found the Brake & the ABS lights on after picking up my car from being parked for 3 weeks
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Adiva45, Nov 26, 2014.
  1. Adiva45
    Adiva45 New Member
    houston, tx
    I parked my car (outside) and went on a business trip for three weeks. When I came back last week, when I turned the car on, the brake light and the ABS light were on. And it hasn't turned off since.
    The car was working fine and didn't show any sign of troubles prior to me parking it, no funky light was on.
    What do you think could be the cause? It wasn't driven during three weeks. What could have deteriorated to cause these lights to come on?
    The car seems to be braking fine.
    FYI, before getting to my car last week, after leaving parked for three weeks, I mistakenly pressed the Panic button. And I didn't realize that the Panic button got stuck and was continuously in circuit. And it stayed like this for an hour before I realized what happened and fixed it.
    Not that I think that it can have an influence on my current problem, but thought I would mention it anyway...
    So what do you reckon the problem could be?
    Side note, I also have had regular problems with this car. I had to change the axle at 20,000 miles, (yes! unheard of, right?), changed the computer's mother board etc... I have used my extended warranty at least three or four times so far, so nothing surprises me anymore.
    thank you so very much in advance, I am looking forward to hearing back from you. And a happy Thanksgiving to you all :)
  2. Patrick Wong
    18,200
    6,479
    1. I suggest that you fully-charge the 12V battery. You need to hook up a charger, 4A charging rate, and leave it overnight. Do not underestimate the time needed to charge the battery.
    2. Make the Prius READY and open the hood. Look at the inverter coolant reservoir and you should see turbulence in the fluid within. This shows the inverter coolant pump is running. The pump is located directly behind the driver's side headlight assembly. If you don't see turbulence, the pump has died and that is the root cause of your car's problems.
    3. After the battery has been charged and you have confirmed the inverter coolant pump is running, if the warning lights remain on, then you can either visit your local Toyota dealer for help, or else buy Mini VCI which runs on a Windows XP or Windows 7, 32 bit OS laptop to retrieve the diagnostic trouble codes. Those are needed to determine what is wrong with your braking system.
    49,796
    12 volt battery?
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    749
    Delaware
    if it was me, first I'd check the brake fluid level, top it off if needed. then pull codes. then I would disconnect the 12v battery for a couple minutes to see if the codes will clear.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    All of the above.
    How old is the 12 V battery ?
    If it is original, you are definitely due for a new one.
    If it is more than 4 years old.....probably.
    Then.....it is possible that a wheel speed sensor went bad while it was sitting there.......or a corroded connector for same finally failed.
  6. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    On a Gen2 sitting three weeks its a good idea to turn off the smart key system (button under the steering wheel). Otherwise the 12v battery can get drained that may cause funny things like you see. It's hard to re-charge the 12v battery driving locally as takes a long trip to really charge it back up. That's why you are getting some of the recommendations above re: 12v battery.
  7. 69shovlhed
    2,170
    749
    Delaware
    I've taken 2 trips to china for 3 weeks each time and never had a problem. but it could just be a weak battery, especially if its the original.
  8. SnowWhite45
    SnowWhite45 Junior Member
    Well, I just took my car to the dealership, and the diagnostic was low pressure in the break line on the rear right side.
    So they had to flush the brake lines and all of that ended up costing me $240! Urgh...
    A few months prior, I got brand-new brakes, I thought this would've been detected then. But what do I know about cars? :-D
    Sorry, seems like I have 2 different IDs... Same as Adiva45 above...
  9. bisco
    49,796
    oh! i was wondering. they probably did your discs and or drums, but not the brake fluid. your driving an 11 year old car with how many miles? you're going to have to start expecting stuff.:unsure:
  10. 69shovlhed
    2,170
    749
    Delaware
    you don't want 11 year old brake fluid in your car anyway. money well spent.
