Gen2 Prius: Custom PIDs for Torque (Android App) with formulas
Discussion in 'Gen 2 Prius Technical Discussion' started by usbseawolf2000, Jun 24, 2011.
  1. justjeff
    justjeff Junior Member
    55
    Colorado
    So I have added the oil temp but dont get a reading. IS this info not available from the prius? Isnt there a sensor for oil temp installed in the prius? If not, has anyone added one? Where?
  2. Daved33
    Daved33 New Member
    France
    Just wanted to thank everyone who contributed here and elsewhere. Very nice project and it works great.
    I got myself a KiWi BT adapter and use my Android phone (Galaxy SII) to display information (I am still new to it and trying to find the best information to display).
    I noticed the Metric CSV file does not include as much information as the US version (137 for the US, 124 for the Metric). It is missing interesting stuff like MG1 or MG2 Power. Am I missing something (I used the zip file linked in the first post of this topic)? Did the Metric version lag behind and has not been updated? If that's the case I can probably try to fix it.
    Thanks again
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,995
    Fort Lee, NJ
    MG1 and MG2 power are mechanical (not electrical). I just did (torque x rpm) / 5050 to get hp. You can derive the power in Metric anyway you like.
  4. ehybrid
    ehybrid Junior Member
    17
    Melbourne, Australia
    Firstly, I've attached my modifications to the metric file. Changelog below:
    Changed:-
    All degree's F units into degrees C
    added:-
    HV Battery Power Resource
    Injection period of the No. 1 cylinder
    ICE Actual Torque
    MG1 Power
    MG2 Power
    Brake - Friction Pad Torque
    Brake - Hydraulic force
    Brake - Master Cylinder Torque
    Brake - Regenerative Torque
    (my memory is vague, there was some discussion about how these brake torque PID's worked, but I can't seem to find the thread. I've done a straight units conversion and copied across to metric in the meantime)
    US has the following in metric also (could be deleted, but you're not missing out in metric)
    MG1 Torque (lbs-ft)
    MG2 Torque (lbs-ft)
    ICE Power Request (hp)
    For discussion
    I think the "combined power" is nonsense ... it's simply adding mg1 + mg2 + engine power request.... which is utterly naieve about how power flows in the transmission. So I've left it gone from metric. I think it should be gone from imperial too.
    there are 2 HV battery power.... one on pid 21c3 and one on 21ce ....
    hv battery power on 21c3 seems simpler equation however unsure of units, the /1013 doesn't seem quite right from a 'round number' perspective, but it's what my math gives from the old forumla. My derivation assumes we're talking straight volts * amps "power resource" (I've renamed this "battery power resource" to reflect the PID's it comes from) and assumed the /1013 should be /1000 for a straight units conversion from watts to kw.) Perhaps this needs clarification/explanation from someone in the know?
  5. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Having a little tricky time with my Galaxy Nexus. Doesn't seem that installing Torque created the .torque directory in /mnt/sdcard. I tried to create the directory in Astro, but it won't let me use the . in front of it. Windows won't see the torquelogs directory, and a few other directories, and also will not let me create a directory with a leading .
    Maybe I need to fire up a Linux VM and see if I can see it. :)
    FIXED.
    Apparently Astro is stupid. I downloaded another file manager app, and the .torque directory was there and I was able to get the extended PIDs to work!
  6. Frayadjacent
    375
    Austin, TX
    Question, why does the HV SOC PID go from 0 to 160?
  7. Flying White Dutchman
    4,374
    313
    Wy is the soc 21ce for the SOC where i read it is 3cb?
    Is it also possible to send messages on canbus with the latest app?
    Like to send to my bms+
    Verstuurd van mijn HTC Desire met Tapatalk
  8. Flying White Dutchman
    4,374
    313
    one of the latest versions of this app got a raw data send CMND button
    i have tried to send 556 2D D2 00 and 5562DD200 and just 2DD200
    but no luck...
    i am correct that the bms response with a message on 555 not on 556? right?
  9. Frayadjacent
    375
    Austin, TX
    Funny thing... My Galaxy Nexus when running Torque, plugged in to power... still loses battery! LOL.
    Guess it's sucking a lot of juice to run the app, with GPS and BT communications going. Might need to check my USB adapter, it may only be putting out 1A. A 1.5A charger may work better.
  10. Верховный Ктулх
    Привет из Раши! Попробовал твою сборку из PID. Вобщем в ней нашел только длинну импульса на 1 цилиндре. а в остальном даже хуже чем то, что в шапке, половина датчиков просо не работает!
  11. Gaylon Whitman
    Gaylon Whitman Junior Member
    This sounds great, just got the Torque app, can't seem to download the csv file, any suggestions?
  12. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    What happens when you click on the link to start the download?
  13. ehybrid
    17
    Has anyone elses HV battery PID's stopped working with the latest torque update?
  14. usbseawolf2000
    14,487
    2,995
    Fort Lee, NJ
    I have not upgraded yet. Now wondering if I should. Hahaha.
  15. mrbigh
    3,686
    699
    Long Island, NY
    I though I was driving nuts; now that you ask I'm tying the two ends together.
    Me (2), neither of my 8 HY batt pid'd are operational.......
  16. mrbigh
    3,686
    699
    Long Island, NY
    Always you can revert back to the previous version, I think?........
  17. KK6PD
    4,003
    944
    118
    Gee, and I was getting "torqued" at my tablets inability to suddenly access the Android Market. I am now glad it's like that, I will stay with the version that seems to work so well! I would think if you have an old phone backup with the previous version, erase the current version on the phone, and load that old backup, you should have the good old Torque.
  18. ehybrid
    17
    I don't think it's possible to go back to an old version unless you can find someone to download the older versions APK from...?
  19. KK6PD
    4,003
    944
    118
    I was thinking if you had backed your device when it had the previous version of Torque. You could get back to the point Torque was working fine, but you would have to up date possibly other apps.
  20. Bruncher
    Bruncher New Member
    Hello
    I can not download the csv file, when I click on the link, but not to download a referral on the first page in the forum.
    thank you for your help
