I was robbed......
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ameliapalooza, Feb 1, 2010.
  1. ameliapalooza
    ameliapalooza New Member
    colorado
    Ok so I called the prius tech today, When i asked about replacing connectors He said the sensor casing is broken ( not quite understanding how) not just connector and wire at pin one so there is no way to keep debris and moisture out. Informs me replacing connectors wont fix my issue. Does this sound correct? I'm thinking super glue......
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Amelia, registering your car's VIN at http://www.toyotaownersonline.com/index.html will get you the service history at the dealers. You're in good hands here. Once the car is patched up you should be very happy with it. Keep us updated.
    Prime Example likes this.
  3. Patrick Wong
    18,210
    6,510
    If you would like comments on this, maybe you might take a few sharp photos of the area in question, and post.
  4. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    I sent you a PM but to answer this question I think the tech is confused on what is actually the sensor. The actual sensor is a part of the motor windings so he would not be able to see it at all. What seems to be damaged is the double sided plug as that is what actually has the seal on it.
  5. jelloslug
    813
    55
    Greenville, SC
    This is what the double sided connector that bolts to the side of transaxle looks like:
    My guess is that this is was is damaged.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Did the OP even use Carfax? She said she bought private party.
    To the OP, I'm sorry. That's a mess. I wish I had something better to tell you. Legal action against the seller would be possible, but time consuming and with no real guarantee of result either. Did he make you sign anything when you bought it? Unfortunately sometimes these scum bags are very well versed in covering their own butts. If you signed anything that suggested you knew you were buying a product "As-Is" then your just in trouble.
    When I was young, I made a few really bad car purchases, lost a lot of money just being unwise as to what to look for, and know when making a private party used car purchase. If it makes you feel any better you are not alone. It happens. Psychologically I would usually compound the loss by for some reason investing into fixing the vehicle, then being so upset about the experience that I would then sell it at a big loss. But I felt I was creating better Karma in the world. I was taking something "bad" making it better and passing it along to someone else in better shape than I had....but that psychological quirk probably cost me thousands of dollars.
    In anycase good luck. I hope you can find some level of resolution that works for you.
  7. Radiant
    Radiant New Member
    148
    17
    NE
    I cannot repair cars, so I can't tell you how to fix a thing. However, I have noticed you have only taken the car to one dealer and taken that dealer's word that you absolutely need these repairs and there is no other way. Actually, it seems the only information you have that the car has been salvaged is from the dealer, right????
    Have you considered taking it to someone else - maybe someone here can give you the name of a trusted auto repair in your area?
    Just tossing out some ideas here.
    Fern1461 likes this.
  8. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hey at least you can feel good that you just didn't dump the problem on another unsuspecting person. For that you should get the "atta boy" :cheer2:
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    too bad u 2 were not closer together since jello actually rebuilt a salvage vehicle on the cheap, he would be a great source of info
  10. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I had the same error codes when I rebuilt my Prius. I think Jelloslug is correct. You can get the connectors from Toyota parts, and I have extra pins that I found that work if you need them, or you can get them from Steve Woodruff. Bring it to a shop that specializes in electrical auto work, and have them change the parts. It should not be expensive, and it should fix it.
  11. nthach
    nthach New Member
    174
    Carfax can lie, it is NOT an infallible system. Some accidents or events aren't even reported by the insurance companies whose databases are what Carfax draws its data from.
  12. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    I had one lie when i bought a 2006 slk :(
  13. ameliapalooza
    colorado
    Re: I was robbed......update
    Hello everyone. I want to thank you all for your wonderful help and support with my issues. jelloslug thank you for all your time and effort. You have helped me in many ways and your were right on with the issues with my car.
    I was not able to fix the car my self however a friend actually towed my car to Indiana where Steve Woodruff was able to inspect and repair the entire vehicle. The cost of the 5 day trip to Indiana plus repairs was far less than the cost of repair at the dealers ($9000). The repair its self was only about $1000 which also included some welding (Toyota did not mention I had portions of the front end that were not welded to the frame like they should have been.
    I can now say I feel 100% safe and confident in driving my vehicle.
    Jelloslug, I want to thank you again. You have been a blessing.
    Amelia
  14. Patrick Wong
    18,210
    6,510
    Hi Amelia,
    Thanks for providing the resolution to your story, glad it had a happy ending and that Steve Woodruff's shop did a great job at a fair price.
    I agree that jelloslug has developed tremendous Prius-specific knowledge which he freely shared with us while he rebuilt his Prius in 2008.
    confusedagain likes this.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    All's well that ends well.
    Tom
  16. ameliapalooza
    colorado
    Patrick ,
    You are very knowledgeable your self. The codes dx and list of problems you sent were exactly the issues I had.
    You put a lot of effort into my issues without you and jello I would not be driving my car.
    Thanks again
    Amelia
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    can tell you how happy i am that you found a solution that works for you Amelia!! stay in touch. would love to know what you think of you Pri , now that is works as it should!!
  18. preeyus06
    preeyus06 New Member
    O.C.
    wow. some good guys on this forum. glad this has a happy ending
  19. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yeah. Welcome to Priuschat.
  20. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    Will you still seek some redress against the seller?
    Ok qbee42 leave this one alone there are NO sexual conotations intended and even if there were I think she'd look very nice with a brand new seller bought expen$ive dress in the $1,000.00 range! :p
    Welcome to Priuschat :welcome:
