Hatchback leak from heavy rain
Discussion in 'Gen 2 Prius Main Forum' started by tom1l21, Aug 7, 2009.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I notice that when it rains very heavily, right above the back left passengers seatbelt, water will leak from the hatch/ceiling area. The leak originates right where the ceiling meets the plastic covering on the hatch. Has anyone experienced this before and what would you suggest doing? I noticed that there could be a small leak around the rubber seal when opening the hatch. If so, what would you suggest to seal it off? It makes the car smell when it rains and then the sun comes out and makes my prius feel like a sauna.
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    ASAP either repair or replace the hatch seal. It won't be inexpensive, but it will be worth it. Water inside a car is not good, water inside a Prius is "-a bad thing-" (tm). You could try silicone spray if the rubber is just a little dry and stiff, but usually it's damaged and has to be replaced.
    Don't put off repairing it. If the water gets into the electronics it will cost -a lot- more. For example, the traction battery is right below that leak! Water and electricity aren't a good combination!
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I pulled away the rubber seal a bit on the corner bend and noticed that there is a tiny crevice that is visible. I think I might get a dab of great stuff on there or something like that. I don't think the rubber is damaged as it looks great and not weather rotted. I'll do some work on it and come back after the next rain. The leak is not major at all, so I wouldn't be too worried about the battery as it leaks only in the side of the seat (not that much), but still, I do want to be careful. Thanks for the info, I'll report back!
  4. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    My 2005 hatch started really sticking some when I would open it. I figured I might have to replace it eventually so I traded it instead!
  5. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    When you say sticking, what do you mean by that? My hatchback won't automatically pull up when I open it. What happens is once I pull it open about parallel with the ground, it will just stay there and not pull itself up, but will not fall either. A little push and it will finally go up by itself. Is this what you are talking about?
  6. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I think it would have been cheaper to fix the sticking!!! :D
  7. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Found the problem! When it rained, I noticed the dripping and pulled the interior roof away. Found the trail of water which led to the black rubber gromet that I believe holds the wires and windshield fluid for the back hatch. There's two of them. Gonna put some rubber cement on it and that should fix the problem!
  8. debberoo
    debberoo Junior Member
    Charlotte, NC
  9. jawshoeaw
    jawshoeaw Junior Member
    67
    Oregon
    Just did the same thing but I have more than one leak. That one was the worst however. If you pull the rubber grommet back from the car side (not the upper side attached to hatchback) the sheet metal there is very thin and easily distorted. Mine had like little ripples . I tried to straighten it but I added a bunch of sealant around it to just to be sure. That might explain the leak on the passenger side leading to the 12v battery but not the driver's side. I think it's coming from the welded seam that the hatch seal clips onto. I found several small gaps in the seam, although I didn't see how water would find its way in since the seal is there. On further inspection however I noticed that water wicks its way up the underside of the seal via capillary action presumably. It might not seem like much (no pun intended) but over several feet of seal, quite a bit of water can wick up, especially once dirt and grime has accumulated. Needless to say I wiped it off with alcohol and applied more silicon goop in various areas. Haven't looked at taillight lenses yet.
    For sure the two vents are also a potential leak spot. Both of mine don't look like they are very well sealed as they are only held on by clips and the sheet metal (again very thin) looks a little rippled.
    Can you tell this was a salvaged car? Well, I got it for about half price and it's a package 6 gen ii so I can't complain.
    FWIW, the traction batteries (all six of them :) ) are fairly tolerant of moisture. I actually had water spill all over one of them once (don't ask) and it was fine. If you think about where the nominal 208v is developed, it's only at one spot, where the battery connects either to the big contactors or in my case in a couple of junction spots and Anderson connectors. I disassembled one of the batteries that had been sitting in the spare tire well which had a lot of water accumulated. There was no corrosion on any of the battery posts, interconnects, etc.
  10. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    A leaky seal was your motivation to trade up to the 2010? Man, you were READY, huh (grin)?
  11. SilverPrius05
    SilverPrius05 New Member
    So did you get your leaks fixed? Any advice for us as we have a similar leak on an 05 Prius that just started. Back door gasket looks fine and not dry rotted or cracked upon examination? Leak seems to be around back door, though. Water is running inside the ceiling and running out onto the left side of the back seat, just over the seatbelt - right next to the window.
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  13. Grubbbb
    Grubbbb Junior Member
    Rockville, Maryland
    The 2nd picture in "a wimpy diyer" photo above is exactly where i had water leaking into right passenger side rear battery area and accumulating in the battery area and spare tire area. It was a small crack exactly where the red circle is in above picture. To test, i out a piece of duct tape to cover and no more leaking. I am going to fins something more permanent later today. Thanks for the image ( i have a 2005 prius).
  14. waynethexplorer
    waynethexplorer Junior Member
    Alabama
    I had a leak on my 08, best I could tell it was leaking at the upper left section of the rear hatch. When raised up there were what looked like very small cracks to the left area of the hinge. I just cleaned the area and spread a thin coat of silicone rubber around the area. It was leak g all the way to the rear small storage compartment before but after the fix it stopped.
