Flashing blue light?
Discussion in 'Gen 3 Prius Main Forum' started by mroe1, Apr 14, 2014.
  1. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Yes it is a KARR system
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    phoenixgreg likes this.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    Thanks for the link to the pdf manual. I saved it with my other pdfs. The KARR has a few more "bells and whistles" than the OEM system so I accepted mine when the dealer said it would be a major effort to extract it. In fact, they would have had to have a tech from KARR come out to do it. I just caved and took the system. I wish it had the TRACK feature, but really, what is the risk here of a theft? Maybe if gas got up to $7 a gallon we could worry.
  4. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Original or after market, I am not sure. In any case, I still can't figure out way when no one is near the car, as in my driveway, the horn beeps a couple of times, almost like some kind of warning. When I close my door and touch the locking sensor, the horn beeps once and the door unlocks. Then when I come back and grab the handle, the horn beeps twice and the door unlocks
  5. phoenixgreg
    1,157
    288
    66
    Phoenix
    That's by design. The KARR system has motion and shock sensors so if someone bumps the car a bit, it will send out warning "chirps". If hit hard enough, the alarm goes off. My car even chirps if there's loud thunder.
  6. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Okay, that makes sense, but mine does it when there's no noise, thunder, and no one has bumped it. Could it maybe have to do with temperature? As I am in Arizona and the car get's pretty hot.
  7. phoenixgreg
    1,157
    288
    66
    Phoenix
    Is it 4 short chirps from the horn, or 2 beeps from the horn? The chirps are the motion/shock warning sensors but the 2 beeps would be the unlocking function. If you are getting chirps with no obvious motions then it's possible the sensors are shorting. If it's 2 beeps from the horn, maybe your remote(s) are sending the unlock signal. Sometimes buttons on remotes depress inside a tight pocket.
    If you think the system has a problem - unfortunately KARR will only make house calls to diagnose and then repair...there is no KARR shop to go to. I almost had to do this and they quoted me about $100 to make a house call. They can be reached at (877) 909-5277.
  8. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    Was working by the car the other day, no thunder noise are anything else for that matter, but it beeped 5 times. Maybe the next time I go to the dealer for my free check up's I should say something about it, or just have then turn it off or uninstall it?
  9. bisco
    49,058
    step away from the car...
  10. nicoj36
    nicoj36 Active Member
    495
    156
    Probably the "neon" lights. lol
  11. phoenixgreg
    1,157
    288
    66
    Phoenix
    Just put it in Valet mode which is essentially disabling it:
    Valet mode – with Prius on, press and hold for 5 seconds until solid blue LED
    Other programming options:
    Make sure Karr is disarmed (no LED lights)
    Turn Prius on
    Press and release Karr button 3 times
    Short LED light with 1 short horn
    Before 3 seconds, turn Prius off
    Horn will give a short-long chirp
    Within 3 seconds, turn Prius back on (now in programming mode)
    Horn will give a long-short chirp
    Press Karr button one time per option (there are 4 options) the Karr LED will flash the number of times per option you are on.
    Option 1 (one flash): wait ½ second and horn should chirp once (auto-lock with ignition on)
    Option 2 (two flashes): wait ½ second and horn should chirp once (auto unlock with ignition off)
    Option 3 (three flashes): wait ½ second and horn should chirp twice (passive arming and lock without lock)
    Option 4 (four flashes): wait ½ second and horn should chirp twice (active arming)
    Turn Prius off to exit programming.
    Get out and arm…LED should flash.
    Wait a bit and then attempt to disarm with fob.
    Valet mode off – within 3 seconds of Prius on, press and hold until LED off​
    sfv41901 likes this.
