HOW TO DIY: JDM Folding Mirrors with Signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sfv41901, Jul 1, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Glad the write up helped.
    As far as I've seen, what u noticed, its normal.
  2. talkin73
    talkin73 Junior Member
    49
    Washington DC
    Thanks very much!
    sfv41901 likes this.
  3. shaotai
    shaotai Member
    34
    38
    Seattle, WA
    Hey all,
    Anyone complete the install with the newer lighted switch and folding relay/harness for the 2012+?
    First thing is the new harness doesn't have the first/last wires in place for the switch to light up!
    Secondly, the folding part doesn't seem to work at all. I'm a bit stumped, as I think I have it all wired up.
    The puddle lights, parking and turn signals all work great. If I manually power the motors, they turn just fine also.
    Not sure if it's a defective power mirror relay.
  4. ncases
    ncases Senior Member
    609
    672
    Chicago
    Cathy from topsage asked me about my 2012 prius if is facelift or after facelift. I emailed her back and asked to elaborate? Any Ideas? Which one did you guys ordered for the auto folding mirrors for 2012?
    #224 ncases, Mar 14, 2015
  5. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    I believe she means before "MC" and after "MC" like www.autostyle-usa.com states on there Prius/zvw30 front lips. I'm assuming and someone correct me if I'm wrong but "MC" stands for mild change? Before "MC" or as you said she stated preface lift would be 2011 and before and after facelift/after MC would be 2012 and up as they had a slight chance to the front end.
  6. ncases
    609
    672
    Chicago
    Thank you.
    Accordlayingkit likes this.
  7. shaotai
    shaotai Member
    34
    38
    Seattle, WA
    Just an update on my install of the folding mirrors. I ordered the newer style illuminated 2012+ folding switch with the new harness.
    I had some really odd behavior and thought it might have been my wiring. Turns out, it was the harness! The ACC and ground were switched and fortunately, nothing bad happened, except just it never worked.
    Top Sage has since updated their wiring harness and diagram! (See pic below)
    I'm still having an issue though! The new style harness comes with both lock trigger wire and unlock trigger wire. (Assuming the unlock was optional)
    The first time it locked via keyless entry, it folded and everything was great. Started the car/ACC and it unfolded.
    But after the first time, the keyless doesn't trigger the fold anymore... (?) Mirrors still fold manually with the switch just fine.
    It seems like the unlock trigger needs to be added, but I'm not sure. Anyone know where this unlock trigger wire is at?
    #227 shaotai, Mar 21, 2015
    Dylan Doxey likes this.
  8. ncases
    609
    672
    Chicago
    Hmmm. I think this would be my problem when mine arrives in the mail next week.
    Starbrand likes this.
  9. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    just search ebay with this it is cheap and does the job "Amber Soft 9smd Led For Car Side Mirror Turn Signal Indicator Light MA299"
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The unlock would be of the same gauge as the lock wire but with the black strip.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I have installed both the controller with & without the unlock wire. It's not a requirement for the mirrors to fold when lock.
    Did Cathy replace ur controller when they gave u a new harness? If not, it could be that the controller got damaged with the incorrect harness.
  12. shaotai
    shaotai Member
    34
    38
    Seattle, WA
    Cathy actually didn't replace any of the parts. At least not yet. I ended up splicing the reverse tilt harness with the correct wires.
    The relay still does work, just not consistently. I'll try the wire with the black strip, see what happens.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I would have her replace the controller since its not working consistently. During all of my installs, I've only needed to get 1 replacement controller as it was malfunctioning
  14. Burna J
    1,063
    3,331
    53
    Long Beach, CA.
    Don't bring me in to this....... LOL !! :rolleyes:
  15. ncases
    609
    672
    Chicago
    Just received mine today and will be installing in a day or 2. Will let you know.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Haha......no 1 mention UR name.....but since u here......
    Burna J likes this.
  17. ncases
    609
    672
    Chicago
    image.jpg Noticed on the harness has 3 wires to be wired but on the instruction it was only 2. image.jpg
    Here's the module. I guess its different for 2012+.
  18. ncases
    609
    672
    Chicago
    Thats right there is a central unlock and lock.
  19. ncases
    609
    672
    Chicago
    Hi Sean. I would like to ask your expertise. Which wires(from the harness) should i tap the green and blue wires thats coming from the autofolding mirrors? Thanks for your help in advance. Im not sure but i think on the green and blue wire after that 1st black wire. image.jpg
    #239 ncases, Mar 23, 2015
  20. shaotai
    shaotai Member
    34
    38
    Seattle, WA
    Yes, that is correct. Look at the updated harness break out picture they sent me. DSC_0073-M.jpg
    Also, your relay is very different from the one I got. That looks solid, with aluminum casing.
    Here's mine.
    Good news is that they are sending me the updated harness and relay, as it is not functioning properly.
