hello
Discussion in 'Gen 2 Prius Main Forum' started by milad, Feb 8, 2016.
  1. milad
    milad New Member
    san jose
    I have a Prius 2007 , my maintainance light turn on , and I changed my oil . After that I reset my mailage as it is written on the manual but still the light is on . Can it cause the dangerous problem to my engine , thanks.
  2. jjmerp
    jjmerp Junior Member
    49
    22
    Ohio
    Did you see the 6 dashes count down to zero ?
  3. Dion Kraft
    Dion Kraft Member
    272
    79
    Washington, UT
    Courtesy of FBEAR
    You could also try reading the fm. All the information you need to reset the maintenance light is in there.
    Try doing this:
    Press start button until car turns the ignition on
    Make sure the odometer displays "ODO" NOT TRIP
    Press and hold the ODO trip reset button in
    press start button until car turns off
    press start button until car turns back to ON
    Hold the ODO button in until all the flashing lines on the odometer go away and the mileage returns and the maint reset light stops flashing
    Your'e done.
  4. milad
    milad New Member
    san jose
    I did it , but it doesn't work .
  5. milad
    milad New Member
    san jose
    I did all these steps but It doesn't work.
  6. bisco
    48,996
    maintenance light, or maintenance required message?
  7. jjmerp
    49
    22
    Ohio
    This video shows how to reset
  8. milad
    milad New Member
    san jose
    Maintainance required
  9. milad
    milad New Member
    san jose
    I did it but I doesn't work again
  10. bisco
    48,996
    i can only think you're not doing it right, unless something is broken.
    it's not the maintenance reminder you can program into the mfd, is it?
  11. milad
    milad New Member
    san jose
    No I dont think so .
  12. Patrick Wong
    18,199
    6,464
    No, if the newly changed engine oil is at a correct level on the dipstick then there is no danger. However you should eventually figure out why it is that you cannot reset the MAINT REQD odometer timer. Perhaps you will need to ask a local dealer's service dept for help.
    If a warning light is on other than MAINT REQD, then take a sharp photo of it and post.
  13. milad
    milad New Member
    san jose
    Thank
    Thank you
