How Many kWh in a Full Charge?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jan 2, 2013.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    That's a good point. I did try to account for this by turning off everything I could: radio, MFD, A/C, lights, etc. The Scan Gauge did say I was pulling about 0.5 amps before I initiated the charging session.
    If we add 100W to the numbers that are going into the battery we get the following:
    240V: 2025 / 2300 = 0.88 (12% loss)
    120V: 1114 / 1533 = 0.726 (27% loss)
    120V: 1114 / 1452 = 0.767 (23% loss)
    If we assume that it's more like 200W overhead, then the numbers are like so:
    240V: 2125 / 2300 = 0.9239 (8% loss)
    120V: 1214 / 1533 = 0.7919 (21% loss)
    120V: 1214 / 1452 = 0.836 (16% loss)
    Keep in mind that there is overhead in an unattended charging session. We know the battery fans run, and we know that the 12V battery gets a trickle charge. We just don't know how much. A safe bet is probably 50W to 100W.
  2. 3PriusMike
    3,095
    2,417
    Silicon Valley
    I measured over 132 miles...29 kwh. That should be within a few percent.
    Mike
  3. John H
    John H Senior Member
    2,208
    558
    what typically accounts for much of the higher effeciency of 240V charging is that the fixed W overhead is only for half the time of the 120V session.
    ie. 200W x 1.5 hours versus 200W x 3 hours = 300Wh which is 10% of a 3kWh session.
