How do you keep track of fuel mileage on a Prius?
Discussion in 'Gen 2 Prius Fuel Economy' started by PriusPhilly, Mar 10, 2012.
  1. PriusPhilly
    PriusPhilly Junior Member
    Quebec, Canada
    2001 Prius
    I
    OK I have an excellent question;
    How do you guys keep track of the Prius fuel mileage knowing the bladder in the tank changes size depending on the temperature??
    Wouldn't that make it impossible to keep track of mileage? I live in Montreal Canada and the temperature varies from -35ºC(-31ºF) to +35ºC(95ºF) so the temperature is constantly changing throughout the year.
    Usually when you calculate your mileage, you take the distance traveled since your last fill up and the amount of fuel it takes to fill up the gas tank.
    But with the Prius gas tank, that accepts different amounts of fuel depending on the temperature, it throws that calculation all off.
    Since I see everyone on this site calculates their mileage and posts it up, how do you guys go about doing it. Is there a special technique?
    Thanks!
  2. Mendel Leisk
    38,953
    Calculation for one tank could be off, but the next tank, or the one after that, should balance it out. And if you calculate accumulating mileage and distance, it will be very accurate, regardless of any variation in tank capacity. For example: a calculation for all the gas you pumped in a year, and the total distance travelled.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Exactly correct. That's how I calculate fuel economy. Over a long time scale.
    I do wonder some times how accurate the fuel delivery pumps are. Sometimes I sense I'm being cheated by some gas stations. I haven't gone to the extreme of filling certified 5 gallon gas containers and complaining to the gas station if I don't get the full 5 gallons. If regular reaches $5/gal average across the continental US, I think you might see people who will do this.
  4. Mendel Leisk
    38,953
    The one downside though: if you want to see short term mileage, it's going to be difficult with a finicky gas tank. At least you can use the dash display for that, keeping in mind that it might be exxagerating by some percentage.
    On that subject, early reports from Plug-In Prius owners are saying that the displayed mileage is finally quite accurate.
  5. Kmack
    Kmack New Member
    Ontario
    For all the Canadians out there... Here's an easy basic sheet that I put together and have been using (including my gas mileage for the first few months) - Size of tank is not in the calculation, rather, you put in the mileage (kilometers) you travelled and number of litres to fill back up. you need to reset one of your your trip odometers or use the reading from the MFD that resets automatically every fill-up (not sure if it's linked to Trip-A, but mine seems to reset by itself on fill up once the car moves a bit). I keep my receipts in the glove box and add up the used litres between actual fill ups so i don't have to fill every time if the price is too high. I only reset/calculate when I put in an actual full tank.
    And before you ask, yes, my mileage is that bad in winter, typically -10 or lower for the winter months and the ICE runs alot for heat.
    Feel free to modify, and pass it on.
  6. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    Same here. Over the long term......
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You don't get to grade your own questions. ;)
    I'd give this one a 'B' grade at best: It's a decent question, but it's been asked and answered many times before.
    Tom
  8. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I have recorded on-screen mpg and miles for each tank (plus price of fuel) for 5+ years now. One of these days I should make some pretty graphs.
  9. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Here is a modified version which gives a three-fillup moving average and should average out the variation over a few fillups. I don't like the lifetime average because it masks other changes.
    (Finally a question here about something I know, spreadsheets!):eek:
  10. Big Steve
    402
    39
    Richmond VA
    And maybe now ith the attachment
  11. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    OK, here is my spread-sheet version. Enjoy.
    Not many data points yet, but I figure no one here would want to look at 5 years of data from my '07 HCH.....
    Once you open it, select the view summary page.....