  15. RMK
    RMK New Member
    Dacula, GA
    I have been puzzled and frustrated with a water leak in my 2004 Prius to date until I read some of the other comments and suggestions in this forum. A few years ago I took my Prius to a local dealer in the Atlanta area to try to fix this problem. After they evaluated it they told me they located the problem and the fix was to replace the gasket seal in the hatch lid for a small fee of $300. Not knowing all the issues other people were having at the same time with this problem I chose to have the gasket replaced. I did not see any leaks for a while until a later date when I was installing a backup camera and needed to access the well under the left storage compartment to run a wire under the foldable cover. There is small a amount of water just sitting there in a crease. Luckily I only saw a very small amount of water in this area so I accepted it as a minor issue. That is until recently that I wanted to explore that area to locate the true cause of the problem. To my surprise when I felt further up from that well to the insulation/noise reduction material above the tire area, the entire piece of insulation was soaked with water. I immediately took the left side interior off and removed it with that material to allow it to dry. I then tried hosing that general area of the car, with the hatch closed of course, to try to locate the true cause of the leak. I thought to myself that it must be coming from a seal that may have become brittle. The only seals on the side of my Prius are for filling the gas tank and the small triangular shaped window. I hosed those areas separately to no effect. I did try hosing the roof then shutting off the hose but did not see any water leak(s). That is when I decided to check the Web to see if anyone else is having this problem. To my amazement, I could not believe how many people have located small cracks in the rear water channel areas of the car as the culprit of this problem. So I tried an experiment by first allowing water to only run down the channel. This confirmed that water started to leak into that well from the same area inside the car's interior molding above the well. I then placed some electrical tape over the areas with cracks after allowing that area to dry followed by watering the channel once again. Surprise ... no leaks! For now I'm going to leave the electrical tape over that area for the very short term to fully convince myself that I have found the source of the leak. I will later apply a filler such as silicone and/or flowable windshield silicone over that area to more permanently fix the problem. Since this seems to be a repetitious issue related to the vehicle's structural integrity, I would hope that Toyota would step up to the plate and remedy this matter; if not, then legal action such as a class action be taken against Toyota for such a defect.
    For purposes of illustration, I took some photos of the cracks in my 2004 Prius:
    3 views of Cracks are shown located on the driver side water drain channel at rear of the roof and under the top of the hatchback; suspect cause of leak in 2004 Toyota Prius:
    upload_2018-6-17_14-2-17.jpeg upload_2018-6-17_14-2-18.jpeg upload_2018-6-17_14-2-17.jpeg
    John Daly and SFO like this.
  16. John Daly
    John Daly Junior Member
    02043-2523 Hingham, United States of America
    Thanks RMK for your post. I am finding the same problem in my 2009 Prius. For me you honed in on just the source of the leak and helped a lot.
    We had been getting water in the spare tire area and then this winter Toyota told us the battery froze up as it was surrounded by a frozen block of ice. They said "keep an eye on it." Not helpful.
    Got worse and finally after 3 days of rain and a soaked car we had to dig in and find it..
    After quite a lot of looking we decided we needed to take out all the rear trim. Not simple:
    Checked all the usual places and nothing seemed to show. Then following your lead we tried using a pitcher of water running water down the drain gutter. If we ran the water from hinge of hatch or lower, no leaking occurred. If we ran it from higher up the rain gutter, like over the rear door entry as shown here it leaked.
    Upon deeper investigation, we think we found the spot, the same type of seam crack under the mastic on the rain gutter down near the hatch.
    It may be there and elsewhere so I applied silicone to the seams of both left and right rain gutters from rear door back to below the clip for plastic.
    We shall see. I agree with the disappointment about Toyota. We expect to run these cars over 200,000 miles and over 10 years. That's why Toyota commands top dollars. At least the dealers need to be aware of this.
    THanks very much for the time and effort you took to share this with us.
    PS. I tried Toyota's TIS Site and a two day rental of repair manual to learn how to remove the trim.
    Very glad I did that.
  17. John Daly
    update 4/20/2020 - unfortunately water is still collecting!!
    A bit frustrating.
    Back to the "sealing" board.
  18. bisco
    49,813
    sorry to hear it. check the hatch hinge points too.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    The 12 bolt battery well is full of water too. There’s a rubber plug in the floor of the battery well you can remove but Many posters also report bad mouse infestation. So not sure if your area has that. Your car probably smells funky which attracts critters.
    Remove the cabin filter behind the glove compartment and check the filter for mouse houses.
    Pop open the engine air filter cover latches And look inside that air cleaner box for mouse house.
    Best to just drill a Small weep hole in the 12 volt well rubber plug and the one under the spare tire if car lives outside. If you remove plug s mouse can just jump in. Be aware on g2 s with bad leaks the water will sometimes get under the passenger side carpet also so check if there soaked or stinky.
    It sucks my car leaks too but it’s garaged. There’s a lot of flex in the roof to quarter panel area and it doesn’t help if you slam the rear hatch without opening a door to vent it. It already has little vents but you have to kinda slam the hatch. That’s tough on the corner welds in the upper hatch corners where they leak there and continue up the roof valley.
  20. Georgios
    Georgios Member
    126
    85
    Chicago
    The water leak problem is one of the easiest to fix. Takes no tools or parts most of the times. Go under the car and remove both small rubber plugs and you are done. If water is in the middle remove and put back the big rubber plug. I drive my car without plugs since then and the car sits only outside winter and summer. No issues. When it leaks from somewhere it goes directly out.
    If its huge leak from somewhere else then seal it but for this you dont have to do noting
