i need help for my prius
Discussion in 'Gen 2 Prius Technical Discussion' started by samtek002, Aug 31, 2015.
  1. samtek002
    samtek002 New Member
    pretoria
    I am having problem with my 2005 prius car, not starting and reading Dtc: P0a0d .Though I bought it from auction. knowing it wasn't starting and when dignose it at first, it was showing B2799 immobilizer but the code was later clear by my mechanic and now showing P0A0D. high voltage input or so But Now i have changed the Ecu and got new 12V battery and still not start but the code error(P0a0d)is gone and now its P0AA4. Please anyone with what might be wrong again.
    48,996
    now you're in the right place, a lll the best!(y)
  3. samtek002
    pretoria
    All the best? am yet to sort it out sir.
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
  5. samtek002
    pretoria
    Tc400, How long have you been battling with the code issue and did you do anything on it too
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    Definition of check engine code P0AA4:
    Generic
    Hybrid Battery Negative Contactor Circuit Stuck Closed
    is the orange safety plug pushed all the way in and the handle flipped down and locked?
    start looking for breaks in the wire harness
    or sell it and cut your loses
    pashko90 and TC400 like this.
  7. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I am not dealing with this code. It was a thread I found that may help you with your issue(s).
  8. samtek002
    pretoria
    if only i can sell it that way or do you know the solution please? am stocked
  9. samtek002
    pretoria
    please who knows where the 2 relays at the back of the big battery is ?
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There is a lethal amount of electricity in the big battery.
    Watch at least the first 6 minutes, then from 18 minutes on. Once inside there is no safety protection but high voltage gloves.
    pashko90 and greasemonkey007 like this.
  11. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    Trouble code : Hybrid negative terminal stuck open.
    1) you didn't pull service fuse all way down or it have a opening(fuse is blown)
    2) your negative battery conductor is bad or switching circuit is open. You can swich positive and negative and take a look on Troble codes again. Cleaning conductor switching surface may help as well. Need to find good trobleshooter. Mechanic guys rare can troubleshoot good.
