HVbattery techstream diagnosis of the hybrid battery pack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doctorman, Apr 21, 2015.
  1. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    He did not. If you start with a reasonable battery, A grid charger is capable of slowly balancing the whole battery at once. Then you can use readouts from the battery ECU to see the health of your HV battery. I did individual module balancing, but the grid charger should be able to do a sufficient job.
    JeffD
  2. doctorman
    doctorman Member
    163
    30
    NY 11020
    Just got the call from Toyota.. they are ordering the battery under warranty!!!! woohoo!
    mileage on the car is like 99940.
    the tech advisor is like you know you have traction light etc etc on as well do you want us to diagnose that..
    either they are stupid and dont know how to use techstream and read codes and see that is all from the HVbattery or trying to squeeze some money from me. oh well I dont care I got a new battery
    m.wynn likes this.
  3. JC91006
    16,470
    8,384
    good deal.......FREEEEE
    Is your car actually under warranty or is this a "goodwill" that they are doing?
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    No either about it.
    Congrats!. Just so you know, you have caused a big headache here for the people trying to understand when Toyota extends warranty assistance. The only moral seems to be to always ask.
  5. doctorman
    doctorman Member
    163
    30
    NY 11020
    there is NO GOOD WILL with toyota with a 4000$ job as they quoted it. they would maybe help with some but it would not come under 2K$.
    Toyota Warranty on HVbattery follows the State the car is registered at and that states Emission regulation.
    Honestly even now I am not sure exactly how it works
    I got bits and pieces here and there
    1) called dealer, dealer said I have to call 800# to find out about warranty
    2) called Corporate and was told in NY CARB regulation was adopted since 2008 but my car was from 2005 so it should not apply , so original 8years 100K will apply
    3) called corporate again I was told in NY and CA both the Warranty is 10 years 150K so I am covered , got the reffrence number of that conversation and used that to push everything else through..
    4) called dealer and was bounced about 4-5 people from tech adviser to customer relation to general adviser at last an advisor was officially assigned to me and he said based on VINnumber I have 8 years so no warranty
    I said I have ref. # from corporate that says I do .. back and for th him and his supervisor etc he came back and said in NY is 10 year/100K
    in CA it is 8years/150K so I am under warranty if I am under 100Kmiles.. I said I have 99K and asked him to note my case that my car under 100K has Hybrid warranty.
    so now I have my case noted by dealer and a ref# from corporate I took the car in
    took them 24 hours and 3 calls to get the car diagnosed and order the battery.
    they should have the battery in 5 days.
    so lots of headache but brand new HVbattery from toyota was worth it.
  6. bisco
    49,046
    sounds right.
  7. JC91006
    16,470
    8,384
    interesting outcome. The confusion might have worked in your favor.
  8. doctorman
    doctorman Member
    163
    30
    NY 11020
    thanks JC for the offer on the modules.. seams like I wont need them.
  9. JC91006
    16,470
    8,384
    lol. sure n/p
  10. SageBrush
    11,627
    2,530
    Southwest Colorado
    Exactly.
    I cannot imagine why the dealership would fuss once Toyota had authorized the warranty work.
  11. doctorman
    doctorman Member
    163
    30
    NY 11020
    got my car back with a new HVbattery.
    need a state inspection but cannot get it since the computer is reset so the car has to go through drive cycle
    in case if anyone is interested the way to do it is mentioned in the service manual 1NZ-FXE ENGINE CONTROL SYSTEM
    Page 22 ES–22
    3 tests need to pass
    Catalyst
    O2 sensor
    evaporative test
    it could be done easily in 6 hours duration with 15 min driving
    I used techstream to put the car in inspection mode for 5 minutes to increase the coolant temp to 177F then drove it for 15 min before O2 and catalyst passed the test, then let the car cool down for 6 hours and do the evap test.
    my toyota dealer offers free state inspection I guess in hope of finding issues to make you pay.
