1. Offline
    clongwor New Member
    May 25, 2005
    61
    Acushnet, Mass.
    Your Vehicle Year:
    I don't remember noticing the last 2 winters, but this year whenever it gets frosty outside, there is also frost inside the windshield. This morning I had to scrape inside the car.
    Is this normal? There seems to always be a lot of fog in there too.
  2. Offline
    davidtm New Member
    Oct 28, 2007
    122
    TJ'ville
    Your Vehicle Year:
    I would recommend turning AC "on" in the Climate screen, as that will de-humidify the air inside the car, even when you're not running the defrost mode. Then, there won't be the moisture inside that will condense or freeze on the inside surface of the windows. The AC compressor will not run if the outside temp is too cold, so the hit on mpg won't be so bad.
  3. Offline
    seasalsa New Member
    Feb 29, 2004
    1,277
    Kent, WA
    Your Vehicle Year:
    It is normal if you have AC off. Hit the Auto/AC button on your wheel and it will take care of the frost as stated above.
  4. Online
    john1701a Prius Guru
    Jan 6, 2004
    5,521
    971
    Your Vehicle Year:
    Using RECIRCULATE allows for moisture build up.
    I never do in the during the cold season and have yet to ever see frost inside... here in Minnesota driving a Prius for 8 winters now.
  5. Offline
    clongwor New Member
    May 25, 2005
    61
    Acushnet, Mass.
    Your Vehicle Year:
    Thanks everyone!
    That's exactly the problem. I started shutting off the A/C and also started choosing RECIRCULATE in the mistaken belief that it would warm up the car faster than bringing air from the outside.
    Duh!
  6. Offline
    • Moderator
    May 11, 2004
    13,922
    1,217
    Far-North Chicagoland
    Your Vehicle Year:
    Well don't come down on yourself too much. The recirculate for warmer air was a good idea and you're right. Unfortunately, you simply failed to take into consideration the water vapor in your breath that is also recirculated.
    Live and learn and pass it on.
    Trust me, many of the tips most of us pass on were learned the hard way.
  7. Offline
    jsuh84 New Member
    Sep 30, 2007
    17
    Chicago
    Your Vehicle Year:
    It was freezing here in Chicago today and I had the same problem. What bothered me was that I just got my '08 Prius this past weekend, and already I couldn't believe a problem like this would occur.
    I'll be following the suggestions. Thanks.
  8. Offline
    smithBYU85 New Member
    Aug 7, 2007
    42
    Tualatin, OR
    Your Vehicle Year:
    I'm in Utah and I have the same problem. I started turning the A/C on to stop it. My problem is that I normally leave the heater off when I'm by myself to help out with my MPG, with a coat and gloves on I stay pretty comfortable.
  9. Offline
    David Beale New Member
    Jul 24, 2006
    3,460
    376
    Edmonton Alberta
    Your Vehicle Year:
    First, put the climate control system in "auto" mode.
    Then just go to the climate screen (press "climate") and select front defrost on the bottom of the screen buttons.
    Presto, the windshield is cleared in just 10-20 sec. If you leave it on it's a little noisy, but the windows will not fog up.
  10. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    17,759
    2,806
    Northern Michigan
    Your Vehicle Year:
    Just to add to the above posts, the climate control system on the Prius is fairly smart, and the A/C compressor is unlike that in most cars. The Prius will only run the compressor when it needs to, even when it is switched on, and the compressor is driven by a variable speed electric motor: If the climate control needs just a little bit of cooling or drying, it will run the compressor at a low power setting. It's not like the all-or-nothing clutch controlled compressors on normal cars.
    Tom
    1 people like this.
  11. Offline
    Stringmike New Member
    Sep 18, 2006
    76
    Move further south.
    Mike
    Scottsdale, Arizona
  12. Offline
    billarb New Member
    Jan 7, 2008
    114
    Long Island, NY
    Your Vehicle Year:
    I'm a new owner (~3 weeks) and noticed condensation on the inside of the windshield tonight coming home from work. I'm glad I read this string, because I now know to shut off the recirculate. All that said, I like Mike's solution better!!!
