Is my display lunched?
Discussion in 'Gen 2 Prius Technical Discussion' started by jackmccullough, Dec 18, 2011.
  1. jackmccullough
    jackmccullough Junior Member
    45
    Montpelier, Vt.
    2008 Generation II driver with about 66K miles.
    Yesterday when I got in the car to do errands the car turned on but neither the MFD nor the main dash display turned on. I was able to get a little bit out of the MFD when I would push the display button, but it would fade and then go off. The main display was completely blank (no speedo, lights, other indicators, nothing), although it would show the turn indicators when I signaled.
    When I got where I was going I couldn't turn the car off by pushing the power button, and I couldn't get the trunk open to get the garbage out.
    When I got home the car would turn off and I got the main display back on, but on one other driving trip yesterday the main display worked but the MFD was sporadic at best.
    I'm assuming it's not a fuse issue because then it would be off for good.
    Give it to me straight, guys? Am I looking at a new MFD? Also, any thoughts about the main display and not turning off business?
    Thanks.
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I suspect that you're experiencing some of the random
    symptoms of a dying 12V battery... :(
    Much less expensive and easier to remedy. :)
  3. jackmccullough
    45
    Montpelier, Vt.
    Seriously? My current 12V is barely a year old.
    <dislike>
    Thanks.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Yes, until it can be ruled out. It is not unheard of for a new
    12V battery to be installed without a full charge which over
    time can lead to problems.
    Have you taken any battery readings after the car has unused
    for a significant period such as unused overnight?
  5. jackmccullough
    45
    Montpelier, Vt.
    No, but I guess I'll be making a call on my dealer tomorrow.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  7. fotomoto
    fotomoto Senior Member
    5,598
    3,774
    So. Texas
    Could be something as simple as a loose terminal.
  8. jackmccullough
    45
    Montpelier, Vt.
    I tried the battery test. Under load it was just under 12V, like 11.7-11.9 (it varied).
    It did stay above 12V in Ready mode.
    If it's a battery at about a year old do they come with any kind of warranty?
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
  10. fuzzy1
    10,081
    In Ready mode, you are really measuring an inverter output, not a meaningful battery voltage. Load voltage, and resting voltage when the car has been shut down for several hours, are more useful.
    Aftermarket batteries typically do have warranties. Do go find your purchase paperwork. It may also be marked on the battery itself, with a little punchout tag to indicate purchase year and month.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    The 11.7-11.9 is death. My oem almost 5 year old battery measures better than that by comparison.
    Did you ever have to jump start this battery? If that answer is yes that's why the battery is bad. Those little AGM's cannot handle one good discharge without mild sufation and that has a big impact on its ability to hold a charge.
    Your mileage probably has been bad lately too as marginal battery will never charge right causing the engine to run alot more than necessary..
    I'm afraid we will be seeing a rash of bad batteries form here on out
    becasue its really starting to get cold and that will kill a marginal battery.
    I recommend abandoning that battery and step up to an Optima as suggested because even if you bring that battery in all the dealer is going to do is
    put that battery on a charger & then tell you its good.
    Month later your stuck somewhere. Do everything you can do to not put yourself in the situation where you need a jumpstart becasue if not done properly can cause $ thousands of $$$ of out of warranty damage.
    Oh and its a very good thing to put the battery on a charger once a month. Put it on a standard charger in 2 AMP mode. It should charge the battery to O current draw in less than 15 minutes. Done.
    That will really prolong battery health for years. Alot of us on this forum regularly do this.
    I can't remember the last time I had to buy a car battery.
  12. jackmccullough
    45
    Montpelier, Vt.
    I've never had to have a jump with this battery, no loss of mileage.
    I'm not arguing, but this is totally without warning.
    Thanks for all the great information.
  13. fotomoto
    5,598
    3,774
    So. Texas
    I had the original battery in our former Nissan Cube die instantly and completely at 14 months. The car was driven 50+ miles/day so it wasn't from lack of use or cold.
  14. jackmccullough
    45
    Montpelier, Vt.
    I just checked in my glove compartment: November 24, 2010.
    Maybe it's just me, but I think a $200 battery should last longer than a year.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    So do I but Toyota warrants a replacement battery for only 1 yesr. Since you have to buy a battery, buy a better oone.
  16. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Hmm...call me a skeptic, but I don't think it is your 12V. Failure to turn off implies a 12V battery with a dead cell. 11.7V under load isn't fabulous, but it isn't dead either. This is looking more like a combination meter problem.
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  18. jackmccullough
    45
    Montpelier, Vt.
    The symptoms definitely match the Luscious Garage description.
  19. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Hobbitt has been inside of these (of course...!)
    Prius MFD
    I am thinking that the problem being traced there (intermittents due to cracks in the connectors) is not present in newer MFDs. But who knows...
  20. jackmccullough
    45
    Montpelier, Vt.
    It turns out it's the combination display ECU.
    The replacement is going to be paid by the extended warranty I didn't want to buy. They're also covering the cost of a replacement rental car until it's fixed, so until next week I'm driving a 2011 Prius.
    I'm still not that close to covering the price I paid for the warranty.
    Thanks for all your help, guys!