  12. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    If anyone sees this later and has issues with their pack after looking at the techstream output I would have suggested that block 3 is the actual cause of all the codes. You can see it from both the voltages under load, all are 15V+ while the "bad" block is 13.88v and the internal resistances are all 0.24-0.25 with the exception of #3 which is 0.29 ohms. Obviously it all worked out for you but this battery should be a pretty easy one to rebuild if someone were needing to do it themselves.
    doctorman likes this.
  13. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    I'm quite sure NY adopted CARB in 2004, including the Toyota 10/150 warranty. Hopefully whoever said 2008 was making an honest mistake. Just so other NYers reading this don't think they are 8/100 if their Toyota hybrid is '07 or older.
    Excellent result, doctorman. A brand new Toyota battery right at the end of the warranty is indeed a dream scenario!
    #33 m.wynn, Aug 10, 2015
  14. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    In order to reset the emissions monitors to prep the car for emissions test you should just have to drive about 20 miles, some highway, some city, or just drive the car normally for a day or two. If no warning lights come on there is a +95% chance you will pass the test. The procedure in the service manual is overkill.
    The I/M monitors reset whenever you clear codes and/or unhook the 12V battery. Until the car verifies all emissions related systems are working correctly you cannot pass an emissions test. Test stations implemented this procedure so people with unhealthy cars don't just "clear the codes" a block away from test station and head right over.
    You can verify that I/M monitors are "READY" using most OBD2 scanners. (autozone/oreily etc) Most states allow 1 monitor incomplete, but it cannot be O2 Sensor or Catalytic Converter. (often the Evap monitor is not complete, but that should be ok for the emissions test).
    m.wynn likes this.
  15. Kevin Cecchini
    Kevin Cecchini Junior Member
    44
    Clinton, Michigan, 49236
    Hello I am Kevin.
    I have purchased three cells off of ebay for my 2004 prius and I have just purchased the $400 grid charger.
    Is my plan appropriate...
    -Remove battery
    -replace two bad cells
    -install battery
    -install harness for charger (assuming it comes with charger, I purchased the one for 2004-2009 prius')
    -plug charger into outlet and let sit for 24 hours
    -install the auxillary battery, replace since it is bad
    -reset the codes using the manufacturer check system
    -take car on test drive
    -if all is well replace all the interior of the hatch
    is this a good plan or do I need to do something else?
    thank you
    Kcecchini @ wccnet . edu
  16. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Pray that the modules you bought on Ebay are good.
    Good luck with the repair.
  17. 3prongpaul
    954
    716
    Actually pray that all the modules in the pack end up with similar voltage, capacity, state of charge, and internal resistance. The battery ECU will generate error codes if the blocks have too much variance from each other.
    If they are all equally crappy, the car won't code, but cars performance won't be as good.
    Mixing great modules with bad ones is a short term fix.
  18. jadziasman
    1,355
    487
    District 6
    I recommended to Kevin that he would be better off buying a new pack from Toyota in a thread he started.
    Instead, he opted for "damn the torpedoes".
    #38 jadziasman, Dec 31, 2016
  19. Kevin Cecchini
    44
    Jadziaman, I do appreciate your recommendation on purchasing a new battery, however, I am a bricklayer, which in Michigan is seasonal work. therefore, I cannot afford the $2000, $3500 for install fee at this time.
    I am hoping that I can limp along, while saving lots on fuel economy, will help me to save for a new battery pack. or refurbished, which I got a quote for a refurbished battery pack, with new auxiliary battery, and install, for $2700.00.
    a shop in Southfield. I asked them if they could replace the bad modules and they replied that they do not practice that as they like to keep their customers happy, since replacing single packs would only by time and not fix for good.
    so as of now, the prolong charger is connected, chaging, and still waiting on the battery packs, which I asked for a refund and I got the refund, and supposedly the three packs are still on their way. I order them Dec 17th. hopefully I wont need them.
  20. Kevin Cecchini
    44
    Good to know 3prongpaul, thank you for the information. at this time I only have the prolong charger connected and charging.
