Four wheel drive??
Discussion in 'Gen 4 Prius Main Forum' started by Carol DiPirro, Mar 23, 2015.
  1. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    AWD is coming because I asked for it.
  2. cmth
    cmth Active Member
    279
    142
    UK
    Agree totally. AWD will add a whole new customer base to Prius especially if they don't sacrifice other good traits and price.
  3. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Well, an AWD Prius might start off selling like hotcakes, but after one winter with the low ground clearance allowing the ice and snow on the road to tear out all underbody plastic, I don't think the enthusiasm would continue. I suspect the new Hybrid RAV4 will suffer from the same problem. Most car manufacturers have to lower their vehicles to improve mileage, and they have to improve mileage by Govt. mandate.
    Invest in the company making the underbody plastic bits!
  4. cmth
    cmth Active Member
    279
    142
    UK
    AWD means different things to different people. Compared to Gen 3, if Gen 4 gets AWD that will give an edge in wet cold weather handling on frozen and icy roads. Whether it has the ground clearance to go on deep snow is another issue.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Maybe. Often I have thought that 4WD/AWD really isn't a good thing for most average drivers.......when it starts to snow or ice over and the 4WD SUVs are the first ones to run off the road into the ditch..........because they can go faster but stopping really isn't any better.
    OVERCONFIDENT.
    drash likes this.
  6. drash
    drash Senior Member
    2,487
    1,258
    Upstate NY
    Even as much snow as we get from lake effect here, the roads are usually plowed. Not always clear, usually slush or ice is still on the road and this past winter a lot of incomplete thawing, but mostly plowed by the time I go to work. The AWD will help with ice and slush, particularly with uphill climbs and frozen over intersections. Since the cutoff speed for the rumored AWD is 35mph it won't be an issue with using it for higher speed driving. It'll help with low speed control more than anything.
  7. bigcwill
    bigcwill Junior Member
    56
    Nice work bro!
    krmcg likes this.
  8. Carol DiPirro
    Carol DiPirro Junior Member
    24
    47
    New Hampshire
    I'll be curious to see what they come out with. I emailed them years ago.
  9. bisco
    49,802
    there are detailed threads here, and independent testing videos.
  10. Tideland Prius
    16,207
    It was revealed at the LA Auto Show last month.
    alanclarkeau likes this.
