Green car symbol in 5 minute consumption intervals....
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Sep 4, 2015.
  1. douglasjre
    douglasjre Senior Member
    1,774
    617
    Orlando, FL
    ....,no longer appears since I changed my 12v battery. What did I do?
  2. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    Is it gone completely? or it is showing 1 min consumption instead. Some of the settings get reset when you disconnect the 12V battery, I guess the 5 min consumption is one of them.
    48,999
    check your 12v health and the connections, including ground to chassis.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    IIRC the green cars only show up on the 1 min display for the 2010, not the 5 min display.
  5. douglasjre
    1,774
    617
    Orlando, FL
    It's gone completely. I'm not sure if it's one minute intervals now. How do I switch it back?
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    On the Gen 3 you hold the steering wheel Display button.
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    You're not Regening enough to register green car. Switch to 1 minute interval. You can see the green cars easier.
