Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. Solscud007
    Solscud007 New Member
    59
    Nyack, NY
    Thanks for the write up. Im more interested in how the front toyota badge is removed without removing the bumper NICE. Thanks for that. Now on to illuminated badging!!!
  2. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    While a little more extreme than I need, train horns are always good for a laugh:
  3. harry r
    harry r slowly turning green
    122
    NW of chitown
    now thats funny but i suspect it might get the car keyed .... tks for the write ups, I may have to add those FIAMM horns to command a bit more acknowledgement... kinda wish i could install a switch to go between, "excuse me" and "hey what the f$#k" did you just do.. sometimes we just need a little wake up call at the light.
    tks again
  4. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    My air horn stopped working last night. I took it apart today and found the relay terminals are not rust proof.
    I went to Advanced Auto Parts and spent $1.37 on a new 12V 30A relay. This time I wrapped it in electrical tape. If you are doing a new install wrap it in tape.
  5. Green Machine III
    Green Machine III New Member
    Davie, Florida
    I installed a JDM Toyota Premium Horn kit on my 2010 Prius and boy what a difference. It was embarrassing to blow the horn! The horn sounds just like the Fiamm Horns that evpv installed on his 2010 Prius V. The only difference is that the JDM Toyota Horn kit is a direct plug and play install. The JDM Horns have the same connector as the OE horns that come with the vehicle. I love it!! I want to thank evpv for his detailed installation pictures and tips as this assisted me on my install. :rockon:
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    If you want weather proofing, cut a finger off a latex glove and put the relay inside the finger then tape off the opening.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    728
    I never realized how pathetic the horn sounds. :(
  8. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    nice DIY write up.....
    I also upgraded my horn.... the stock horn was too soft for me... ;)
  9. BNAL
    BNAL New Member
    Temecula, CA
    Well I did the mod and it was not that hard. I had to remove the clips and bolts from the bumper, because my hands need the extra space to get in and remove the original horns. I think the removal was the hardest part. Anyway now other cars can hear my horn if I use it.
  10. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    Done. Ordered the horns from Amazon and installed them. Ridiculously good improvement for $20.59! Matter of fact, the best upgrade I've done on any of my cars for the price. I called my local dealer to ask about warranty issues: They told me no problem if the install was done correctly.
    One observation regarding the install: I loosened all the "pop" fasteners and 2 bolts for the bumper cover to allow my (large) hands to better access the horns. I couldn't get my hands in the space without doing so.
    It is a VERY tight space for someone with big hands!
    Thanks for the great tip EVPV - well worth the effort and expense!
    Benjamin Haag and DaWeav like this.
  11. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    Glad it helped, congrats on the install. You loosened the fasteners so you could get to the emblem screws, right? Once the emblem is removed you should have plenty of room to get to everything.
  12. pixelmixer
    102
    Seal Beach CA
    Yes. I used the emblem opening in addition to pulling back the top of the
    bumper cover to get the room I needed. I found the right-side horn retaining nut to be very tight. It was difficult to get loose. The left side was easy.
  13. RufusNapkin
    RufusNapkin New Member
    36
    So, is a relay needed when installing these Fiamm horns? Or is there a relay on the car already?
    On bikes installing such a horn without a relay makes the horn barely audible.
  14. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    No relay is needed with the Fiamm Freeway Blaster horns.
  15. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    just finished, thanks for the write up evpv!
  16. unkprius
    unkprius Member
    152
    17
    Just finished my install, took a while as the horn bolts were really tough to get to, I don't see how anyone could do it without taking out the emblem. My Piaa horns had the connectors on top so I had to put together some short jumper wire connectors between the horn and factory connectors. Used some premium 3M plastic electric tape to seal things up.
    No more wimp-prii sound!
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I envy the price difference, I went w/ the JDM Toyota Premium horns (similar sound), but they've recently gone off-tune. I could have paid $20ish (after empl. discount) vs $85!
  18. Keithstef
    Keithstef Junior Member
    17
    Northeast, Pa
    20 minutes to install(10 was looking for a stubby phillips)
    Now that's a horn! $20 something via amazon. Thanks for the tip!
  19. aliti19
    aliti19 Junior Member
    Chicago, Il
    took me an hour an a half - i was trying to take off the bracket the whole time and frustrating myself. About an hour into it I realized I was working on the wrong nut.
    Sounds great!
  20. RufusNapkin
    36
    Is there a difference between the Fiamm 72012 "Low Tone and the 72112?
    The 112 says "Freeway Blaster on It"... I received the 012 which doesn't say Freeway Blaster" and is obviously a different model.
