FOB response slow???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, May 23, 2015.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    All
    last couple my FOB response slow, I thought it was FOB battery, I replaced it, no help, If I stay about 20ft in front of the car I can not lock it, I have to stay close to the door before I can lock it. Do you think it is my 12v battery? my Scangauge 2 still show 14.2v; any idea please let me know.
    V/r
    Khoi Nguyen
  2. JC91006
    16,470
    8,383
    it's not your 12v. do you have the spare fob to try?
  3. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    JC91006
    Yes I did, tried spare one too, same thing.
  4. JC91006
    16,470
    8,383
    I don't know the range of the fobs, I usually only use SKS to enter and lock the car. Seems odd both fobs do the same.
  5. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    JC96001
    I usually use the FOB lock my car from my garage, I can not do that anymore with both FOB. Please try your should be work with 50ft.
  6. JC91006
    16,470
    8,383
    try it outside your garage
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    did that too
  8. JC91006
    16,470
    8,383
    what's your 12v measure? it shouldn't be 14.2v if it's off.
  9. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    from Scangauge 2; why do you think if off?
  10. JC91006
    16,470
    8,383
    a new 12v should measure 12.8 or higher. seeing you have 2010, it probably would be weaker, closer to 12v. If it's less, then you should replace it since it's 5 years old.
    but I still can't imagine that causing the issue.
  11. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    JC91006
    That what I want to find out, I had Scangauge2 connected to ODB2 for last 4 years, always keep my eyes to it, but Scangauge2 indicate 14.2v, how do you find out your battery is going bad?
  12. JC91006
    16,470
    8,383
    Since your battery is 5 years old, just assume it's bad and buy another one. It's not going to last that much longer.
  13. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Well, Just went to Auto part to check the battery, the battery still check out good. What do you think next.?
  14. JC91006
    16,470
    8,383
    Did you replace the batteries in both your fobs? If yes, the batteries might not be good
  15. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Well, I thought the same thing, went out and buy a new one, cost me 4.99 form Target CR1632, guess what? no different. please keep it coming.
  16. JC91006
    16,470
    8,383
    The car receiving unit/antenna for the fob. But since it works and the range is shorter, you would have to somehow disturb that. And I don't know where that's located
  17. xliderider
    xliderider Senior Member
    7,849
    3,102
    Honolulu, HI
    That 14.2v your scangauge is measuring isn't the battery voltage, it's the operating voltage when the traction battery is online and supplying current to the 12v auxiliary battery.
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    xliderider
    ok, do you know where can I tell my battery volt when I look at my scangauge?
  19. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Press the bottom right button on the ScanGauge when the car has been shut down with everything off for a few hours. Enter through the right door so you won't start the brake pump doing its thing by entering the driver's door.
  20. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    CR94
    It had been almost 4 hours, just did what you recommend and the Scangauge showed 12.2V, is that good?
