is there any downside to a prius?
Discussion in 'Gen 2 Prius Main Forum' started by stinken1, Jun 20, 2005.
  1. Tideland Prius
    16,206
    Ohhhh, that's why. I was thinking to myself. The armest is quite high and fits my arm nicely.
    Yes, the Classic Prius' centre console is much too low
  2. popoff
    popoff New Member
    560
    western NC mountains
    Sorry, I was assuming '04-'05.
  3. MadHungarian
    MadHungarian Member
    139
    Atlanta and Miami Beach
    From other posts:
    Seats lack sufficient rearward travel, and have no upward tilt on leading edge of bottom cushion=real problem for tallish drivers on longish trips! Perhaps the electric adjustable seatc rummroed as option in "06 will remedy this--if I can retro-fit one!
    And from me, today. My black paint adds scratches like the government adds debt. More every day!
  4. MadHungarian
    MadHungarian Member
    139
    deh2K: Sorry about that. Big fingers, little keyboard. Its my typiong . . .
  5. Ron Dupuy
    Ron Dupuy New Member
    112
    Fortuna, CA
    It won't hold seven people, beat a corvette off the line , tool off road, or tow a fifth wheel! What do you expect? It's a mid size transportation car that gets tremendous mileage and is fun to drive.
  6. MadHungarian
    MadHungarian Member
    139
    What do I expect? The advanced technology of the Prius PLUS the interior design one gets in a Corolla or, dare I say it, a Civic or a Golf!! I wouldn't trade my Prius for any of them, BUT the presence of the former is NOT (IMHO) justification for the latter, Ron.
  7. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(Jonnycat26\";p=\"100171)</div>
    I guess this must be relative. A friend and co-worker who used to have an Acura complains about exactly the same thing (he's having some process done -- I forget the name at the moment -- to insulate sound in the Prius' paneling).
    However, coming straight to the Prius from an old '87 Civic, I find it refreshingly quiet.
    I would think BMW drivers would find the Prius noisy -- the few I've been in have been damn near silent.
  8. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I find the maximum weight limit to be a bit confining. The manual says it has a 825 pound passenger and cargo limit. It also claims to be a five passenger vehicle. The manual explicitly justifies the 825 pound weight limit in regards to 5 passengers by making the assumption that the average weight per passenger is 150 pounds. Obviously, it was designed with Japenese passengers in mind.
    I'm 5' 11" and weight 225 pounds. I do have a bit of a "beer gut", but I definitely wouldn't qualify as grossly overweight. However, four of me would exceed the weight limit by nearly 10%.
  9. stinken1
    stinken1 New Member
    thanks for all your replies everybody. :p
    i feel so more knowledgeable about my PRIUS!!!
  10. Tyeise
    Tyeise New Member
    22
    Rhode Island
    <div class='quotetop'>QUOTE(kirbinster\";p=\"100208)</div>
    This must be different for different people. It's a bit high for me. But then, I'm short.
  11. Tideland Prius
    16,206
    Tyeise, kirbinster is referring to the Classic Prius which doesn't have an armrest cause the console is short
  12. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(bookrats\";p=\"100463)</div>
    If you could find out how much it's costing him, I'd appreciate it.
  13. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    Only major downside I can think of that hasn't been mentioned is the the scarcity of Prii make a replacement a dicey proposition if your car is totalled. I thought of this when I discovered that my Prius had been hit (and ran) overnight to the tune of about 6k in damage. My first thought was, "Oh God, how would I replace it with the waiting lists getting longer daily?"
    Have fun.
    Bob
  14. stinken1
    stinken1 New Member
    <div class='quotetop'>QUOTE(Bob Allen\";p=\"100828)</div>
  15. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Maintenance:
    The plugs and coolant need to be changed at 100-120K. Coolant is more involved than in a traditional car, especially with the thermos bottle. You have to be sure the inverter cooling system is properly purged of all air or it may be damaged.
    Batteries for the classic have held up quite well. Too soon to tell for G2.
    Although not addressed in maintenance as when to actually change it, you should probably change the tranny fluid at 60-100K. It doesn't get the same heavy use as a traditional auto tranny. It's more like a manual transmission with long life ATF, except not gear shifting to cause any grinding wear, and no hydraulic controls to get clogged.
    Brake system is also more involved if it needs bleeding, but simple brake shoe/pad change should be standard stuff, but would need to be done way less often because of regen braking. Perhaps the life of the car.
  16. rocco
    rocco Member
    146
    FL
    I have one (really only ONE) complaint and that is the low clearance. Of course I'm coming from a Landcruiser but I've yet to get used to it. 3 times I've hit the "bottom". The first I posed about where that strip came off (I did get it fixed), second I ran up on a broken down curb, my teenager is learning to drive and she ran over a curb both front and back wheels. So unforgiving -
    This car is pretty easy to drive for a new learner - I just wish it had an emergency brake in the middle so I'd feel a little safer in the passenger seat when my teeny daughter's foot slips off the brake pedal.
  17. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    The only downside I have experienced is the need to log my mileage on an Excel spread sheet and depression when I go below 54 mpg. :D
  18. Tideland Prius
    16,206
    :lolup:
    I agree on the ground clearance. I feel like a ricer in a slammed Civic. After I've scraped the bottom on a temporary hump (that was protecting some wires that ran across the road), I'm a little more careful when going down ramps or anything that has concrete pointing up
