How a solar storm two years ago nearly caused a catastrophe on Earth
Discussion in 'Fred's House of Pancakes' started by cwerdna, Jul 27, 2014.
  1. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Nope.
  2. fuzzy1
    10,111
    ftl likes this.
  3. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Well, apart from that one... :D
    I tend to ignore landline systems as my main interest is undersea (submarine) cables, all the way back to 1850. These were used for telegraph messages from then until the early 1960s, when all the remaining traffic was moved onto undersea telephone circuits. Soon after that, all the submarine telegraph cables were abandoned in place (you can still haul up sections today) and the associated shore equipment was scrapped.
    Today just a few telegraph cable stations remain worldwide, out of the hundreds once in use. If you're ever on Cape Cod this one is worth a visit:
    French Cable Station Museum - Home Page
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  5. tochatihu
    tochatihu Senior Member
    9,014
    3,511
    Kunming Yunnan China
    2001 Prius
    Could someone comment on the utility of the range of surge protector technology vs. voltage transients from 'charged particle' events? I guess they work for nearby lightning strikes, but...
    In this scenario, the distribution grid is fried (per ftl) but your boxes at the outlet end get protected. So you can use them if the power ever comes back on.
    Let's bring this back home - how big of a solar storm would it take to bake a Prius?
  6. fuzzy1
    10,111
    I'd expect powerline surges from CMEs to be sustained events, driven by motion of the Earth's magnetic field under the solar-driven storm. They will continue for some time, similar to the length of a nice Aurora Borealis display. This is far longer than the quick transients addressed by common surge protectors. I'd expect such protectors to soon exceed their energy limits and fail.
    But I'm not sure how much of the surges will appear at household wall outlets. Most of the problem appears in very long wires with some sort of ground connection at each end. Long distance power lines tend to suffer excessive DC offsets, which causes imbalance and overheating in the transformer banks. Old telegraph lines were single wire, using the ground as a return path, so the excess DC was applied directly to the telegraph receiver, which sometimes burned.
    The DC offset itself doesn't pass through the transformers from input to output. But because transformers will saturate and show non-linear behavior, that offset will distort the AC output waveforms, which may cause problems with the attached appliances, and lead to additional DC offsets. But I believe the problems are the worst at the big transformers coming off the lone lines, and should be reduced by each local step-down transformer and shorter distribution circuit along the chain to household wall outlets.
    How big of a solar storm would it take to bake a Prius itself? For a Plug-in Prius, I suspect that it would have to be big enough that the fate of the Prius is no longer a primary concern. For a non-plugin Prius, the storm would have to be so big that the Prius' fate is absolutely no concern whatsoever.
    #26 fuzzy1, Aug 1, 2014
    GrumpyCabbie and ftl like this.
  7. tochatihu
    9,014
    3,511
    2001 Prius
  8. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Glad to see a post from you. Is everything OK in Kunming, then? Did you feel the earthquake?
  9. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    There is a bright side. Some one might come up with a solar flair energy harvesting collector and get power while many other lose power. ROI might not be so great however.
  10. tochatihu
    9,014
    3,511
    2001 Prius
    search
    "Solar storm risk to the North American electric grid"
    and download from Lloyds or AER
    fuzzy1 likes this.
