1. Offline
    KK6PD _ . _ . / _ _ . _
    Start a Conversation
    Mar 24, 2008
    3,573
    611
    Los Angeles
    Your Vehicle Year:
    Because of the transition to the new server, the links for the files need to be reset to point to the new URL address edited into the OP!
    I need to do the same thing with several of my heavy pictorial posts!
  2. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    I can't edit my post #1 to reupload and relink. I'll contact a mod to see if they can resolve it.
    KK6PD likes this.
  3. Offline
    danl New Member
    Jan 26, 2009
    231
    Boston, MA
    Your Vehicle Year:
    I just got an Elm 327 BT adapter recently, but couldn't seem to download the files from the first post. Please relink!
  4. Offline
    Yeti_Bob New Member
    Aug 19, 2012
    Your Vehicle Year:
    USB, Any chance you can link the csv files to a new post until the mod can fix links?
    thanks
  5. Offline
    dhanson865 Expert and Devil's advocate
    May 24, 2011
    477
    62
    TN, USA
    Your Vehicle Year:
    My android phone only has a mini (or is it micro) USB connector, I'm assuming I'd need a usb A/A gender changer to get the Scantool.net OBDLink to connect to a USB data cable that goes to the phone. I'm assuming that doing so wont exceed the length limit and degrade the signal.
    Come to think of it I don't have a data cable for the phone either so I'll need both the cable and adapter or two cables as I'll want to be able to use the standard data cable to link the phone to a desktop PC as well.
  6. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    I am attaching the most recent file I have on my hard drive.
  7. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    Make sure your phone supports USB host. Otherwise, it won't work. You may have to go with Bluetooth or Wifi OBDII wireless adapters.
  8. Offline
    planetaire Plug in 9 kWh 85 km/h or 100km range
    Aug 11, 2009
    159
    107
    France
    Your Vehicle Year:
  9. Offline
    Nexus1980 Junior Member
    Mar 18, 2012
    Antwerp
    Your Vehicle Year:
    Hi Usb,
    i don't understand something (and i was hoping you could help...) i saw a few threads back that you mentioned that the ELM327 doesn't work with a Gen 2 Prius. but i see a lot of youtube clips where people show it clearly works. Can you help me telling what precisely doesn't work with the ELM327?
    Thank you!
  10. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    I had early ELM327 clone one and hybrid specific PIDs (anything on CAN bus) didn't work. Perhaps the clones have improved. I have seen many reported here with success.
  11. Offline
    Jaquimo Paraglider, Prius glider...
    Jan 22, 2011
    93
    27
    Bloemfontein, South Africa
    Your Vehicle Year:
    I also bought an ELM237 clone and had lots of intermittent and inconsistent operation problems until I fixed the pins of the connector with super-glue. The pins pushed back when the connector was plugged in and did not make contact properly. Since I have not had any problems.
  12. Offline
    Justdidit LVNPZEV
    Jun 12, 2012
    797
    133
    San Diego
    Your Vehicle Year:
    I'm Using the ELM and Torque..
    This was posted by 'JimboPalmer'
    I haven't quite figured out my Torque apps ability for logging. How can I log this? I only see two options for logging, scatter chart like the one below makes it really hard to follow and the line chart only lets u track one thing. I'd like to show MPH, Ambiant Air Temp as well as Intake Temp. Any help would be appreciated.
    [IMG]
    I currently THINK i have the latest PIDs from USBSEAWOLF2000
  13. Offline
    NortTexSalv04Prius Active Member
    Nov 14, 2009
    540
    44
    Your Vehicle Year:
    Hello
    I am considering going the Android /Torque path for HV display data..... I have seen other threads with scangauge(have but do not like the limit of screen data display) and other alternatives. I do not know /understand software code so will LCD,arduino, shields is like tryin to reinvent wheel 4 me.... To do Android Torque from scratch/start what do I need to get going.... Gen2
    Hardware/software (torque app)
    will this work for display New 7" VIA8850 Mini Notebook Netbook Android 4 0 1 2GHz 1GB 4GB Camera Black | eBay
  14. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    It should work as long as it can access Google Play to purchase Torque app. I don't see bluetooth on it so you need to get an OBDII device that is either USB or Wifi.
  15. Offline
    glyndwr Junior Member
    Jan 30, 2012
    56
    South Wales, UK
    Your Vehicle Year:
    Hi all,
    i have just installed the seawolf file into the torque app and tried out a few dials,mg1 and mg2 etc work fine,
    a query though, is there anything for the gen 2 prius torque app that can monitor the hv cell voltage, individual cell voltages, and hv pack amps.
    Thank you. Anthont
  16. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    Yes, they are in there as well.
  17. Offline
    Jan 30, 2012
    56
    South Wales, UK
    Your Vehicle Year:
    Hi usbseawolf,
    I have looked through the list of dials to add and i cannot find anbything in there that relates to the hv pack.
    Can you shed any light as to what the dials are called please. I can then search again through the list to see if they are there on the downoad list that i have installed.
    Many thanks< Anthomy.
  18. Offline
    Sep 6, 2005
    1,850
    280
    N.Babylon, Long Island, NY
    Your Vehicle Year:
    I would go for a 7" or 8" Android based tablet like this one.
  19. Offline
    Nov 14, 2009
    540
    44
    Your Vehicle Year:
    Yea I may go with touchscreen tablet possibly as well . Besides the tablet and torque app what do you need to set up .....
    I want more than just rpm,fwt, aux batt vltge, so what else hardware and software are pchat Gen2 users going with....
  20. Offline
    Sep 22, 2004
    11,328
    1,766
    Queens, NY
    Your Vehicle Year:
    Name / Short Name
    "HV Battery Current","HV Current"
    "HV Battery Block-01 Voltage","HV Block1"
    "HV Battery Block-02 Voltage","HV Block2"
    "HV Battery Block-03 Voltage","HV Block3"
    "HV Battery Block-04 Voltage","HV Block4"
    "HV Battery Block-05 Voltage","HV Block5"
    "HV Battery Block-06 Voltage","HV Block6"
    "HV Battery Block-07 Voltage","HV Block7"
    "HV Battery Block-08 Voltage","HV Block8"
    "HV Battery Block-09 Voltage","HV Block9"
    "HV Battery Block-10 Voltage","HV Block10"
    "HV Battery Block-11 Voltage","HV Block11"
    "HV Battery Block-12 Voltage","HV Block12"
    "HV Battery Block-13 Voltage","HV Block13"
    "HV Battery Block-14 Voltage","HV Block14"
    glyndwr likes this.
Share This Page
