Gen2 PHEV Kit with 32 nissan leaf battery cells, BMS2 or BMS+ opinions
Discussion in 'Prius PHEV Plug-In Modifications' started by glyndwr, May 17, 2015.
  1. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi all,
    I have recently purchased a nissan leaf battery pack from a salvage yard, and decided to upgrade my phev kit that was 76 off 33ah type 26650 cells. The kit is / was working well before, the leaf pack came along at a very reasonalbe price so decided to do the upgrade, and re use the original lifepo4 cells in a home energy recovery project for me and my brother, more on that later.
    ok, so, I installed 32 nissan leaf cells into the car as the pic will show, still leaving me 16 cells left over.
    Now, after one full charge / discharge cycle covered, batteried performed well, but something snt right with the kit in general.
    Before the battery swap, the PIS kit i have would sometimes drop out, without warning, this was especially troublesome in out of gas mode, as i had no notice the kit had recided to sop working, the prius battery woiuld go very quickly to blue bars, then again quickly to purple needing a fast stop, recycle and engine warm up to recover the prius battery voltage before the PIS kit could be re started.
    I have checked all the wiring, it all looks ok, but these episodes are getting more frequent.
    One thing that is true with the PIS kit that i hve whitnessed as a user is that is has a narrow voltage operating window, and too much sag will send the voltage low which in turn switches the kit off, meaning mote cells in series have to be added to get any meaningfull range within the voltage window of the batteries.
    So, with this in mind, and having a very good battery installed, i was thnking of taking the plunge and build a hybrid interface pcb designed by Norm, all the info is on here, i think its in my capabilities to take on the task.
    Any help with the setting up of the BMS2 after its build would be very helpful, or please share your settings on your set up with the dip switches, and what you have set your voltage window to would be a great help.
    With 32 leaf cells in series charged to 8.1v per cells gives 259v high voltge, too high in my opinion, but needed with the pis kit as the kit knocks off at about 230V is what i have whitnessed.
    with the BMS2 i could maybe drop to 30 cells with a max voltage of 243V.
    Please fell free to add your settings, opinions, it would be greatly appreciated.
    Thanks, Anthony.
  2. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Update for you.
    Checked wiring again, and found that the cat5 cable going into the rear pcb connection although was in all the way and could here the click on the connection during the push in phase, the connection wasn't being made properly.
    Fortunately, the "bad" connection on the cable end was on a short extension cable, changed that cable, and the kit is now working as normal, haven't suffered any drop outs for the last few days and have gone through numerous full charge / discharge cycles.
    Hopefully this has solved the drop out issues.
    I'll report back if the problem re occurs.
    Anthony.
    hill, RonMc5, mrbigh and 1 other person like this.
  3. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Anthony
    30 cells is a very good idea because bms+ reduce ccl (charging limit) very quickly over 240v. With ccl=0 there is no regen.
    It could be interesting at the begining of your trip to avoid regen so your Leaf cells will not be overcharged.
    Using 8.1 volts, so 4.05v each cell will increase your cells life. Usually they can be charged up to 4.2 volts.
    What will be the lower cell voltage ?
    Knowing these two limits will give you the usable capacity.
    In my prius (that have bms+) I use the range 240-210v when the max range is needed.
    If you use 210v then each cell will be at 3.5 volts. If you start from 4.2v you have 27.4 Ah usable. So less when starting from 4.05v.
    What are the max charge amperage when they are cold ?
    (y)
  4. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi planitaire,
    My charge profile is charge to 4.05v and discharge to 3.6v.
    In the short time the cells have been is and used, they don't bounce as much as lifepo4, like, after the charge cut off, the settle very near to the charger trip set point, my older lifepo4 would shut off at 3.5v and settle at around 3.33v, I'm not seeing this with these leaf cells,
    Similarly, when at the lower limit, with the lifepo4 I would dip below my 2.8v Lower limit under load, and the cells would bounce back to around 3.15, close to empty,
    With the leaf cells they tend to stay quite stable at the voltage being displayed, if that makes any sense at all.
    As for charge max when cold, I'm not sure on that level to be honest, I figured, if these cells can power an 80 kW leaf motor with regen, then it should have no trouble at all powering my gen2 Prius motor which is about 65% lower in power, so I think they should be ok in whatever I put them through, hopefully anyway.
    I would say with the charge settings I am using I'm probable using around 70% of the cells capacity, maybe alittle less.
    I'll run in this state for a while whilst I get used to using the cells and seeing their characteristics under various driving and environmental conditions.
    Cheers for the input, best regards, Anthony.
  5. jimgood
    jimgood New Member
    perm
    Hi glyndwr.
    Did you manage to make a battery from Nissan Leaf with prius gen2?
  6. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    I had a 3rd party kit that added a third battery to charge plugged in. He replaced that battery wit the Leaf battery cells.
    He still as the regular Toyota 12 Volt & traction batteries also.
  7. jimgood
    jimgood New Member
    perm
    If I correctly understood, then the battery from LEAF is better not to put?
  8. stephenjo
    stephenjo Junior Member
    Auckland
    2003 Prius
    sounds like a great idea to me, my EV mate is using Leaf cells. does anyone have a build thread or more information? Im still trying to get my head around it. I now own a Gen II and Leaf cell additions are on the cards :)
  9. bisco
    49,019
    search around, i believe there are quite a few threads, a bit old, but possibly relevant. with the advent of pip in 2012, kits and diy fell off the map.
  10. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    yes did that and ir run very well to be honest.
    Sorry for the very late reply.
  11. whereswally606
    whereswally606 Junior Member
    uk
    Hey Glyndwr,
    Sorry to dredge up an old thread. just sold my Honda insight mk1 and have ambition to but a 2004-2008 prius and do a similar conversion. You used a PIS kit? where did you get it, can it still be got.
    I think I will have to build the bms2 kit and got that way and ive already reverse engineer'd the old expresspcb project so I could use pcbway (other pcb houses are available).
    Thinking of doing a colourCG maximite canview as I can really find an old original Norm Dick Kit.
    Anyway you are relatively close (based in the UK) and if you wouldn't mind a call sometime so I can clarify the ideas in my own head that would be appreciated.
  12. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi buddy,
    Ive still got the prius, but removed the kit. Only removed as ive got a fill EV now, a nissan e-NV200.
    Ive also still got the kit here, all complete, and the batteries, have part reconfigured the batteries to make a home energy store to work with our solar panels, but that project is still work in progress.
    Where you located, im in south wales, a town called Aberdare.
