Help my power steering is gone
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by johnnychimpo, Feb 6, 2008.
  1. johnnychimpo
    johnnychimpo Active Member
    511
    109
    Monterey
    My power steering is gone the mfd says in red square ps and there is no speedometer all of my lights are blinking the park drive B reverse my climate conroll is gone so is mpg all this stuff i checked my fuseses all seem good any ideas
  2. Doc Willie
    1,717
    142
    Out there, somewhere
    Call dealer.
  3. Tideland Prius
    16,074
    *moved to troubleshooting forum*
    ehh.. sounds like all the electronics (not just PS) have gone bonkers.
  4. richard schumacher
    7,663
    1,038
    United States
    I'll bet dead 12V battery or poor connection. Let us know what the dealer finds.
  5. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I am very interested to find out what the diagnosis is by the dealer too.;)
  6. Winston
    Winston Member
    614
    SF Bay Area, California
    Got Punctuation?
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    That went out with the power steering: "Help! I'm heading for the end of a sentence and I can't find a full stop!"
    Tom
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Did you accidently push the power button twice rapidly while in ready? If so, just press firmly on brake and hit the power button again. This should bring it back to normal.
  9. johnnychimpo
    511
    109
    Monterey
    Car now at dealer they say many codes sucha as disconected battery and something about synergy drive very odd two day earlier they said the computer was fine no codes now they did a recal on steering shaft when all this happend but they want to blame it on my aftermarkte stereo and power inverter
  10. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    All I can say is that improper installation of audio eqpt and inverter *could* upset the 12 volt system. Suggest you fully disconnect all that stuff and see if the problem recurs. If so, troubleshoot your added wiring.
  11. johnnychimpo
    511
    109
    Monterey
    Re: Help my power steering is gone + ev mod
    well i had this stereo and power inverter for like 3 months no prob i took the car to the dealer for recal and diag they told me no error codes and my car was fine then the day after the steering shaft replacement all these things happen. i also have the ev mod is there any possability the ev mod could cause this? i removed the button before i took it to the dealer i knew if they saw it they would say ur warrenty is void but i couldnt remove the cable so it is still in place i dont think they have seen it but they still have not figured out what is wrong either they told me they were going wire by wire
  12. bandaid
    bandaid New Member
    earth
    As much as the normal prius owner likes to think they know everything about their vehicle, they don't. It is very dangerous and possibly deadly to monkey with alot of things on this vehicle. If you have the ability to change your own oil and put air in your tires please go ahead and do so, otherwise leave the diagnostics to the pros. I should know, I am a prius certified technician. So to emphasize some earlier posts, TAKE IT TO A DEALER if there is a problem.
  13. johnnychimpo
    511
    109
    Monterey
    I did take it to the dealer after that then i started having prblems. They still dont know wahts wrong but i get the feeling im gonna end up paying like 1500 or more. as a tech can you tell me if the ev mod could possibly do anything like what i have described
  14. johnnychimpo
    511
    109
    Monterey
    Well they figured it out after three days of diagnostics it turned out ot be a bad fuse
  15. PAPARYNO
    PAPARYNO New Member
    81
    Pensacola, FL
    As a newbie,... I have a question on the "electronic steering". If the battery goes dead of in the case of the blown fuse, is the Prius driver at the mercy physics to just go straight ahead..... no steering at all??
  16. qbee42
    18,058
    3,073
    Northern Michigan
    No, the steering is electrically assisted, in the same fashion that normal power steering is assisted by the engine. You can still steer, but it takes more force.
    Tom
  17. tochatihu
    8,995
    3,507
    2001 Prius
    I have driven a 2001 Prius both with and w/o power steering assist. The new model is of very similar design, but less likely to fail ;)
    Keeping to your lane at highway speeds, the steering effort feels hardly different at all. But taking corners at low speeds (and parallel parking etc.) become very muscular activities w/o the electric assist.
