Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    Glad it helped, congrats on the install.
  2. golo
    golo Junior Member
    corona ca
    very nice! thanks for posting
  3. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    I have had a pair of the Fiamm Freeway Blasters on my 2012 Prius III for about two years. I did not use a relay in the installation and the low-tone horn has recently failed. Could the failure be blamed on the absence of a relay? I intend to replace the horn but I need to know if I should include a relay in the circuit.
  4. mrbigh
    3,686
    699
    Long Island, NY
    You should, but the horn failure doesn't have anything to do with the lack of it.
  5. Nutstoyou
    Nutstoyou Junior Member
    34
    Southern California
    Just installed the FIAMM's and wow what a difference they make!! I have large hands so I also remove the 2 bolts and the plastic clips that hold the front facia on, so I could pull it forward. Much easier for me that way. I also removed the stock brackets holding the OEM horns and used the brackets supplied by FRAMM. I assembled the horns to the bracket out in the open, then just had to thread the one bolt holding the bracket back in and hook up the one wire. Took me about 30 mins.
    mrwhsprs, evpv and ftl like this.
  6. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    To relay or not? Some of you installed a relay most did not. I guess my question to this mod is why do I need to install a relay? Or better question why is there not a relay already part of the original circuit if it something thats needed?
  7. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    Relays aren't necessary because the current draw is the same as stock.
    Relays are typically only needed when you install something that uses significantly more power than the wiring was designed to handle.
  8. Jeremy Henry
    Jeremy Henry Junior Member
    MOSES LAKE
    I did my horn this weekend and went through the top after taking a bunch of clips out under the top bezel. What a difference that makes!
  9. MeetGeorgeJetson
    48
    33
    Woodstock NY, USA
    Thanks EVPV!.. Horns are coming in this week from Amazon..
    Jeremy Henry likes this.
  10. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    You'll enjoy the "big boy" sound of the new horns. No more meep meep. :D
  11. MeetGeorgeJetson
    48
    33
    Woodstock NY, USA
    Horns went without too much trouble, though that space was so tight it was pretty hard for my hands and they are not that big.
    TIPS FOR THE NEWBIES: Make sure you have metric wrenches on hand as I did not, used a socket set and that really wasn't the right tool, but I managed. Horns sound great and I even got all the neighborhood dogs and my own barking! Also note the power cord connected fine but I was a bit puzzled as to how to use the Toyota connector to the Fiamm 2 post connectors. For anyone doing this who is as mentally challenged as I am, it just slips on to one of the posts and the supplied washer-wire with connector slips on the other. Doesn't matter which connector you use as the horn is not polarity sensitive, if that makes sense. And Xliderider, you were right I am enjoying the big boy sound.. Thanks for the step by step EVPV
    xliderider likes this.
  12. krausternet
    krausternet Member
    137
    24
    SF Bay Area
    - I am wondering the same thing; easier to do the 74100 package or the 72102&72112?
    - and is the 74100 package just as loud?
    - Also when I look at 72102 on Amazon there seems to be high version and a low version which makes me wonder.
    - Plus, I have a 2013 and amazon is stating to me (I guess since I somewhere entered that I have a 2013 Prius) that the 72112 doesn't fit my 2013 Prius. I see this thread was started prior to 2013 but I am assuming the more recent posts here are with 2013 or later models, right?
  13. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    I just installed the Fiamm El Grande 74100 instead of the 72101/72112 Freeway Blaster described in post #1. Reasons are (1) it's $12 cheaper, and (2) they're slightly smaller so they're a little easier to install. Note however that the El Grande is 128 dB while the Freeway Blaster is 130 dB.
    Anyway, for the 2014 PIP there are a few differences from the procedure described in post #1 but otherwise the same:
    1) You need to remove the fasteners that secure the top portion of the bumper cover to provide additional room. It doesn't matter if you have small hands, because...
    2) You need to remove the speaker that warns pedestrians when you're at low speed. Only way to do that is at the bracket mount, which you can't get to unless you loosen the top of the bumper cover. If you don't do this, there's no way you're going to get to the right horn.
    3) Because you have to do 1 and 2, I found it easier to remove the nut holding the bracket and horn, then remove them though the emblem hole, and then remove the horn from the bracket.
    My opinion is that it's plenty good and plenty loud for just $20.
  14. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    What kind of air horn did you use? I have been wanting to put a air horn or a semi horn on my second gen, I almost got hit the other day because people didn't see me so a more commanding horn would help a ton.
  15. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I verified this info as well. I also removed the pedestrian warning speaker in the process. Thanks.
  16. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    Thanks for the info about the El Grande horns and PIP installation. I updated the first post.
  17. CTPINTL
    CTPINTL New Member
    Virginia
    So 4 years later, your info is still helping people. THANKS!!!
    I just followed your directions exactly and changed my horns. I never bothered before because I rarely drove the car. 2010 only has 28k miles.
    Worked great. Thanks again!!
    CTP
  18. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Tried to install these earlier and ran out of natural light due to overcast. Spent too long removing the emblem only to find out it might be easier for me to just loosen the bumper and come from the top.
    Anyway, I'm a little thrown off because I got the El Grande twin pack and see the ground prongs in the bag, but don't see any wiring connected. Am I missing something or do I not need to ground them?
    sfv41901 likes this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Ues the ground wire that came with the horns & attach it to the bolt that the horn mounts to. Then OEM wire goes to the other terminal on the horn.
    VS980 4G ?
    HelloHybrid likes this.
  20. HelloHybrid
    482
    1,483
    Thanks Sean. I think I'm missing the ground wire then since i didn't find any in the packaging.
