Gas Gauge accuracy
Discussion in 'Prius c Main Forum' started by allopatry, Apr 19, 2012.
  1. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    The C does not have a bladder fuel tank.
    ztanos and Ryephile like this.
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
  3. Mike55
    Mike55 New Member
    I've had my 04 Prius for 9 months now, a couple of months ago the fuel gauge also started reading less than what was in the tank, about 3 bars less.
    I took it to the dealer today because of a recall on the steering shaft. I complained about the fuel gauge, the dealer said they reset the unit to read 1 bar down instead of 3. They told me that the fuel tank is actually a bladder instead of a solid tank & that it contracts in the winter, which may be part of the probem of false readings.
    You asked about the Prius c. I've read that 2010 & later priuses are being made with solid fuel tanks, which may avoid this problem.
  4. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    As has been noted in this thread - the Prius c does not have a bladder fuel tank.
  5. FosTexZ
    FosTexZ New Member
    the gauge isnt the problem. its the fuel sending unit.
  6. ThirdRonnie
    ThirdRonnie Junior Member
    Hobart, Tasmania, Australia
    I'm just astounded that after all these years, they still can't get them right!
  7. Ryephile
    418
    151
    24
    Metro Detroit
    They're not wrong unless you're misunderstanding their operation. The Prius C's gas tank is not unique or special. It's the same fundamental design as most other cars on the road. Also consider the gauge damping required to avoid wild fluctuations for every corner or bump you hit causing fuel slosh, and subsequent float movement.
  8. straw10
    straw10 New Member
    Wallingford, CT
    I had heard that about the bladder tank...learning as I go with my new purchase...
  9. blhvet
    blhvet New Member
    I'm a little confused with my gas gauge as well. In July, I left home and had about 65 km to go to get to the next gas station. My cruising range said 174 km, so I felt pretty comfortable. (I think there were 3 or 4 bars showing.). Anyway, about half way there, the cruising range started dropping dramatically and with about 20 km to go, it beeped and told me I had 0 km left. I limped into the gas station and there was less than a gallon left in the tank. It almost seems a little like my old Chev - the "top half" of the tank seems much larger than the "bottom half". Suffice to say that I fill up when I have 3 bars left. (I'm in a rural area so gas stations are about 30 miles apart.)
  10. bisco
    49,802
    the dte is an estimate based on past mpg averages. in no way should you use it to determine when to get gas. and btw, you do not have a bladder in the tank.
  11. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    What exactly do you mean by "limped" and how did you determine that there was less than a gallon left ??
    That one experience might not be typical but it's better not to wait that long anyway.
    How much do you put in at a "fillup" now ??
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    When the car beeps you still have ~1.0 - ~1.5 gallons of fuel left. Depending on how you drive this can get you anywhere you need to go, so you didn't actually limp.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Only the Gen 2 Prius Liftback has the bladder. There is a reason they got rid of it for Gen 3/PC/PV. It was awful.
  14. blhvet
    blhvet New Member
    Ok, so perhaps "panicked" would be a better term than limped. I mean that I turned off the AC, rolled up the windows, and slowed down to 90 king to try and get the best mileage I could. I know there was about a gallon left because of the amount it took to fill the tank. I really didn't think I'd be cutting it close by trying to drive 60 km when I had 3 bars left on the fuel gauge and I was driving a Prius c! A typical fill is around 30 L - my gauge is usually at 2 or 3 bars.
    ztanos likes this.
  15. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    I was wondering if there was something wrong with my gauge, but it looks like is a peculiarity of the type. I don't know if it is the bladder effect or not, but it looks like this: it take 80 to 100 miles to drop one bar, then the process accelerates to the point that nearby the middle to bars disappear every 20 miles or so. And the last two bars last way longer than the ones int he middle.
    I get gas anywhere between 300 to 360 miles traveled since the previous fill up, or 2 bars left.
  16. bisco
    49,802
    there's no bladder in the prius c. i think you can get the gauge adjusted, are you still under warranty?
  17. Dimitrij
    405
    202
    Virginia
    ^ Ah, good to know. Unless warranty for the gas gauge is 1,980 miles or 16 days, whichever occurs first, I should be covered :sneaky:
  18. Easy Rider 2
    1,584
    257
    Ocala, FL
    And what exactly makes you think that ?
    I think it is absolutely wrong.
  19. bisco
    49,802
    just what i recall from reading here in the past. your free to think what you want without fear of retribution.
  20. Oldwolf
    Oldwolf Prius Enthusiast
    820
    110
    NC
    2016 Prius v wagon
    There must be something wrong with your sending unit as you have suspected. Mine works fine, when the single bar starts flashing I have less than 1 gallon left. Usually by the time I find a station I have .8 gallons left in the tank. I find it worrisome to let it get that low so I usually refill at 2 or 3 bars.
