How many EV miles do you get after a full charge now?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Flynlyon3, Sep 21, 2015.
  1. mrlebop
    mrlebop Member
    136
    68
    I just bought my used 2012 PIP Base with 51,200 miles and the EV miles after charge shows up as 10.5, but I routinely get 14. Strange.
    #181 mrlebop, Dec 1, 2015
    49,072
    welcome and congrats. not really strange, just conservative.
  3. CharlesH
    2,785
    1,152
    Roseville, CA
    Are the recent posters in this thread referring to the fairy tale EV range on the Hybrid System Indicator display? At best, it is a rough guess based on recent driving patterns, and has little to do with how far one actually can go in EV mode.
  4. mrlebop
    mrlebop Member
    136
    68
    I'm happy with conservative!
  5. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    The is my second full charge, it shows 10.
    iPhone ?
  6. mrlebop
    mrlebop Member
    136
    68
    Mine usually shows 10.5 but not always.
  7. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    "In EV mode, the car will shut off the engine if traveling about 61 MPH or less".
    I have had my PIP on the Highway and gone up to about 65 without the engine engaging. I know the speedometer reads higher than actual speed, but that seems pretty good. I can cruise on the Interstate in town, as the speed limit is 55 MPH, in all EV, if I can keep it about 65...the battery drain isn't too bad either.
  8. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    How best to use EV?
    (I had the car for over 1 month now, so I am a noob).
    Accelerate with gas and manually switch over to EV and cruise ?
    Never use EV to accelerate?
    If in traffic, use EV?
    BTW, when I first got my car, it use to show 10 EV. Recently, it started showing 11 EV, now, it went down to 10.8, then 10.5, and I assume it will continue to go lower.
    Seems where i use to charge my car, it is a slight decline road going home. (Got to 11EV)
    Now I am charging somewhere else, and the EV is getting lower because going home now is a slight incline road. (10.5 EV and declining).
    iPhone ?
  9. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    If you can do the whole trip in EV, use EV. Otherwise, use EV on downhill areas, or any time the car doesn't require much throttle. The gas engine is best used for acceleration and going up hills.
    I always use the first 10% of the range before switching to gas so that I can regenerate energy when coming to a stop. The car won't recapture energy if the battery is full, and charges at a much slower rate when near full.
    On long road trips I like to keep about 6 miles of range just in case I run out of gas.
    Your guess-o-meter will show increased range as you practice efficient use of EV mode.
    TerryK. and sillylilwabbit like this.
  10. markabele
    5,084
    1,782
    Nebraska
    You have to keep in mind your warm up costs, too.
    Redpoint5 likes this.
  11. bisco
    49,072
    just hit 13.9 today.
    retired4999 likes this.
  12. Flynlyon3
    Flynlyon3 New Member
    Tustin
    I've been stuck at 9.9 :/
  13. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    My winter low this year was 10.1
    So far this spring, it had climbed up to 13.1
    I don't expect the estimate to go much higher. That had been the annual pattern for 4 years now.
    bisco and N.J.PRIUS like this.
  14. Redpoint5
    1,026
    508
    Portland, OR
    My swing seems to go as low as 13 indicated in winter, and as high as 17 in summer. I just started making most of my work commutes on EV alone. During the winter I fall a mile short, and during the summer I have 1-2 miles surplus. I might even get to use a few minutes of AC with the spare juice.
  15. bisco
    49,072
    do you have much temp change year around?
  16. Eddiedirtriding
    Eddiedirtriding New Member
    Hayward ca
    I got 13 tonight , I only had the car for 2 weeks ,
  17. QuantumFireball
    QuantumFireball Active Member
    416
    267
    Ireland
    I'm only getting around 9 miles so far, but still getting used to the car (just got it last week). One thing I've noticed is that for whatever reason the European PIP has an EV maximum speed of only 85 km/h (53 MPH), which explains why the ICE was kicking in much earlier for me compared to what I read here.
    My normal commute includes a dual carriageway with a 100 km/h (62 MPH) speed limit - maybe I should reconsider my other route (all 50 km/h, heavier traffic, but shorter)? Or should I switch to HV mode altogether on the 100 km/h sections? My commute is 7-10 km depending on route.
  18. john1701a
    12,749
    5,243
    57
    Yesterday was the highest estimate I have ever seen it 13.6
    Sadly, I have no idea what the actual EV miles would have been. I didn't drive far enough yesterday... just a short run into town for ice cream.
  19. bisco
    49,072
    congrats and welcome, all the best!(y) it depends on distance, hills and how many lm at each speed limit. can you give us more details?how is your cholesterol?:p
  20. Eddiedirtriding
    Hayward ca
    I have to say , I love this car it was hard letting my 650hp Pontiac GTO go , but 12 mpg wasn't cutting it , and two of my riding partners diying on motorcycle accidents , it was time for some change ,
