How to adjust the MFD night brightness on your Prius v
Discussion in 'Prius v Audio and Electronics' started by Cristino, Nov 12, 2012.
  1. Cristino
    Cristino Junior Member
    45
    22
    Bayamon, Puerto RIco
    I have a v Base (no GPS) but this probably will work with other models too.
    1. Park in a dark garage or cover the light sensor
    2. Turn your car on (READY mode)
    3. Turn on the radio and press SETUP
    4. Press Display (Top right of the MFD), the DISPLAY SETTINGS screen appears.
    5. Turn on the lights. The MFD should dim and the DISPLAY SETTINGS screen will change. If it doesn't, some light is being detected by the light sensor. Please make sure it is well covered
    6. Press GENERAL
    7. Mine is set with the contrast full left and the brightness at 2 pips right of center. Press >> to change between brightness and contrast. Remember you're setting the NIGHT brightness. Press OK then BACK when done.
    8. To set the daytime brightness and contrast, turn off the lights at the DISPLAY SETTINGS screen
    Hope this is useful... :)
    Chazz8 likes this.
  2. GerryL
    GerryL Master Model Railroader
    170
    Minneapolis, MN
    THANKS! I didn't realize it would do that and was just thinking the other night, while driving at night for the first time, how bright that screen seemed.
  3. Cristino
    45
    22
    My pleasure! :)
