iPod "skips" in USB mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rogerv, Mar 16, 2012.
  1. rogerv
    rogerv Senior Member
    1,632
    306
    Simi Valley, California
    I've noticed occasionaly my music goes silent for a second or so when the iPod is plugged into the USB port. But then it will play without missing a beat for long periods. Anyone having a similar problem? Any ideas as to what could be wrong? No skips when using the aux plug.
  2. Piprius
    Piprius Member of the cult of Prius
    72
    MD
    I thought people said plugging drives in to the USB results in the car indexing the drive. AUX is just sound out. Larger drives take longer to index. Or so I understand from reading PC.
  3. podmon
    podmon Junior Member
    SF Bay Area
    I picked up my PIP yesterday ( ya-hoo) and noticed the same skipping with an ipod classic plugged into the USB port. Every song about 2 or 3 times a 2 second skip. Annoying. This ipod works perfectly in a 2011 Hyundai Genesis so I don't think it is the ipod. I may return to have service look at it but my feeling is that they will be clueless.
  4. rogerv
    1,632
    306
    I've gotten used to it, and found it the most convenient way to listen to music in the car. It starts and stops automatically, something it won't do when plugged in using the aux cable. Nathan at Carson Toyota suggested it is similar to buffering on my home PC. What I wish I had was an easy way to convert iTunes to a format the system would accept, so that I could just put all my music on flash drives!
  5. janie
    janie Precious Prius Plug In
    163
    37
    In iTunes, you can convert your music to mp3 format, and then copy the mp3s to a flash drive.
    I can do that on my Macintosh computer's iTunes, but I am not sure how iTunes works on a PC.
  6. rogerv
    1,632
    306
    The problem I have run into is that most of the music I have purchased is "protected" and can't be changed to mp3 format.
  7. janie
    163
    37
    Oh that is too bad. There are software programs out there that can help you to do the change to mp3 format, but of course, it takes time to do all of the changing.
    On the Macintosh, I have used a program named "Switch" to do some conversion of lectures I have recorded on my iPod/iPhone. There may be a version of Switch to use with Windows (PC).
  8. pfile
    pfile Member
    319
    35
    bay area, ca
    if you want to solve this, you can turn on itunes match, match your library, then tell itunes to use a new, blank library and turn on match again. then you can download everything from apple in the new, higher bitrate, unprotected AAC format.
    of course this costs $25 so it is insult to injury.
    if you are talking about some music service other than itunes, sorry for the diversion :)
  9. ThatTallGuy
    ThatTallGuy Junior Member
    67
    Southern NH
    Never used iTunes myself, but there seem to be plenty of options for converting protected tracks to MP3. Google is your friend.
  10. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
    Mine was doing that some...went away with a different USB cord.
  11. krishkal
    krishkal New Member
    Fremont, CA
    I have never had this problem with the iPhone (yet!)
  12. rogerv
    1,632
    306
    I have tried the sat. radio a few times, and notice that it tends to blank out momentarily as well, but in that case it is usually due to something interfering with the signal. I've noticed that same problem on other cars with sat. systems, and actually my iPod is really no worse. I am going to try some of the suggestions made by recent posters, starting with a different USB cord.
  13. Rocky77
    Rocky77 New Member
    17
    Capitola, CA
    I'm having the same issue in my new Prius. Pretty annoying. I'll switch out the USB cord and see if that helps.
  14. jtse818818
    jtse818818 New Member
    It also happened to me but when i tried a different USB cord, it worked fine.
  15. Priuskat
    Priuskat Junior Member
    36
    Orange County, CA
    With USB - Iphone (works w/ other cars) does not connect to PIP car speakers (the screen does) . . . when aux cord (tried 3 different new cords) -static. I have not come across anyone else having this issue - may take car in.?
  16. rogerv
    1,632
    306
    I tried a different USB cord with the same result. Mine works fine with the Aux. cord, but then I have to remember to switch off the iPod, just like with my '06.
  17. bniblock
    bniblock New Member
    Louisville, KY
    I don't have a plug-in but I have a 2012 Prius 4 and my usb connected ipod skips. I've tried 2 different usb cables and 3 different ipods. I've also tried the vehicle in different driving modes (ECO, Power, EV) and the ipod skips every time. I took it into the dealer and they applied a software update but the skipping persists. They tried the ipod on other 2012 Prius and they also skipped. The dealer is saying nothing can be done until Toyota technical support gets enough complaints that they come up with a fix.
  18. j_benj
    j_benj Prius C Fan
    125
    Jersey
    I've tried my 160GB iPod Classic in my Prius C and same thing. Lots of skips. iPod works fine otherwise.
  19. COIllini1
    COIllini1 Junior Member
    34
    Colorado
    Are you talking about the real iPod or the iPod in an iPhone?
    I have noticed that music from my USB-connected iPhone pauses for a short moment when it receives an email or a message. I suppose it would not happen if I turned off the notifications for these things. Obviously, if it is happening with a device that does not have email or messaging capabilities, it can't be the reason.
  20. jabecker
    jabecker driver of Prii since 2005
    448
    73
    Portland, Oregon
    I have a 160gb iPod Classic and an old 1st gen iPod Touch, and both work fine. Every once in a great while there's a pause for a second or two. That happens maybe once in two weeks.
