How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. Fly
    Fly New Member
    This worked like a charm, and so I logged in mostly just to say, thank you very much!!
    However, as I seem to have an endlessly inquisitive mind, might you also share with us how in the world you were able to identify the precise components and sequence of the "chicken dance"? It doesn't seem likely that it's set out in a service manual anywhere...
    Anyway, thanks again for helping out what I'm sure are a ton of grateful people.
  2. usnavystgc
    3,159
    988
    Tucson, AZ
    First, I didn't develop or figure out anything. This was originally published by a Toyota Service Rep (to the best of my knowledge) back around 2005. But of course, it got lost in the sheer amount of threads on here (it is still available but hard to find). I put together this sticky because I just thought the info was too valuable to lose and I was trying to make it easier for people to understand. The only credit I deserve might be the idea I came up with to make it a sticky and to refine the procedure so all could understand.
    Isaiah54 likes this.
  3. lost_mesa
    lost_mesa Junior Member
    Sant Fe New Mexico
    I just purchased a new SKS FOB, Part #89994 47061 from Daytona Toyota, through Amazon.
    I can't get part B of the programming to work. This FOB has a black logo on the back, not silver. Is the silver logo the definitive indication that it is a SKS FOB? At this point I'm not sure if they sent me the wrong FOB, or if I just don't have the chicken dance down right.
    Thanks
  4. jackson5
    jackson5 Junior Member
    san diego
    Dear USN: Thanks so much for your patience in this thread. I have a question (I may have missed it reading all the threads):
    Both my fob black Keys to my 04Prius have lost their functionality to lock/unlock though they work fine when inserted to operate the car. Can I use the 'chicken dance' to program new keys, or is it more serious (i.e. a trip to the dealer)?
    Thank you.
  5. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    Sounds like you need new batteries for the fobs.
  6. usnavystgc
    3,159
    988
    Tucson, AZ
    If you're trying to program a black logo fob, you should be using procedure C. If they sent you a black logo fob and you ordered a SKS fob, they def sent you the wrong part. The silver logo is the definitive indication of a SKS fob.
    I'm betting you can. I would replace the batteries in them before doing anything. There is likely nothing wrong with your old fobs. I would take them apart, clean them up with alcohol and let them dry out, then replace the batteries.
    PS: Can you delete all of post #165 and replace it with a period (click on edit, highlight all and replace with .)? I'm trying to keep this thread clean.
  7. jackson5
    san diego
    Thanks: This worked like a champ and will save me a trip to the dealer
    PS: Can you delete all of post #165 and replace it with a period (click on edit, highlight all and replace with .)? I'm trying to keep this thread clean.[/QUOTE]
    Willco.
    P.S. I looked at the U-tube video (a previous post), cut the rubber around the alarm, and restored functionality with a new battery. I've ordered a key from Amazon since it's looking pretty bad and will let you know how the programming goes. Thanks
    usnavystgc likes this.
  8. JC91006
    16,470
    8,384
    You don't really have to make a slit in the fob, just stab the edge of the stuck button with an exacto knife and lift up. This will free the button and won't deform the fob
    jackson5 likes this.
  9. jackson5
    san diego
    Success with programming the BLACK fob!
    I was able to program a new "non SKS" fob with some struggles. I know that this is mostly an SKS thread, but here's my experience with procedure C. Like most, the ON/OFF programming was straight forward I then tried Procedure C, but no joy. I got to step 10, one lock/unlock cycle (not 2) but subsequent steps didn't work.
    I found a slightly different procedure under a different thread:
    Finally! How to program a non-SKS key/fob. Detailed!
    Read more: Finally! How to program a non-SKS key/fob. Detailed! | PriusChat
    Post #68 in this thread from Scott121. His procedure finally worked, and many others reported success also. You might want to post this as "Procedure D" or make a note that if Procedure C doesn't work (I think it did for some people), they might look up this modified procedure.
    Also there was an interesting discussion about a limit of 128 programming tries from robH in this thread. Although I flapped my wings and did the chicken dance several times, fortunately I didn't reach this magic number. But this might explain why some used fobs couldn't program. There was speculation that this limit didn't apply to the silver (SKS) fob.
    Thanks USN. In the end I spent more time than I expected, but I saved many $$ by ordering this $104 key and reading the comments in this thread I even resurrected one of my old black fobs.
    Cheers,
    Gary
  10. Claster
    Claster New Member
    I tried a number of times and nothing was working, until I tried the chicken dance as an uptempo number, and then everything worked great.
  11. Leesburg_Dave
    Leesburg_Dave New Member
    Just purchased an 06 Prius with only one fob. I ordered a new SKS from a dealer through Amazon and the Procedure A followed by Proceedure B worked perfectly. It took me a couple of tries to get it right. It seems easy when you read through it but doing it for real seems to require a rehearsal or two! Thanks for posting this. Saved me close to $100.
    usnavystgc and PriusGuy32 like this.
  12. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
    Gotta love this site!! (y)
    On a side note, a few pages ago in this thread, I bought a new SKS fob off amazon and programmed it, after my original SKS fob stopped working. Well, someone posted something on fixing the prius fob by cutting it open, yesterday I was cleaning the junk drawer and found the broken fob; I was about to pitch it and figured "what do I have to lose?" I cut the unlock button open, bent it outward, put a battery in it and now I have a third working key fob! Bonus. :)
  13. mjay
    mjay Junior Member
    I bought a replacement SKS (silver logo) Fob on eBay from a Toyota dealership for about $95. Received it in the mail today, and had it working in less than 5 minutes. The only problem I had was that my wife couldn't stop laughing while reading me the instructions!
    Thanks for all of your effort in getting this procedure to the masses!!
  14. JC91006
    16,470
    8,384
    $95 wow, they've come down a lot
  15. orgil
    orgil New Member
    Toyota
    Is there any chance used /old/ key to clone my working smart key?
  16. JC91006
    16,470
    8,384
    best to buy new, it'll be cheaper in the long run. A used key needs to be reseeded, which will be more than the new key cost...in most cases
  17. Isaiah54
    Isaiah54 Junior Member
    South Chicago
    Thanks for posting this! You saved me a lot of money. This was great I have done 2 keys this way.
  18. JimInRadfordVA
    JimInRadfordVA Junior Member
    Radford, VA
    Our new (used) 2008 came with only 1 remote so I bought a new SKS fob from Daytona Toyota for less than $100. Followed the "Chicken Dance" instructions and stuck the landing on the first try!
    Thanks to all the great members of PriusChat.
  19. PriusGuy32
    1,411
    506
    Welcome to PriusChat and congrats on your Prius!!
  20. scotrinaf
    scotrinaf Junior Member
    37
    Blountville, TN
