Hi
Discussion in 'Newbie Forum' started by Pianoteacher83, Nov 1, 2015.
  1. Pianoteacher83
    Pianoteacher83 New Member
    Herndon
    Hi there are alot of Prius owners around here how dose it handle in the snow I am thinking of either getting the C or a used 2013 or 2014 regular prius!!
    If you use Winter tires which ones do you use
    Burna J likes this.
  2. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    I believe the consensus is that a "regular" Prius of the generation you're considering will behave similar to most other front-drive cars in light snow---OK, not remarkably well or poorly. It doesn't have enough clearance to deal with snow much more than 4" or so deep.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Mine seemed to navigate 6" of snow well enough to get through it without any issues. BTW, this was with 17" all-season tires.
    49,018
    hi! where is herndon?
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Google Google Maps
  6. bisco
    49,018
    ah, thanks. unusual for only one city in the u.s., it will handle that snow just fine.
  7. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    There's good news and there's bad news, yes the Prius handles slippery surfaces as good or better then any other front wheel drive car, possibly better, much less oil use age.
    The bad news, undefeatable traction control, studs are great, or at least snipes (Michelin) if you have an unusual amount of slippery product. With studs its bar none the best possible winter vehicle, because of the mpg's, the 5.7" clearance is plenty, if you live 35 miles up a mt, get a helicopter, but the question is how much ice do you drive on, if any , studs...
  8. Pianoteacher83
    Herndon
    By Dulles Airport
  9. bisco
    49,018
    thanks!
  10. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Hi Herndon , I know where you are - Lots of prior discussions but bottom line Prius does quite good in snow with some caveats. I am using All Seasons (Continental True Contacts - see TireRack.com) but All Season tires are not the best, people in cold climates go with real winter tires in winter (you can see the types in prior discussions here). I am not aware of too many in our area doing that though. Nokian may be the best All Season but we seem to be to far south to have Nokian dealers here.
    PS- Toyota coming out with new 4WD but not in USA for 2016 maybe 2017 we hope but no guarantees.
