Ignition Switch: Technical Differences betwen 2010 & 2012
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PixelRogue, Jul 27, 2016.
  1. PixelRogue
    317
    57
    US
    Other than the color, are there anybtechnical differenxes betwen the ignition switches of a 2010 Prius Gen ||| Trim V and a 2012 PiP Advanced?
    Plastics seem identical, harness clips seem inter-changeable. Will either car know if the ignitions were swapped?
  2. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I swapped out my 2010 Start button to one that is 2012 -2015 and it fit fine.
  3. PixelRogue
    317
    57
    US
    image.jpg image.jpg Not sure if this would be coincidence, and not wanting to experiment just yet by swapping them back.
    2010 Prius started with a dashboard error - before the ignition swap. OBD2 reader is not picking up any errors.
    Today (same day) the 2012 PIP started with a warning message - post ignition switch. Wondering if there mught be some extra connector in the wiring for the PIP?
  4. mrbigh
    3,686
    699
    Long Island, NY
    did you see any extra connection terminals on the switch the socket???????????????????
  5. PixelRogue
    317
    57
    US
    Maybe it was the heat? Messages vanished on both vehicles within a day...cars are running fine. So weird.
    Oh, and no did not notice any difference in terms of connectors or wires between the two.
