help car wont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ru5real, Dec 1, 2015.
  1. ru5real
    ru5real Junior Member
    42
    I'm assuming it is the battery eventhough i didnt leave anything on. I can unlock all doors with the fob, except the trunk won't unlock. When i try to start the car, the dash lights up, but doesn't go into "ready ok" and there a single click sound coming from the back
    49,114
    probably right, how old is it? cold weather can cause a weak battery to stop working properly.
  3. ru5real
    42
    It was the 12v battery. so how do i ensure that the battery becomes fully charged if the engine doesnt run the alternator all the time?
    49,114
    when you buy a new battery, you should put a volt meter on it before installing. if it's below 12.5 or 6, you should put a trickle charger on it. a new battery will read 13+ volts.
    ru5real likes this.
  5. ru5real
    42
    Ok, Thank you.
