HID Relay Harness
Discussion in 'Gen 3 Prius Accessories and Modifications' started by slowpriusj, Jan 28, 2015.
  1. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    Hey Prius Gen III owners! I recently just purchased my 2010 Prius and the first mod I did was add new projectors/HID's. Upon ordering this kit I did not get the relay harness that a lot of people on here say we need, and I personally could not find a direct yes or no to whether we need this or not, so the answer is no. If someone would like to chime in please feel free! I've used my headlights for a total of 2 hours so as of now, no issues!
    I also would like to add I drove my car around with my headlights out to see if a bulb out warning would come on and nothing. Also, if we add LED's to turn signals will this create a hyper flash? Thanks!
    #1 slowpriusj, Jan 28, 2015
  2. okdonk
    okdonk Junior Member
    29
    Las Vegas
    I did not use relay/ harness kit on my 2015 Prius. They work and no issues at all.
    Yes you need relay to prevent hyper flash when installing LEDs for turn signals.
  3. slowpriusj
    167
    271
    Brunswick, MD
    Thanks, reason I ask is when I had my car apart, and used turn signals on it didn't hyperflash but I do not know...
  4. ray_prius3
    ray_prius3 Junior Member
    29
    West Hollywood and OC
    Still no issues? (Hopefully)
    I'm about to install HIDs too. I bought the relay harness just in case, but theres really no install relay guide for the Prius.
  5. slowpriusj
    167
    271
    Brunswick, MD
    You will be fine it seems to be only Chrysler/German cars that need a relay harness, and I couldn't tell you where or how to install it.
  6. mrbigh
    3,686
    699
    Long Island, NY
    It has been a headlamp wiring issue on MY 2010 vehicles, these are in need of the relay harness.
    On our 2011 and 2012 PiP, I installed the HID's with the relay harness regardless.
    I does make a better and proper install.
    ray_prius3 likes this.
  7. slowpriusj
    167
    271
    Brunswick, MD
    To each his own, I've ran my hids w/o it for 9 months and I'm trouble free!
  8. ray_prius3
    29
    Thanks for your responses. I kinda figured out how to install them. Just waiting on the actual HIDs to come in. :D
  9. ray_prius3
    29
    So I properly installed my HIDs, but I couldn't install my relay harness. I have no idea how to open the little lid that covers the positive battery connection in the fuse box. Can anyone help with how this is done?
  10. xliderider
    xliderider Senior Member
    7,850
    3,103
    Honolulu, HI
    Just connect your power wire to one of the two open terminals at the rear of the fuse box, where the two red wires are in the pic below. It's much easier to use them, just use a quarter inch push on terminal:
    In the pic, you can also see the positive bolt you are trying to get to for power. If I recall correctly, you have to use a small screwdriver to pry the clip that holds the cover on to access the bolt.
  11. ray_prius3
    29
    Thanks! I'll try that. I spent about 20 minutes before giving up. Maybe the philips screw driver wasn't small enough.
  12. ray_prius3
    29
    OK, this is my positive connector. How can I get it to connect to one of these terminals?
  13. xliderider
    7,850
    3,103
    Honolulu, HI
    You would have to cut the ring terminal off and replace it with a quarter inch push on terminal. Or you could leave the ring terminal on and put it under the bolt.
  14. ray_prius3
    29
    So my relay setup worked. This is how I zip tied it. Anyone see any possible issues?
  15. xliderider
    7,850
    3,103
    Honolulu, HI
    Your pic isn't showing up for me on either my smartphone (Tap a Talk) or PC (Chrome).
    Keep the wiring away from heat sources like the radiator or exhaust manifold, or moving parts (fans), and you should be good.
  16. bongsta213
    bongsta213 Junior Member
    32
    santa barbara
    which brand did you guys buy?
  17. ray_prius3
    29
    Here's the direct link to the photo: http://s10.postimg.org/y8s5sv1if/IMG_2989_2.jpg
    I don't think it's covering anything that you mentioned (or at least I hope not).
  18. ray_prius3
    29
    I got mine from DDM.
