How to wash engine compartment?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by web1b, Apr 15, 2011.
  1. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Pressure washers can force water through the seals on connectors. It's also bad to use on brake calipers.
    Both Pearl and Pearl S have been cleaned with a garden hose. Then by hand using a mitt (there are a lot of sharp edges under the hood). Then rinse with the garden hose. If there are any areas that oil or grease has stained, a paint brush with varsol cleans that up just fine, followed by the garden hose.
    I do not try to avoid any areas with the garden hose. Remember, underhood can get very wet when driving in heavy rain. It's all "water resistant" (whatever that means).
    I wash under the hood in summer, on my backyard lawn. The "contaminants" have so far not harmed the grass or weeds. In 40+ years. ;)
  2. Mendel Leisk
    38,961
    All I see on ours is dust, so I "dust" it, very occasionally. Use a paint brush or two, a "boa" style duster pushed through gaps between components, a wet/dry vacuum to vacuum what I can, and a leaf blower to really get in the corners.
    It pretty much looks like new.
    #42 Mendel Leisk, Aug 22, 2016
  3. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    The electrical connections are sealed. I don't use a high pressure spray, which could force water in or knock things loose. Just a soak.
    And never pour water on a hot engine.
    Another thing -- the silver-colored plastic piece over the oil cap comes right off for cleaning. Just life it straight up. Not towards you, but straight up. It just snaps on and off. So you can scrub it really well, although there's a sticker or two that you want to be careful with.
    #43 Rebound, Aug 22, 2016
  4. nicoj36
    nicoj36 Active Member
    499
    159
    I washed mine with a high pressure hose from the coin-op wash and I never had any problem except the engine was so clean. Just make sure you don't over-wash it and just do it really quick. And give it time to dry or wipe it down. When I washed my engine, it was a 95 degree day so the engine dried just a few minutes after the wash.
  5. rhythm0699
    rhythm0699 New Member
    Bangladesh
    Is there any problem if i clean the engine bay daily using a blower only ? in my area the environment is so dusty.
    SM-G935F ?
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I don’t see a problem with that. Here’s how we cleaned ours
    m.wynn, RMB, Grit and 2 others like this.
  7. Mendel Leisk
    38,961
    No problem. I've used a few brushes coupled with a leaf blower, and/or the blow side of my wet/dry vacuum. Our area's not very dust though.
    rhythm0699 likes this.
  8. Kingsway
    Kingsway Active Member
    114
    116
    Cambridge, UK
    2014 Prius c
    Active
    Amongst the many, many You Tube videos on this subject - I quite like this one where he uses aluminium foil to protect certain areas from water...
  9. tacopyro
    tacopyro Member
    82
    Los Angeles
    just to add, a more specific video of the above.
  10. Mendel Leisk
    38,961
    Meh, asking for trouble.
    bisco and Raytheeagle like this.
  11. Rebound
    3,964
    2,615
    Portland, OR
    I’ve used that approach many times, except I always remove the silver plastic “Hybrid Synergy Drive” cover. I also remove this before oil changes.
