Iphone 4 and Prius 2012 - Transfer partial contacts
Discussion in 'Gen 3 Prius Audio and Electronics' started by HaroldMelamed, Mar 29, 2012.
  1. HaroldMelamed
    HaroldMelamed New Member
    Just got me a new Prius 2012 and it transferred all of my iPhone contacts into the phone book on the Prius. Is there a way to only transfer part of the contacts?
  2. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    From what I've read in the owners manual and from others on this site, unfortunately not. It sure would be nice if you could...
  3. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    It just reads your phone address book dynamically. I think they disappear when the phone Bluetooth connection is broken and/or car turned off unless you add them to Stored Contacts.
    You could upload a selected list of contacts to the Stored Contacts list which stays in the cars memory vs. dynamically read from the phone's addressbook via Bluetooth.
  4. bfenwick
    bfenwick New Member
    Bay Area
    I have a iPhone 4S (but I'm sure this is a iOS 5 setting) and under the Setting, Bluetooth, Devices, select your phone. If you have Groups set up in your Contact list (which I have done via my Mac), you can select a sub-set of Contact you want to sync with your car.
  5. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    I have a huge list of contacts. Syncing the whole database over BT every time I get in the car isn't going to work well for me.
  6. ProximalSuns
    1,877
    PNW
    It cuts off at 999 contacts and those load quickly via BT.
  7. pacohaas
    pacohaas Junior Member
    56
    +1 for this, I know this works. I have mine set to "Sync Contacts, Phone Favorites, Phone Recents" and under "Other Groups" selected None.
  8. jon_lancaster_toyota
    jon_lancaster_toyota Nate Riesen
    120
    68
    Madison, WI
    I was initially told that it stores contacts dynamically, but I'm not sure that's correct. The fact that BT quickly pulls the contacts onto the car every time doesn't work for me.
    The first time I pair BT it takes about 40 seconds to transfer my contacts, every connection after the initial I have a quick connection and can see my contact list nearly immediately. I'm just not sure about the workings there.
    Add the "Refresh phone book list," and I'm further thrown off.
    Still, Great find by PACOHAAS. I wasn't aware that you could since individual lists. I love it
