I need to rebuild my battery...anyone have lipo chargers for sale?
Discussion in 'Generation 1 Prius Discussion' started by Mr.Kenny, Jun 5, 2013.
  1. Mr.Kenny
    Mr.Kenny New Member
    Springfield, MO
    2001 Prius
    I
    I'm a new poster, but a long time lurker.
    I bought Dustin Langston's 2001; and fixed the complex braking system myself; but now it looks like there is an imbalance in the traction battery.....code 3006. Triangle etc...
    Dustin Had "rebuilt" the battery pack a year ago with the newer 2004-2007 batteries; but I don't think they were ever balanced.
    I checked all the voltages; (7.92 to 7.88) so there was nothing obvious, I hooked them all up into a inline series to balance the voltage...... finished with 7.85 volts across the board, then left them alone unhooked for a couple of days. They all stayed within .01 of a volt....nothing obvious. Put it together drove it one mile, and the "bang, boom, whir, triangles, lights, revving engine, etc......
    So I need to balance and find the offending module(s).
    I was just wondering if anyone has some battery chargers they want to sell, or a rebuilt battery or suggestions.
    (I have read a few threads about rebuilding;... gulp)
  2. bwilson4web
    15,407
    Welcome to the world of older Prius. My first thought is you need a proper diagnosis and that mean a Prius-aware scanner. There are 19 pairs of modules but at a minimum, you need:
    • maximum pair voltage and index
    • minimum pair voltage and index
    But I would recommend getting a scanner that can record all 19 pairs and the four temperature sensors. Also, do not rule out a possible broken sense wire. The modules could be perfectly fine but if you have a cracked sense wire, the control computer will see the voltage changes even though the modules are OK.
    A secondary indicator is excessive heat. A failing module will run hot. In the worse case, it can turn on the battery cooling fan.
    Don't rule out loose nuts. We've had one poster who was a little 'casual' with his electrical connections and didn't really discover it until driving around after sun-set where he could set the colorful display.
    GOOD LUCK!
    dave77 likes this.
  3. Mr.Kenny
    Mr.Kenny New Member
    Springfield, MO
    2001 Prius
    I
    Thank you Bob.
    I guess I should get a proper scan, or scanner before I do much of anything else.
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    Mr. Kenny, where is the car located? (someone with expertise may be close to you)
    If you can get visibility into the 19 blocks (Techstream is best) or at least min and max block#'s (scangauge??) drive the car in reverse uphill. This will give useful info since reverse uphill stresses the battery more than anything (ok perhaps driving uphill in reverse in 100 degrees weather will stress it more).
    dave77 and bwilson4web like this.
  5. Mr.Kenny
    Mr.Kenny New Member
    Springfield, MO
    2001 Prius
    I
    I live in Springfield,Mo (i just updated my info)
    I am going to order the knock off china techstream since it is only $26.
    I am not one who "throws parts at cars" until I find the fix. I like to know what is really wrong with a car first.
    I really appreciate the help and expertise; the learning curve for these systems is quite steep.
    bwilson4web likes this.
  6. 3prongpaul
    954
    716
    The "Mangoose" mini VCI clone cables work best on a native Windows XP laptop. Best to use an old computer with XP operating system if you can. If you don't have one they are cheap on Craigslist/Ebay (although you'll most likely need to plug in the wall or replace the laptop battery if it's an older computer)
  7. MortenAZ
    MortenAZ Junior Member
    26
    Phoenix AZ
    I have a charger that I'll be willing to sell. They are the really nice mrc 989. I used them to rebalance a couple of batteries.
    Nexus 4 ? 4 Beta
