I accidentally connect the positive to the car body with a wrench, car won't start.
Discussion in 'Newbie Forum' started by james089, Sep 27, 2014.
  1. james089
    james089 New Member
    waltham, MA, USA
    I accidentally connect the red positive in the fuse box to car body with a wrench, car wont start, there is no power at all, the door lock does not even work.
    what should I check now? I prefer DIY to fix it...save some cost, please help here. what fuse should I check
    I own a 2004 Prius.
    Thank you in advance!
  2. Mike500
    Mike500 Senior Member
    2,593
    763
    You probably burned out a large fuse or fusible link.
    Also, check the voltage of the 12 volt auxiliary battery.
    james089 likes this.
  3. james089
    james089 New Member
    waltham, MA, USA
    Thank you so much for the reply, Mike, I will check it, by the way, I will appreciate it if you could tell me where are those possible fuses located? I mean what fuse box are they located ?
    I know in my 04 prius, I have fuse box located 1 under the hood, 2 instrument panel 3 luggage area.
    thank you!
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Look for an owner's manual, either on paper or online.
    There likely are other things in there that you need to know.
    P.S. Is that "hot" point not supposed to be covered by a red plastic protector of some kind ??
    If you were about to disconnect the battery itself, you should ALWAYS disconnect the negative cable first and reconnect it last.
    KK6PD and james089 like this.
  5. james089
    james089 New Member
    waltham, MA, USA
    Thank you so much, Easy Rider 2. I never disconnect a battery before, and thank you again for the helpful safety reminds for removing the 12v battery in the trunk.
  6. bisco
    48,999
    i'm not positive, but the big fuse might be in the battery case.
  7. james089
    james089 New Member
    waltham, MA, USA
    Hey, Rude person's and Easy Rider 2 and bisco, I would like to say thank you to all of you.
    I did as the Mike suggested, checked the fusible link, it turns out that it is the 120 AMP fusible link in the trunk got blown ( in the manual it says "fuse #50 main: hybrid system" located in luggage compartment). Thankfully there was no other damage ( I just got the car few days ago!)
    I went to AutoZone and bought one Bussmann 120 AMP fusible link that matches my model (BTW, in order to get the fusible link/fuse out, since it is bolted on to that "thing" above the battery, I need to take off the brake control unit first and take off that "thing" from battery (there is this YouTube link I watched and feel might be helpful. ) I also used 10mm and 13mm socket to remove the bolt.
    Put it back, positive first, then negative :)
    My 04 Prius comes back to live!
    I hope this information can help someone else in the future, just in case. :p
    #7 james089, Sep 28, 2014
    ftl likes this.
  8. bisco
    48,999
    well done, congrats!(y)
