1. Offline
    jdcollins5 Senior Member
    Start a Conversation
    Aug 30, 2009
    3,262
    645
    Wilmington, NC
    Your Vehicle Year:
    I have just recently installed a ScanGaugeII on my car and have been intrigued with the HSD and learning all that I can about this amazing vehicle.
    I have a 52 mile RT commute each day on a 55 mph speed limit highway and of course run on cruise control at 60 mph. I have noticed that the MG2 RPM = 7000 at 60 mph displayed. So I began to do some research here on PC to determine the gear ratios and the relationship between MG2 rpm and mph.
    I came across an earlier thread where there were discussion of the improvements of the Gen III over the II. I came across a post by HTMLSpinnr where he gives the gear tooth counts of the complete HSD system.
    I have taken those gear tooth counts and applied them to the MG2 RPM of 7000 to calculate MPH based on my tire rev/mile. I also found out that the max MG2 rpm = 13500. When using the gear ratios this works out to the Prius max speed of 113 mph.
    I thought that other newer PC members like me may be interested in these calculations. If anyone sees any errors in my calculations please let me know.
    3 people like this.
  2. Offline
    tumbleweed Senior Member
    Oct 3, 2005
    3,965
    615
    Eastern Oregon
    Your Vehicle Year:
    That explains why the top speed is electronically limited to 112.
    1 people like this.
  3. Offline
    vincent1449p Active Member
    May 24, 2004
    742
    230
    Singapore
    Your Vehicle Year:
    With the addition of SRU, the speed relationship for MG1, MG2 and Engine has to be updated.
    Equation 1:
    ws = ( 1 + R ) * wc - R * wr
    where
    ws = Angular speed of Sun gear = MG1 RPM * 2 Pi() / 60 rad/s
    wc = Angular speed of Pinion gear = Engine RPM * 2 Pi() / 60 rad/s
    wr = Angular speed of Ring gear = ( MG2 / S ) RPM * 2 Pi() / 60 rad/s
    R = Gear Ratio of PSD = 78 / 23 * 23 / 30 = 78 / 30
    S = Gear Ratio of SRU = 58 / 18 * 18 / 22 = 58 / 22
    Converting all rad/s to RPM and substitude into Equation 1,
    MG1 = ( 1 + R ) * Engine - R * MG2 / S
    MG1 = ( 1 + 78 / 30 ) * Engine - ( 78 / 30 ) * ( 22 / 58 ) * MG2
    MG1 = ( 30 + 78 ) / 30 * Engine - ( 13 / 5 ) * ( 11 / 29 ) * MG2
    MG1 = ( 18 / 5 ) * Engine - ( 143 / 145 ) * MG2
    MG2 = ( 145 / 143 ) * ( ( 18 / 5 ) * Engine - MG1 )
    Engine = ( 5 / 18 ) * ( MG1 + ( 143 / 145 ) * MG2 )
    Vincent
    4 people like this.
  4. Offline
    Aug 30, 2009
    3,262
    645
    Wilmington, NC
    Your Vehicle Year:
    Thanks Vincent
    Now does anyone know how to convert the Gen II HSD animated graphic with these numbers to make a new animated Gen III graphic ??
Share This Page
