Info Screen - Navigation Display no longer working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AceMulder, Jul 28, 2014.
  1. AceMulder
    AceMulder Junior Member
    Orange County, California
    The Navigation touch screen does not work. I can still us controls on the steering wheel, bu the touch screen is dead. I am assuming that I just buy and install a new screen? Or could there be something else to trouble shoot?
  2. AceMulder
    BTW this is a 2007 Prius I believe it was the VI top of the line in terms of extras.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Not sure of your location. You should update your personal details to show your location. I would suggest you Google AutoBeYours, they are in Indiana. Scott there can send you a working MFD and you can replace it yourself. He also has instructions on removal and replacement. Sometimes it is as simple as wiggling the wires where the interfaces connect. MFD failure is a item that does happen unfortunately. It doesn't happen real often, but yours is not the first one to go.
    I would avoid the dealer like a plague. You will find a new MFD to be very expensive.
    Hope this helps you.
    Ron (dorunron)
  4. AceMulder
    I am in Orange County California, but I am sure the Indiana contact would work as well if there is nothing closer
  5. dorunron
    3,318
    1,103
    Houston, TX
    Contact Luscious Garage in Cali. They might have a MFD or be able to point you to one. A Google search will reveal Luscious for you.
    Ron
  6. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    You might also give Avi's Advanced Automotive a try. (Not very far from you).
    dorunron likes this.
  7. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
