Failed Inverter: Check Hybrid System Error U0110 Lost Communication W/ Drive Motor Cntrl Mod A
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jwedel, May 21, 2014.
  1. jwedel
    jwedel Junior Member
    Bellvue, Colorado
    I'm having it repaired under the warranty and then selling it privately where it can fetch 14-16k. I'm flying to California to pickup a plugin prius for 21k after dealer & tax incentives..
    Yes, it wouldn't make much sense to trade it while broken when it is under warranty.
    My question now is, was this a 2010 issues as I've seen a handful of inverter failures on only 2010's or will my 2014 be subject to the same issues? Still wonder if it was related to the recall (which they deny).
  2. jwedel
    Bellvue, Colorado
    Got a call last week that they've put two new inverters and a new CPU in the car and it still won't start. They are escalating it up to Toyota Engineering. Anyone else has had an issue like this?
    I'm surprised toyota hasn't bought the car for a case study - they are going to end up with more money in it under warranty with labor and rental fees than the car is worth.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Amazing, sad and scarey all at the same time. :eek:
    51,882
    wow, what have you been driving? i think we've seen one or two inverters in the pip.
  5. Former Member 68813
    3,524
    983
    US
    The OP should show it to the incompetent dealership. If the problem is with wiring, throwing new parts isn't going to fix it for sure.
    Like I said in my post back in May, this car probably needs some $5 dielectric grease in wiring connectors.
  6. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    It sounds as though your dealer's service department does not know enough about what they are doing with a Prius. You might at some stage wish to ask Toyota if they can recommend a competent dealership for future work.
  7. jwedel
    Bellvue, Colorado
    The car is functional again.. the mechanic doesn't know what was wrong with it. He said they unplugged a wire to the transaxle to test it (spun the motors) and afterwards the car started. He thinks one of the motors may have been stuck and was causing noise to the communications.
    friendly-jacek: I showed them your post initially and they looked at me like I was crazy.
    26 hours, 2 new inverters, new computers modules and no known cause. I guess the plus side is that it isn't another gen3 inverter failure (also, I was able to put 9,500 miles on a rental prius!)
  8. Former Member 68813
    3,524
    983
    US
    No, he unplugged it and plugged it again and the problem with bad electric contact went away. That was the first thing they should have done with all connectors instead throwing new inverters and computers at it. Idiots!
  9. Right2Know
    Right2Know Junior Member
    West Sacramento, CA
    2014 Prius v wagon
    Could it be that the software update had changed response code from the usual ones for hybrid inverter problems to the U0110 code? It seems really odd that the guys in service had never heard of the U0110 code till after the update on the car. Shifty Toyota software engineers??
  10. ChapmanF
    18,116
    U0110's a perfectly cromulent trouble code, explained in early editions of the repair manual, well before the recall updates. Means the power management control ECU (under the dash) isn't able to communicate with the MG ECU (inside the inverter housing).
    Both of those ECUs get firmware updates in the E0E / J0V recalls ... and of course lots of those recalls and updates got done without leaving the ECUs unable to talk to each other. So it seems like either something rare and weird went wrong in the recall service, or something unrelatedly went wrong two months later.
    "We've never heard of that code before" does seem kind of a lame thing for guys in service to say. Those are the times you look it up in the repair manual, guys, right?
