How do I change from kph to mph on the speedometer?
Discussion in 'Prius c Main Forum' started by priuscpower, Mar 15, 2012.
  1. priuscpower
    priuscpower Junior Member
    Spring Branch, TX
    I read through the manual but can't figure out how to change to mph on the speedometer. I saw the full size Prius has a button but I see no button on my Prius-c.
  2. JimboPalmer
    JimboPalmer Friend to those who want no friends
    9,203
    3,043
    Greenwood MS USA
  3. priuscpower
    Spring Branch, TX
    It worked...I now can read my speed in MPH. Thank You.
  4. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    I think it is rediculous that the dealerships are not changing the cars to MPH from kph during the pdi process. The car I drove was kph as well and I didn't notice until the car was moving.
  5. PreciousPups4U
    PreciousPups4U New Member
    Lexington, SC USA
    I
    Thanks. Was having the same issue. Could not find anything in the book. Who would have thought to look under odometer to convert the speedometer?
  6. wifemomhockeyfan
    wifemomhockeyfan Junior Member
    34
    Newman CA
    We were having this same problem last night at the dealership. Even the salesmen didn't know how to fix it. They finally got someone that could figure it out.
  7. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    It must be in 'odometer' mode. If in the 'disp' sub-menus, this will not work. I was frustrated otherwise. I called the dealership to no avail. I thought I was speeding for my first trip!
  8. jodypret
    jodypret Junior Member
    Dallas, Tx
    I am so happy to have found this answer. The odometer display stayed lit even after the car was turned off, but eventually went blank. Hopefully, this problem is solved!x
  9. whipper25
    whipper25 New Member
    You can also press and hold the 'trip' button on the steering wheel to toggle between km/h and mph.
  10. cmstlist
    cmstlist Member
    177
    38
    Toronto, ON
    Might be going on a road trip across the border tomorrow - will have to try this! I have a Master's in Chemistry but I still was never that good with arithmetic - so I need my speedometer to read the same units as the speed limit. :)
  11. Smorger
    Smorger New Member
    Hold the trip button down while you are on the odometer and it will change speedo from km to miles.
  12. jtfresh1
    jtfresh1 New Member
    Apex, North Carolina
    This short video is easy and helped me. It answers it completely...
    I hope it helps everyone...
    Tideland Prius likes this.
  13. koipond
    koipond Member
    193
    35
    The car must be stopped for this to work... drove me crazy until I figured that out.
    SCH-I535 ?
  14. vernon birdman
    vernon birdman Active Member
    330
    140
    Vernon BC Canada
    Why don't you all just move to Canada and save yourself all of this aggravation.
    griffdb and Tideland Prius like this.
  15. ztanos
    ztanos All-around Geek!
    2,544
    773
    40
    Duluth, Georgia
    I've changed the speedo from KPH to MPH while driving plenty of times.
  16. vernon birdman
    330
    140
    Vernon BC Canada
    M
    me 2
  17. Sara Lavendar
    Sara Lavendar New Member
    Toronto
  18. DKTVAV
    DKTVAV Member
    476
    I just copy/paste here the section you need from page 188:
    Odometer Displays the total distance that the vehicle has been driven. Some models, pressing and holding the “TRIP” switch will switch the display between MPH and km/h.
