Hmm; I’m leaving my Prius V for a few months and wonder how this will affect the battery; ideas?
Discussion in 'Prius v Main Forum' started by HiPriustess, Apr 15, 2013.
  1. HiPriustess
    HiPriustess New Member
    17
    Does the car need to be ‘turned over’ to keep the battery alive. Do I disconnect the Battery. I may not have anyone to take the car for a spin now and then so all ideas appreciated. Thanks !!
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,198
    4,862
    Texas Hill Country
    If you can get someone to start it and warm it up that would be the best. Otherwise I would leave a trickle charger on the 12v battery. Disconnecting is not the best idea.
    HiPriustess likes this.
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    There are smart battery maintaining devices out there for around $50 that will do a good job of keeping the 12V battery healthy. Based on experiences of others on this forum the high voltage battery should retain a healthy level of voltage without outside intervention for a few months.
  4. HiPriustess
    17
    Wow. Thanks !!!
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    rjparker, though I agree with your first two comments are viable, why do you say "Disconnecting is not the best idea."? Curious.
  6. Adam H
    Adam H Junior Member
    61
    I thought the 12 volt battery is charged from the high voltage battery, so if the high voltage battery is charged the 12 volt should be OK?
  7. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It only charges the 12V when the car's in Ready mode.
  8. Adam H
    61
    OK, but also the 12 volt battery is not used for starting, so if it's down the car should start, no?
  9. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The 12V battery is used for "booting up". If it's dead nothing will start, even though it doesn't actually crank the engine.
  10. Mike500
    Mike500 Senior Member
    2,593
    764
    I tried the $25-35 Deltran Battery Tender Jr. a few years ago. It killed the AGM battery in my riding lawn mower. It recently killed the battery on my brother's BMW X3.
    I've had good luck, however, with the cheap Harbor Freight model, that I got for $4.99 with a widely distributed coupon.
    Automatic Battery Charger - 12V
    The nice thing is that it NEVER goes above 12.5 volts. It means that it doesn't overcharge. Overcharging boils away the water in a battery.
    Cheap, but it works.
  11. rjparker
    8,198
    4,862
    Texas Hill Country
    If you disconnect the battery you lose all tuning and setup parameters plus it's not that easy on a Prius v.
  12. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Can you leave the car "On" and locked?. AC and heat off, radio off, DRL's off.
    The engine would come on to keep the battery charged. Tank of gas should last 6 months?
  13. WilMent
    WilMent diacritic
    369
    149
    New York
    I don't know about 6 months, I thought the ICE starts when temp is under 110ish? If that's the case a tank won't last that long at all. Leaving the car on outside would be a little weird and indoor garage might be a little dangerous?
