How Many MIles Do you Avg b/w Fillups?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tony Prius, Oct 7, 2013.
  1. Tony Prius
    Tony Prius New Member
    Northern New Jersey
    2013 Prius Plug-in
    On average, how many miles do you average between fill ups? I understand that this is all dependent on everyone's respective commutes, road conditions, ability to charge at work, etc., but i'm interested to know what you all do on average.
    I'm still on my first tank and have 905 miles with one bar left on my tank.
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I've owned my car for 19 months. Here are my fill ups so far:
    793.6
    858.4
    1371.8
    1134.7
    2088.2
    1798.2
    2334.4
    Biking Maniac likes this.
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Miles between fill-ups
    525
    556
    585
    547
    917
    817
    900
    49,798
    i have to look at the spreadsheet, hang on a sec.
    around 1,350.
  5. El Dobro
    El Dobro A Member
    7,003
    3,226
    I usually fill-up between 800-900 miles, but I hit the gas station when I'm down to two pips on the fuel gauge.
  6. 3PriusMike
    3,014
    2,364
    Silicon Valley
    On this tank I'm at 1327 miles and still have a full tank! (40 miles HV).
    (Yes, I know I need to use a tank every 6 months or so...some longer trips coming up in the next couple of months)
    Mike
    markabele likes this.
  7. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    Southern California is the place for the PiP...... here in Upstate NY, we've only got three months of really warm weather, making the other 9 months a challenge ......
    12/23/12 - 648.1
    2/2/13 - 746.3
    2/23/13 - 570.0
    4/2/13 - 728.9
    5/6/13 - 943.9
    7/16/13 - 1515.1
    9/15/13 - 1145.1
    current tank estimate - 950+
    Mileage is already starting to fall........
  8. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    my first and only fill-up was 4300 miles
    3 gallons down on tank #2 and 2600 miles so on pace for 8,000+
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    SWEET! (y)
  10. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Average 1000 miles per tank = once a month.
    iPad ? HD
  11. Tony Prius
    Northern New Jersey
    2013 Prius Plug-in
    Wow, these are all impressive numbers. Thanks for the responses. This may be a stupid question, but how do you check how much gas range is left? I have one bar left and am not sure how much further I can go. I know I should check the manual but you are all here...
  12. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Scrolling through the trip computer will bring you to one setting that shows the estimated fuel range. I don't have a ton of experience with it so far, but it always seems a bit pessimistic to me. I believe it also will read zero miles to go with ~2 gallons of fuel remaining.
  13. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Push the Trip button on the steering wheel until you see the DTE on the dash. It cycles between A, B, DTE, and Odometer.
  14. markabele
    5,084
    1,782
    Nebraska
    Personally I fillup once my ratio screen says I've used 9 gallons.
  15. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    that's correct and why my first fill-up was done with just 8 gallons used - the read had me concerned I was close to empty
  16. chesleyn
    596
    158
    Los Angeles
    I use the 9 gallon rule as well… but only when I know I have to drive into LA the next day and will be using fuel. If I am driving around my hood in electric, then I do not fill up until the day before I plan on using gas.
    fortytwok and markabele like this.
  17. RBooker
    RBooker Member
    154
    56
    Current tank 1,556 miles ~1/2 tank remaining
    5/4/13 1,002 miles 5.70 gallons
    2/9/13 800 miles 6.43 gallons
    11/10/12 422 miles 3.69 gallons
  18. Astolat
    Astolat Member
    229
    73
    Guildford UK
    About 825 - 850. I'm trying to make the 1,000, but haven't yet, there's always been a longer run or two where I couldn't do enough EV.
    I tend to fill up at 1 pip, though I am also normally aiming for a particular cheap filling station (cheap for the UK, anyway) on my commute. I only recently realised that what I thought was a 45 litre tank is actually only a 40 litre tank, so my 37.5 litre fill up when the one pip was blinking and my range was down to 5 miles was rather hairier than I thought...
  19. El Dobro
    El Dobro A Member
    7,003
    3,226
    920 mils on the trip odometer and down to two pips on the fuel gauge, so it's off to the gas station tonight. $3.09 a gallon. :D
  20. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Well, the price at my favourite place is only about two of your American dollars...
    Unfortunately that's per litre...
