gas gauge down 4 bars after only 71 miles?!
Discussion in 'Gen 2 Prius Fuel Economy' started by prof.curnon, Nov 12, 2014.
  1. prof.curnon
    prof.curnon Junior Member
    portland, or
    hi everyone,
    I just bought my second gen 2007 prius a week and a half ago and it's been performing like a champ. however, I am a wee bit/a LOT freaked out that after only 71 miles the gas is down 4 bars!! now I know there's been much discussion about mpg's and the inaccuracy of the tank reader, but when I drove my new car home it was practically full (2 bar shy), and now it's at half a tank! should I call the repair shop asap??
  2. prof.curnon
    portland, or
    oops, that's *1* bar shy of full above
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Do you have an average mpg for those 71 miles?
  4. prof.curnon
    portland, or
    um, no. but at this rate, the tank will be empty after only 142 miles!
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    1) get gas when you have 2 pips left.
    2) join fuelly.com and start believing the numbers after three tanks. (never stress over any one tank)
    uart and prof.curnon like this.
  6. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I would go ahead and fill up, and reset the average mpg. When you go to fill up, open the gas cap and wait at least a minute before filling your "tank" (the 2004-2009 prius actually has a gas bladder) at the slowest fueling setting your pump offers. Hope this helps! Keeps us updated
    prof.curnon likes this.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    No reason to wait a minute to fuel up.
    OP:
    Fill up the tank
    Reset the trip meter so that you can follow MPG
    The tank reader is very non-linear, plus you do not know 'where' in each pip you are/were. This might be a total of just over one pip drop. If pips had decimals, you might have gone from 6.1 to 4.9
    Take it easy for now, and follow a tank from full.
  8. prof.curnon
    portland, or
    I haven't even looked at the trip meter yet; will do that post haste. it did occur to me that I was on the tail end of the 9th bar before it dropped down to 8, but it seemed to drop precipitously down to 6 practically overnight. most alarming!
    nothing in the maintenance records from the previous owner shows any problems with the gas gauge, so I do not know what is going on... since I drive so little, I was fully expecting the bars to stay at almost full for a good long while. how disappointing!!
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
    Try not to jump to conclusions.
    I was able to drive way close to 150 miles on the first pip (meaning full tank) in our Gen2, but then I would see a rapid fall in subsequent pips to for the next few. Simply a non-linear tank meter. You also might be seeing an effect of tank angle knowing Portland.
    Just fill a tank and follow along. Much to0 premature to be worried.
  10. prof.curnon
    portland, or
    aaron -- thanks for the suggestion to let the tank breathe first before filling up slowly... I'm in oregon, where filling up your own tank is outlawed, so I'll be sure to ask the attendant to do as you advise.
    does anyone know if there has been a fix for the inaccurate tank reader? considering all the technology in this car, one would think knowing how much gas one has in the tank would be anything *but* a guessing game!
    a
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    • 10 gallon tank
    • Accurate MPG meter
    • Accurate trip meter
    Result: anything but a guessing game, but you do have to be able to perform a division calculation. I hear calculators are pretty cheap these days if needed.
  12. prof.curnon
    portland, or
    yeah, I was expecting that "150 miles on one pip" phenomenon you are describing, hence the disappointment!
    by tank angle, do you mean climbing hills? cos I am way too poor to live (or traverse) the hills! pretty flat in the city where I am. :)
  13. prof.curnon
    portland, or
    sheesh, what's the point of having a gas gauge then if one has to do long division?!
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    NOT every pip -- just the first one from a full tank.
    If a linear meter drops one pip every 50 miles or so, but in actual practice the first pip lasts 150 miles, then in order to 'catch up' the next 3 pips will last 50 miles. <<shrug>>
    It is really not important, but if you are feeling obsessive then perform the calc.
  15. SageBrush
    11,627
    2,530
    Southwest Colorado
    So that you have an alert when to fill up.
    BELIEVE one or two pips as time to get fuel.
    Don't use 6,7 or 8 pips to accurately infer fuel left in the tank, and certainly do not try to estimate fuel economy from their transitions.
    When you read that the fuel meter is non-linear, that is what it means.
    #15 SageBrush, Nov 12, 2014
  16. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Watch "How To: Reset Gas Gauge in a Toyota Prius" on YouTube
    How To: Reset Gas Gauge in a Toyota Prius:
    you might want to go ahead and try this. If you're interested, this lady also has a great video on how to disable the annoying back up beep!
  17. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    What kind of driving are you doing? Short trips to the nearby grocery store? Go ahead and fill it up, note your mileage and start an accurate, new tank measurement. Who knows how close you were to being down two pips when you bought the car.
  18. prof.curnon
    portland, or
    thanks for the video, aaron. I thought resetting the trip odometer simply entailed double-clicking on the trip button?
    I kinda like the back up beep -- even though it's just inside the car, I like to think it's loud enough to alert passersby that the silent ninja car is about to roll over them! ;)
  19. prof.curnon
    portland, or
    yep, short trips to work (5 miles RT), to the market, and of course some freeway miles to the dealership to cancel the extended warranty. :)
    just read in another thread that short trips don't reap high mpg's cos it takes 5-10 min to warm up the engine. but then the same goes for ICE cars...
    kenoarto likes this.
  20. prof.curnon
    portland, or
    ok, sagebrush, I'll start thinking of the fuel meter as being QUANTUM... now if the pips go UP tomorrow, then I will *really* believe it's non-linear!
