1. Offline
    Start a Conversation
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    Howdy gadget-lovers!
    I have several "standard" ice chests (and a powered one or two as well). What I don't have is a really well insulated ice chest that has high-tech insulation instead of just super-thick walls like you find in the current bunch of "extreme" coolers from all the major makers. There are many ways of insulating - and the cheapest way is to just use more of the same - thus the "extreme" coolers that have super-thick walls. The problem, of course, is that we all have limited storage space, and I want something that insulates as well as these thick-walled coolers - but without the extra bulk. For the ouside dimensions of these things, they sure don't fit much inside!
    I'm looking for something that is roughly 12" x 24" inside. Just to give an idea of the size I'm interested in. I don't mind paying a bunch of money for something that is durable and really well insulated. I'm tired of packing stuff in ice, and needing new ice the next day!
    For bonus points, I'd love to find a powered cooler that is totally quiet!
    Thanks guys... looking forward to the replies!
  2. Offline
    phumpher um...oh...uh...wa...er
    Jan 17, 2006
    44
    where gold was discovered
    Your Vehicle Year:
    Hi Darell,
    Check these;
    Yeti
    Icee
    Frigid
    Ultra
    Hope one of them will work for you.
    We use the Icee's for river trips, with diligent management we have ice for our drinks on day 10 in the Grand Canyon.
    Would like to move to Yeti's as I think they are nicer, but it's a lot to spend for a small gain.
    Have seen, but never used the Frigid's and the Ultra's.
    Don't think I would buy the Ultra's, they look a lot like Yeti's old design.
    I would consider the Frigid's if I could get them for a good price, but it's hard to beat the price we get on the Icee's and Yeti's.
    Good luck,
    Mike
  3. Offline
    Jul 12, 2007
    10,609
    491
    Adelaide South Australia
    Your Vehicle Year:
    I have a 54 litre Igloo cooler
    http://www.igloocoolers.com.au/legend_series.htm
    I can go camping for a week with my son and still have ice in the esky on my way home.
    I freeze everything I can freeze including my drinking water and I leave a block of ice in the esky over night before I pack it in the morning.
    I use 2 litre bottles of frozen drinking water and 4 litre icecream buckets to make blocks of ice a week before a trip.
    Cold drinks are stacked at one end, salad veg and fruit kept up high in containers or they will freeze and the ice and frozen meats down low. Don't open the lid more than you need to and avoid putting anything in the esky unless it's near freezing. Keep the esky out of the sun, when traveling put your prius windscreen sun refletive shade over the top with a towel on top of that.
  4. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    Thanks for the great input guys! So, if I'm not mistaken, there's just no getting around thick polyurethane insulation? It would seem that a layer of reflective foil (think space blanket) laminated to the interior walls would go a long way toward needing less bulk. The Quality and durability are just dripping off the units that Mike linked to... but where is the high-tech insulation that I just assumed would be out there somewhere... at some price? Has anybody ever attempted a vacuum insulation on something this big?
  5. Offline
    PA Prius Member
    Feb 27, 2007
    430
    23
    Your Vehicle Year:
    A few months ago I was doing a similar search for a cooler for our cross country trip. In the end we decided to use our cheap thin walled cooler and made sure we packed other things around it to exponentially improve the insulation. This worked well.
    If you are more adventurous, try this-- leave your spare tire at home and take along one of those Fix-a-Flat kits. Tap and plug a hole in the bottom of your spare tire storage area (to drain water). Spray the inside of that lower storage area with insulating foam. Use a piece of 2" blueboard for the "lid," making sure you have a tight fit.
    PA P
  6. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    I was thinking you should have your own line of hybrid coolers out by now. :)
    I have a small thermo-electric (Peltier) cooler that is quiet and does a reasonable job. As long as things are cold when they go in, and I keep the unit running and out of the sun, it's fine. I try to wedge it in among the sleeping bags when I'm packing the car, for better insulation. But for longer trips, and California heat, I think something better would be more to your liking. The Stirling-cycle powered coolers sound great, but I haven't tried one yet.