  13. Offline
    orracle Whaddaya mean "senior" member?
    May 24, 2007
    440
    Gurnee, IL
    Your Vehicle Year:
    Boy am I glad I found this thread! This morning at zero or near abouts, after I pulled out of the garage the inside frosted over so badly I had to scrape! I tried about everything including the previously mentioned wrong things to do. I just didn't believe the a/c button would take care of things.
  14. Offline
    jayman New Member
    Oct 21, 2004
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    As others have mentioned, it's really important to take all excess snow off your boots. The Prius uses partial recirc to save energy, not the best thing in bitter cold temps.
    Also make sure the air intake vents are clear. When the cabin fan is turned on, it can suck in snow
  15. Offline
    PrematurelyGray New Member
    Nov 29, 2007
    62
    Pittsburgh
    Your Vehicle Year:
    Jayman brings up a good point - you might have excess moisture (like snow on boots) that won't dissipate in these temps. My son spilled a bottle of water on the floor in December and didn't tell me. Still suffering from excess moisture and waiting for some 60 degree days to dry the car out.
  16. Offline
    NoMoShocks Electrical Engineer
    Jan 21, 2007
    1,274
    64
    Camas, WA
    Your Vehicle Year:
    Really! Has living in Scottsdale helped you to use your AC less all year long? Seriously though, I know it is a nice place.
    I found the suggestion to clear the intake vents good. I assume they are at the back of the hood just in front of the windshield wipers, so I will be doing that next time I get snow.
  17. Offline
    donee New Member
    Aug 15, 2005
    2,958
    183
    Chicagoland
    Your Vehicle Year:
    Well, that is an understatement. I put my car to bed wet from the warm damp drive home (40 F), only to wake it up in the morning at -2 F. And in the mean time there were winds gusting to 40 mph, and snow blowing into little tiny (6 inch) drifts, with bare pavement inbetween.
    There was also ice under snow where the snow melt water had not drained before the thermal shock hit. So, the traction control got a good workout. But I never got stuck.
    I had about 1/4 th of the inside of my windshield frosted, and all of the rear hatch window. I remember my Saturn SL2 frosting over the inside of the windshield on occaision, but not the rear window. I think they need to double up of the heater wires in the hatch window.
    It was sunny today, and its all gone now.
  18. Offline
    dustyhuskie Itchy Tomato
    Feb 24, 2008
    35
    Plainfield, IL
    Your Vehicle Year:
    Are there wires in the bottom hatch windows? I though maybe not as the window ice seems to melt very slowly if at all.
    I keep a scraper in the passenger seat. I get in the car with wet hair. Par for the course. First time it happened I didn't have a scraper and had to keep scratching patchs off the window to see the road.
    Detailing with steam cleaning the carpets/seats seems like it may be out of the question.
    With auto on the air will come on automatically in response to just humidity? I noticed that it was on even with the interior of the car was freezing and thought it was just another charming Prius glitch.
  19. Offline
    diamondlarry EPA MPG #'s killer
    May 20, 2007
    559
    Elkhart, IN
    Your Vehicle Year:
    I have had my windshield completely frosted over a few times this winter; had to use my ice scraper on the inside. I drive with the driver's window and the right rear passenger window cracked open about 1". I would think that any moisture from my breath would be sucked out of the car with the windows open.:confused: This is the first car I've ever owned that I've had this happen.:confused:
  20. Offline
    Mar 27, 2004
    7,385
    760
    United States
    Your Vehicle Year:
    With recirc on, the wet air from your boots doesn't get sucked out fast enough; it blows over the windshield first and the water condenses there. Consider it a testament to the air-tightness of the cabin. Turn on the defrost, make sure it's set to outside air and all should be well (except for sucking in exhaust from other vehicles...).
Share This Page
