HID kit in 2014
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Spooled, Oct 20, 2014.
  1. Spooled
    Spooled Member
    142
    26
    Concord, CA
    I read all the other hid threads I really want some hid as the stocks arent putting out enough light( seriously)
    I was about to pull the trigger on the Xenon Supply kit but fears about having to use spades instead of a connector (shown in the video) coupled w reports of the ballasts lines being to short have perturbed me.
    Is there currently anywhere to get a PNP kit as shown in XS video, also I dont want to use a relay so a 35w kit
    thanks!
  2. Spooled
    Spooled Member
    142
    26
    Concord, CA
    what about this ?
  3. Spooled
    Spooled Member
    142
    26
    Concord, CA
  4. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    Try some brighter HID bulbs before buying a, new kit. check out theretrofitsource. com they have pretty much everything for hids
  5. mypriuscious
    mypriuscious Member
    206
    70
    Cincinnati, Ohio
    I buy all my HID equipment from theretrofitsource.com. If you do want to get a pnp kit you should go with the XB series bulb as it moves the wire on the bulb to prevent shadowing in the center.
    The reason I buy there is because of the OEM like quality of parts provided and they specialize in retrofitting your headlights as opposed to PnP.
    kenichols29 likes this.
  6. Spooled
    Spooled Member
    142
    26
    Concord, CA
    I bought xenentechs off amazon for 40$ total plug and play, ground wires install at 6oclock
  7. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I went with theretrofitsource and the XB bulbs. It's 100% plug and play. No shadow line and I can see the space shuttle with these lights. I went with the 35W since there was no difference in light output with the 55w. I also went with the 4300k bulbs. Just a hint of blue. Possibly because of the lens covers. Highly recommended.
  8. davidw8818
    davidw8818 Junior Member
    39
    Huge differences between 35w & 55w
    H11 kit from retrofitsource xb35 4300k bulbs n morimoto ballasts
    35w
    55w recently upgraded
    SM-N9005 ?
  9. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
  10. Spooled
    Spooled Member
    142
    26
    Concord, CA
    running the 55w requires a relay install some people dont want to bother
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Relay should be installed regardless, also you could go the can bus route and not "REQUIRE" a relay
  12. Spooled
    Spooled Member
    142
    26
    Concord, CA
    the amperage draw on the 35w kits is less than the stock halogens
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Yes but the voltage can be up and down
  14. Spooled
    Spooled Member
    142
    26
    Concord, CA
    so my understanding is 55w= relay time
    35w pnp
  15. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    unsaid truth is that relays should be used. you can have complications either way. I am using a 55watt ddm without any problems, but i am now also preping for a retrofit for this Saturday!
