Fog light installation documentation?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by burstaneurysm, Feb 20, 2014.
  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    So my parents lost the lower grille on their '07. Looking at replacement parts, getting the grille assembly plus a fog light kit is only 20 bucks more than getting the plain grille pieces.
    This is the kit they ordered:
    I noticed they don't come with any documentation. I'm wondering how similar the wiring is from 2nd gen to 3rd gen. I did the installation on my 2010 without issue, but I'm just wondering if anyone's done this install and if they've come across any documentation on wiring, etc.
  2. tf4624
    tf4624 Active Member
    526
    51
    you will have to get an updated stalk with the fog lamp switch or you can skip that and use the same stalk and hook them up to the wires that that go in the headlights. when you turn the stalk once.. the base lights come on (cornering) then turn it again for the 2nd click (that turns on the actual lights)
  3. dmf415
    dmf415 New Member
  4. burstaneurysm
    469
    144
    Chicago, IL
    Sweet. Thanks!
  5. dmf415
    dmf415 New Member