    As for making your own, some foil on the outside to reflect radiant heat could be effective. Do you have any old down sleeping bags lying around? ;)
  7. Offline
    naterprius Senior Member
    Mar 15, 2004
    1,841
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(darelldd @ Sep 3 2007, 09:51 AM) [snapback]506298[/snapback]</div>
    Darell, the foil is good for radiant heat. In space, since there is no air, and lots of sun, the foil works well.
    On earth, inside a cooler, where it is dark and full of air, it is kind of useless, since you are trying to stop conductive heat.
    What would work well is a vacuum cooler, like a thermos.
    Nate
  8. Offline
    Jul 12, 2007
    10,609
    491
    Your Vehicle Year:
    Did you click on the link to Frigid? http://www.frigidrigid.com/index.html
    http://www.frigidrigid.com/results/test_results.htm
    They did tests on the coolers including the Igloo. The Igloo has half the wall thickness yet in some tests only took an 20% hit in efficency. Should you cover the top with a cheap windscreen sun deflector you would get most of the 20% back I think and especially if you bought 3 and covered the whole thing but for the bottom.
    Engel car fridges can be assisted with an insulated cover, this would be the same sort of thing.
    That's my opinion anyway.
  9. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    How about this one? You can leave this or any other electric cooler running in a locked Prius by removing the mechanical key from the fob. Lock the doors with the button on the armrest, and flip the window button up. The car will turn on and off as needed to recharge the battery.
  10. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(darelldd @ Sep 3 2007, 11:51 AM) [snapback]506298[/snapback]</div>
    I've done extensive research on this topic for sailboat ice boxes. They are built-in, but the same principles apply. It comes down to durability and cost. There are many types of insulation with better R values than blue board, but each comes with some baggage.
    Some types of foam work well when dry, but rapidly absorb moisture and loose most of their insulating properties. Blue board is impervious to water.
    Vacuum panels are incredible, and can used for large ice boxes. The limitations with vacuum panels are cost, inability to cut to size, and short life span. While they have great R values when new, in a couple of years the panel will loose its vacuum and then it's not nearly as good as plain old blue board. You also have trouble insulating the corners between the panels, and the whole assembly tends to be fragile.
    Silica tiles like those used on the Space Shuttle would work well, but the price is also in low earth orbit.
    What we found is that all of the higher tech insulations provided an R value gain only at great expense with limited life. Plain old blue board has the best overall characteristics. We use four inches of it all of the way around, and cover the outside with a heat reflective material, such as aluminized mylar. We line the inside with layed-up GRP (fiberglass).
    Tom
  11. Offline
    priussoris New Member
    Apr 5, 2007
    1,005
    Darrelldd, when we lived in AZ. we needed a cooler that would keep ice and food good for a few days at a time.
    What I did was to use an older cooler we already had that was thick shelled and I drilled a few holes on the underside of the cooler all the way around it ( just a couple on each side)
    then used that " foam stuff insulation in a can" it worked great , so great that when the wife and I moved our daughter asked to keep the cooler, she still lives in Phoenix.
    So I am glad you brought this topic up, as I need to make another ' Super Cooler"
    I will have her take a picture and email it to me to post you can't even tell and it does not add to much extra weight at least I do not think so.
    good luck in your quest.
  12. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(hyo silver @ Sep 3 2007, 09:14 AM) [snapback]506306[/snapback]</div>
    My Peltier cooler is good for what it is. But you sure don't want to pack stuff tightly around it while it is running. That would block the fan, and wouldn't let out the heat that the system generates.
    <div class='quotetop'>QUOTE(naterprius @ Sep 3 2007, 10:07 AM) [snapback]506327[/snapback]</div>
    Dang it. I hate being trapped here on earth. If I were in space, I likely would need insualation to keep everything FROM freezing, so there are several issues. :) A very good point about conductive being the big enemy here - assuming the thing can always be kept out of the sun. I toss a space blanket on top of the thing whenever I think there will be direct sun hitting it.
