumption.
    That is what I wanted to bring to the attention of the followers of this thread.
    It surely requests a proactive driving style, which may not be liked by everybody.
  8. CharlesH
    2,785
    1,152
    Roseville, CA
    So, Paradox, the point of stacking for you isn't gas economy or anything like that. It's that you really enjoy driving in EV mode and stacking is a way to increase the number of miles you can drive in that mode, which makes perfect sense to me.
    I was just worrying that some people might think that were somehow getting more EV miles from the plug or using less gasoline using this technique, which I don't think is the case. (OK, there is case where the ICE starts just to warm itself up, but how much gasoline is that?)
  9. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    That's right, I personally do not do it for mpg's. I do it because on the highway I want to use hv and once at my destination driving low speed highways, streets etc I would rather use ev. It may get me the same, more or less mpg's but in the end I just drive the car. Getting 55mpg just driving my way on a trip to Virginia beach from NYC never charging, driving 75 to 80mph a lot of the highway miles and netting 69 ev miles again without charging sure works for me lol.
  10. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I depleted my EV battery completely on the way home from the office yesterday. I also threw out my back and was in pain and just hobbled into the house last night not caring to plug in ... and when I started the car this morning, I had .08 EV miles back. That happens to me from time to time... but usually .06-.07 so maybe it's getting better over time!
  11. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    It's quite nice being able to have your cake and eat it too!
    I'm very pleased with how efficient the system is even without plugging in.
  12. I recently got 69 mpg doing 65 mph in HV and was quite pleased with that #. Total trip about 120 miles. I did bank some EV charge to use later back in suburbia.
  13. Sorry to hear about your back Dianne, I am going thru the something right now and am seeing a physical therapist, it can be really debilitating! Almost all healthy batteries will recover a small amout automatically, within PIP we have extra charging bonuses. As John described, I generally leave a EV supply on a trip where I think I will use up the EV anyway.
    DianneWhitmire likes this.
  14. DLee
    DLee Junior Member
    81
    Starting from Big Bear (San Bernardino, California Mountains) with a full charge, I can get all the way through Mentone and still have a full charge. And plenty of charge left at the hwy 38 entrance onto I-10. The drive is mostly downhill from 7K ft., but has ups and downs. Always enough battery to makes the uphills, and the PIP charges fast on a downhill.
  15. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    Question, if the ICE kick in to burn off electricity. Does it suck any gas?
    LT26i ? 2
  16. bisco
    49,019
  17. JamesCSmith
    JamesCSmith New Member
    59
    Actually it can burn gas in this situation if it is not warmed up yet. when I leave my house with a fully charged battery and go down a steep hill the ice kicks in to "burn off extra energy" or whatever. Then I stop at a stoplight at the bottom of the hill and the ice keeps running for a minute while the soc is still at 85. (full charge).
  18. DLee
    DLee Junior Member
    81
    Once a cold ICE starts, it has to fully warm up to meet emission specs. But, is it really starting when used as a brake? I would think "started" means the first time fuel is suppled to the engine. My understanding is that fuel is not supplied to the engine when used as a brake.
  19. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Yes, it really is started. The ICE will run until its warmed up as you pointed out.
    This happened to me a few times in the first few weeks of ownership. I then started putting it in N as I was coasting down the hill where the ICE would normally start and that prevented the excess regen. But I've since switched to braking later and harder to prevent the excess regen and havent had the "problem" for a few months now. However, it happened again last week (asleep at the wheel, I guess).
    Aside from the ICE running until its warmed up, you'll also notice your trip MPG drop (I reset it each morning). And it drops a lot.. its painful to watch (I'm only about 0.5 mile into my trip to work.. so it goes from 999 to something in the 100s until the ICE shuts off).
    Here's a log of my morning commute from 3/20/2012. Although I didnt log anything to do with MPG or the fuel injection system, you can see that the Engine RPM starts at row 132. It "idles" at around 1500 RPM for about 1 min 17 seconds where it drops to 1300 RPM. It then runs for another 3 minutes and 44 seconds before it shuts off. You'll also notice that the "magic number" is about 84% SOC where the ICE will start to prevent excess regen.
    Dropbox - torque_phv_20120320am.xls - Simplify your life
  20. I do enjoy your phraseology.
