I'm curious; if the engine runs out of oil, will it shut off automatically?
Discussion in 'Gen 2 Prius Technical Discussion' started by herqulees, May 22, 2015.
  1. herqulees
    herqulees Junior Member
    59
    24
    Tennessee
    Title sums up the whole post. My Prius tends to use a bit of oil, I don't know the exact numbers just that it can't go without a couple top-offs between 10k oil changes. As much as I love this car it's because of that fact it will be sold after it's paid off as I've never seen a car that uses oil and yet drips none onto the ground.
    Anyways it's because of its oil consumption and me not being used to having a car that needs its hood opened between oil changes that I've worried and wondered if I forgot to check it and it gets low enough to make the oil pressure drop will the hybrid system turn the engine off assuming I'm going slow enough for it to do so? I understand if I'm going over ~40mph the engine has to be spinning to prevent MG1 from over-revving. So lets say I'm doing 65 on the interstate and the triangle lights up then I slow down and come to a stop will it prevent the engine from turning back on, or I'm sitting at a light and the engine is running because the heater is on then the oil pressure drops will it prioritize protecting the engine over the heater? Or is it like a typical car it will warn me but it's up to me to stop the car and turn the engine off as fast as I can to lessen the damage that is being done?
  2. Patrick Wong
    18,199
    6,464
    It is up to you to turn off the engine as fast as you can or the engine will be damaged.
    Would you prefer to own a car whose engine actually leaks and drips oil onto the ground?
    It is up to you if you want to sell your car just because of this issue, but personally I don't think it is a big deal to check the oil dipstick at every other gas station visit, and add a $3 or $4 quart of oil when needed.
    Starship16 likes this.
  3. Mendel Leisk
    38,253
    Checking the oil periodically is worth doing with every car, doubly so if you're consuming oil. I'd suspect by the time the car lets you know there's a problem, it's an expensive problem.
    Starship16, valde3 and Sergiospl like this.
    48,995
    the correct answer is yes.
    padroo and M in KC like this.
  5. JC91006
    16,470
    8,383
    But it may not start again afterwards
  6. orenji
    orenji Senior Member
    5,884
    3,486
    The engine will shut off automatically, (and it will let you know with a bang or smoke) but will never start again....:eek:
  7. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Yes, it will shut off automatically, while magically transforming itself into a hunk of scrap metal.
    Don't run it out of oil. "A couple top-offs between 10k oil changes" isn't much.
    cwerdna likes this.
  8. bisco
    48,995
    correct.(y)
    shouldn't a 2007 be getting 5,000 mile changes?
  9. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Depends where you live and what oil you use. In UK 10,000 mile OCI has always been the recommendation from Toyota using synthetic oil in the gen2 and gen3
    John
  10. bisco
    48,995
    thanks john. the o/p (who has yet to respond) says he's in tennesey, but hey, this is the internet.:p
    theshark likes this.
  11. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Has anyone actually had the engine quit because of low oil? I'd like to hear someones experience about this.
    If the low oil causes the engine to stop because the ECU shut it down doesn't mean that it is fried. It should only need a refill of oil to get you going again.
    The real problem is if the ECU doesn't shut down the engine then the engine is fried. That is because low oil = lots of increased friction and then the engine seizes up. Then it is fried!
    You gotta love a Prius because it protects us from our dumb things we do.
    P.S. make sure you have oil with you when you travel.
  12. Okinawa
    Okinawa Senior Member
    1,333
    317
    You have to check the oil level on all cars. That is no big deal. I have a 2014 Avalon. I check my oil about once a week. I add a little oil between 10,000 mile oil changes. No big job.
    Starship16 and valde3 like this.
  13. uart
    uart Senior Member
    4,215
    1,200
    Australia
    I agree with Okinawa. I don't see it as such a big deal. You need to check your tires for air from time to time. You need to stop and pump in petrol (gas) periodically. There aren't any cars on the road that you can just drive and do nothing else. Is looking at the dipstick once a month or so really that onerous?
  14. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    When an engine is out of oil it will make it known before going bang. It'll make more and more noise, lose performance, struggle, knock, grind, clatter and even then it might still run. But at that point it's scrap, even if it does still propel the vehicle forward. Once you fill it with oil again it will really just burn it as the damage will have been done.
    It's rare for an engine to just stop due to lack of oil - unless you ignore all the above symtoms - but run the car low on oil and it is junk. Top it back up with oil thinking you can save it and you won't - it'll just blow smoke as it burns the new oil at a phenominal rate.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Wasn't there a post recently where a Prius Owner had a problem with a repair shop that had changed the oil but NOT replaced the plug, and when the oil drained out and the OP noticed it, the shop defended themselves by telling the OP there couldn't be too much damage to the Prius Engine because it had an automatic "low oil" turn off capability?
    To which most of us screamed....BS!
    I think any rumors of The Prius somehow "knowing" when it's oil is low and having the capability to turn it's own engine off in defense should be squelched.
    No.
    The Prius does not have this ability.
    Therefore it behooves owners to be aware of oil level and consumption and NOT drive with the false chimerical idea The Prius will protect you from any engine damage should the engine become too low on oil.
  16. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Here's an interesting read and some pics from Noah Hoffman, a World Cup cross country ski racer from Aspen. He'd had his '04's oil changed in September and in March it threw a rod through the block. Noah is a great guy but I'd bet he wasn't checking his oil much, if at all!
    Scroll down to the last 3 pics and the accompanying text.
    From Car to No Car - Noah HoffmanNoah Hoffman
  17. Patrick Wong
    18,199
    6,464
    Too bad he didn't consider the possibility of installing a used engine. That might have cost him ~$2.5K or so depending upon labor cost in his area. The used engine itself could be purchased for <$500.
  18. JC91006
    16,470
    8,383
    wow a broken down 2004 is not even worth more than $100. I actually think the mechanic and the tow truck driver was in it together to lowball the deal.
    #18 JC91006, Jun 21, 2015
  19. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes, you're definitely on the money with the "if at all" part.
    I notice that he said in his blog:
    Pretty certain that a much better answer would have been "but I had checked the oil just last week", if indeed that had ever actually happened (not likely). :)
    If you were still unsure as to whether or not he ever checked the oil, the next paragraph says:
    Oh say no more. ;)
    Oh well. That story does somewhat support the OP's position here. It illustrates why at least some people cannot own a car with even fairly mild oil consumption.
  20. Mendel Leisk
    38,253
    When we went to a new owners night, the service manager told the assembly their goal is to ensure you never have to pop the hood.