    <div class='quotetop'>QUOTE(patsparks @ Sep 3 2007, 04:02 PM) [snapback]506460[/snapback]</div>
    I did follow the link, but missed the tests. Thanks again for the pointer. They start off with 20% difference, but apparently end up with a 200% difference? A bit confusing how they talk about it... Still, 20% is pretty significant in my book.
    <div class='quotetop'>QUOTE(hyo silver @ Sep 3 2007, 10:25 PM) [snapback]506641[/snapback]</div>
    Wow. I'd love to try one of those... except that I don't want everything frozen (ever tried to drink crunchy beer? The head sort of suffers). I wonder if it has temp control that can be dialed down. And while I do understand that it can be kept powered via the HSD, the LAST thing I'm looking for is a gasoline-powered cooler! Ug.
    <div class='quotetop'>QUOTE(qbee42 @ Sep 4 2007, 06:42 AM) [snapback]506731[/snapback]</div>
    Thanks for your great input. Obviously there's much here that I hadn't considered. I definitely need something that's durable even if I give up a bit of initial effectiveness! Bummer that they haven't figured out the perfect, non-leaking vacuum system yet.
    <div class='quotetop'>QUOTE(priussoris @ Sep 4 2007, 06:53 AM) [snapback]506735[/snapback]</div>
    I tried that very thing with some of my old coolers. And what I found was... there was no more room for my foam since they seemingly squirted in expanding foam to make them in the first place! You're saying that the walls of yours were NOT all the way filled from the factory? Definitely room for improvement there!
  13. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(darelldd @ 2007 Sep 4 12:22 PM) [snapback]506882[/snapback]</div>
    Yes, the extra packing goes only around the sides, without blocking any airflow. It's also important to be sure the plug's in right, since the Peltiers can work as heaters, too. No need to ask me how I know this.
    True, a gasoline-powered cooler is not ideal. I just think it's cool that it can be done. I'm sure the Coleman Stirling has adjustable controls, so there's no need to go camping without head. Or cold beer. :rolleyes:
  14. Offline
    RobH Senior Member
    Sep 18, 2006
    1,551
    289
    Sunnyvale, California
    Your Vehicle Year:
  15. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(RobH @ Sep 4 2007, 02:56 PM) [snapback]506943[/snapback]</div>
    Just a few thousand bucks, and I can do the whole car! :)
    R50 per inch. That is EXACTLY that I'm talking about. Anybody know about durability of this stuff? And why nobody seems to make a cooler with it?
  16. Offline
    Godiva AmeriKan Citizen
    Apr 8, 2005
    10,340
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(darelldd @ Sep 6 2007, 04:15 PM) [snapback]508131[/snapback]</div>
    Uh...because no one wants to buy a $500 cooler?
  17. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Godiva @ Sep 6 2007, 06:47 PM) [snapback]508273[/snapback]</div>
    Well, THAT ain't true. Here's the money. Where's the cooler?
  18. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,047
    442
    Flushing, NY
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Godiva @ Sep 6 2007, 09:47 PM) [snapback]508273[/snapback]</div>
    <div class='quotetop'>QUOTE(darelldd @ Sep 6 2007, 10:38 PM) [snapback]508300[/snapback]</div>
    I'm with darelldd on this. I get it, I think.
    Reminds me of a true story. Ever since I was a kid, for some inexplicable reason, I have always loved thermoses and coolers. When I was studying for the bar exam, I became friendly with someone who studied in the same room as me. I told her which law firm I was joining, and she said that she had a friend who was also going to the same firm and that she would introduce her to me. A couple of days later I was studying in the room with my thermos of coffee on top of my desk, and she comes in with her friend to introduce us. The first sentence out of her friend's mouth was "Hey, I like your thermos." The second sentence was "I love thermoses ... I also like coolers". Wow. A real kindred spirit! I should have proposed to her on the spot.
  19. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Boo @ Sep 6 2007, 08:39 PM) [snapback]508344[/snapback]</div>
    Hey, great story...Ahem. I'm married. To a woman.
  20. Offline
    Jul 12, 2007
    10,609
    491
    Your Vehicle Year:
Share This Page
