How much should I keep in the battery to get best fuel economy?
Discussion in 'Prius c Fuel Economy' started by highroller, Apr 29, 2014.
  1. highroller
    highroller Junior Member
    78
    When battery reaches 2 bars, ice kicks in to charge the battery. I am wonder what minimum level should I keep the battery in to get best fuel economy?
    Nexus 7 ?
  2. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    It seems to me that it doesn't really matter, unless you get the batt full and still are going down hill or have to stop and end up wasteing the regeneration of breaking. it may depend on the type of driving you do. on hwy it may make a difference if the batt gets to low. but in town driving 25-35 speed limits I am getting very good mpg. today I drove 40 miles with 88.? mpg on the display. usually I drive short trips and this kills the mpg. but this tank has 420 miles and average is 64.6 on the display. I am using 92 octane e10 and the mpg seems better than 87 octane e10, most people say the higher octane is a waste of money, but it sure seems to work better in my prius c with in town driving. On the hwy it doesn't seem to help but I am only on my second tank of preimium so time will tell.
    48,999
    you'll get your best mpg's by using the engine as much as possible, and the battery as little as possible. have you heard of pulse and glide?
  4. highroller
    78
    Why is that? Isn't pulse and glide spending most of the time in the first half of the hsi?
    Nexus 7 ?
  5. bisco
    48,999
    no, it's using the ice to get up above your desired speed, (pulse) then holding the throttle so your not powering the car or charging the battery. (glide) rinse and repeat.:p
  6. highroller
    78
    Yes, but it is impossible to get no arrows in Prius c, the best glide can do is to stay a little above regen, which is ev barely. So most of the time, it is battery.
    Nexus 7 ?
  7. bisco
    48,999
    that's where you want to be, it's a minuscule amount of electricity.(y)
  8. Recharging the battery (especially at 2 bars) uses extra energy from the engine. The recharging process also has a bigger hit on your trip fuel economy if you are recharging at higher speeds.
    Staying "a little above regen" (as highroller said) uses low current. This is also what I tend to do.
    Using "a lot above regen" on all-electric uses very high current and is way less efficient since the battery drains faster... but this also implies more energy spent recharging during the trip.
  9. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Well THAT statement is grossly misleading.
    If it were true, why HAVE a battery at all. :)
    It is actually best to "glide" while not using either means of propulsion......but that gets tedious fast.
    For the average driver........just keep a light touch on the throttle and let the car do the rest.
  10. xraydoug
    571
    176
    Roseburg, Oregon
    Not sure it matters. I pulse up to just over speed limit and let off, the car swithes the ICE off, I then pull into neutral. If the road is flat or downhill you can coast for a long time without slowing down much. after you slow or someone is comming up behind slip back into D and accelerate up to just over speed limit and shift back into N and this gives very good mpg in town I have had several times with 20-45 miles showing 80 plus mpg. I am MPG OCD and try to get every mile I can without making other drivers angry. where I drive there are small hills and I try to charge going up those hills as much as I can and coast on the downhill parts.
    ps I am not sure but think this only works if speed is under 40 mph, otherwise the ICE keeps running.
  11. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Anyone who deliberately puts a car in neutral while moving is a couple of sandwiches short of a picnic.
    In a split-second emergency (like a deer jumping into your path), drivers can use any combination of braking, steering and accelerating to try to avoid a collision. To deliberately disable one of these beggar's belief; to regain full control also requires steering one-handed. This is while the emergency situation is rushing at you at maybe 100 feet / sec.
    I might add that in some jurisdictions such actions are illegal (read dangerous driving), and are likely to result in loss of your driving licence. Your insurance company wouldn't pay out on your claim either.
    GT-I9300 ?
  12. xraydoug
    571
    176
    Roseburg, Oregon
    :ROFLMAO: one always must be cautious when driving, you should know your limitations. haven't got in an accident in over 20 years. not to say I couldn't get into one, however I believe I will survive coasting at in town speeds as others are speeding away.
  13. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Yes yes yes, driving in neutral is illegal in many states and not advised due to safety concerns. But I can't judge.
    Keep in mind that a charged battery is a happy battery.
    When the battery is low - you mentioned 2 bars - the ICE is working to propel the car and recharge the battery. All that really awesome mileage you just drained the battery for will be undone by the period of recovery.
    The theory of pulse and glide is that you should be able to glide farther than you pulsed. Also keep in mind that pulsing is not pedal-to-the-metal. You pulse with relatively brisk acceleration depending on the current situation: traffic, terrain, etc. There is no concern about the trickle during the glide because if done correctly you will be replacing most or all of it during the pulse.
    But since I find it incredibly hard to pulse and glide all the time - and ridiculously boring - I simply try to find the pedal pressure sweet-spot and ride that. You will keep your battery very well charged which will keep it happy and it will reward you will high mileage. That pedal pressure sweet spot is different for every part of your drive so there is no real formula; you just have to feel it. Too slow and the car's working too hard to maintain momentum; too fast and the car's working too hard to maintain speed.
    Mabarking likes this.
